Question about Thermador SGS36GS Gas Cooktop
Clicking gas cook top
All of a sudden tonight one of the burners on my Thermador gas cook top started clicking. The unit is off. I did not just clean the cooktop and there has been no water used either. Actually, I hadn't used the cook top at all today. I hate to go to sleep tonight.
  • Anonymous Mar 05, 2009
    sudden this morning one of the burners on my Thermador gas cook top started clicking when I attempted to turn it on. I don't smell any gas, nor is any gas comming to the burner. I did not just clean the cooktop and there has been no water used either.
I accidentally bumped the thing where the gas comes out (I don't know what it's called - I'm a wife not a tekkie) and it started clicking when I turned it on. I turned off the gas and repositioned that gizmo and it stopped clicking.
Posted on Mar 18, 2009
Thermador gas stove top is clicking when not on
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Aug 21, 2011 | Thermador SGS36GS Gas Cooktop
My 6 burn cook top when it turn it on it keeps on "clicking
heatman101
Jun 16, 2011 | Thermador PC366BS Stainless Steel Gas...
I was cleanning my 24" stainless gas cook top when all of the sodden a clicking sound from the pilot doesnt stop what do I do?
Gas Range RepairBurners Keep on Clicking
heatman101
Sep 18, 2010 | Verona 11 in. CTG212F Gas Cooktop
Burner shuts itself off after 10 0r s minutes of working normally
this unit has a gas coil controling the valve . and wen it gets hot it is failing and cannot keep the gas on . replace the valve coil // mm
Jul 12, 2010 | Thermador PC366BS Stainless Steel Gas...
Miele Gas hob KM326G 2 burners won't stop clicking
Hello Leighvz,
The rings around the burners should be cleaned periodically. Each one has a series of holes to let the gas come out and have to be set back perfectly or else you will continually have this problem. You can clean with regular dish soap an water and a sponge or rag.
Also, If you put a pot or pan on the burner and it is too large it will cut off oxygen to the burner causing your clicking. The clicking only occurs when the oxygen supply is not enough. Hope this helps
Sep 07, 2009 | Miele 35 in. KM326G Gas Cooktop
Clogged burner on gas cooktop
lowly is it the left burners that won't lite? I only ask as depending on the model some of the Thermador cook tops had simmer control burners. This is a 3 part system on the burners. 1 a simmer control, 2 electric solenoid, 3 potentiors. When you turn on the burner the potentior tells the simmer control to send power to the gas solenoid. At the same time the unit will spark. If your unit has extra low on the left 2 burners then you have this system. The usual problem in the potentior. Hope this helps.
Aug 07, 2008 | Thermador SGS36GS Gas Cooktop
Burner won't light
Clean the gas nozzle w/small wire are located at the back of the gas cook top /shut off the gas clean small gas nozzle clog / w moisture /rust dust and any foreing material.
Dec 19, 2007 | Thermador SGS36GS Gas Cooktop
Starter keep trying to start when cook top is off.
If you have recently cleaned unit and got moisture behind knobs, this may stop when the spark switches dry out. If not you will need to replace spark switches behind the knobs.
Nov 14, 2007 | GE 30 in. JGP337 Gas Cooktop
Ticking Sound of spark igniter persists
Our GE cook-top burner igniter has started ticking even when the oven is shut off. Even after cleaning the bottom of controls the ticking persists. Any suggestions? Thanks
Aug 27, 2007 | GE 36 in. JGP628 Gas Cooktop
Thermador SGS36GS Gas Cooktop Logo
209 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
jasbo
jasbo
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
