Question about Car Audio & Video
How to set up my audippipe apa 4500 rack mount pro amp
I'm trying to hook my amp (audiopipe apa 4500 rack mount pro) to my mixer and speaker (one) which is a 15'' enclosed in a box with red and black input, and also 1/4 jacks. now my amp has so many switches in the back that i dont know where and what to set. first i have a switch for stereo,parallel, bridged have a switch for1.44v,1.0v,&0.7v also another switch for normal,compress. one more switch 115v manual came with this item to tell me what from what i'm afraid to burn it out if ya know what i mean, My amp is goint to a vestax pmc170a which i have connected to a- torq connectiv going to my -sony vaio laptop vgn fs790 ok guys lets c what you can do. i do have it connected but i know i have it wrong cause it sounds bad and not very loud.
2 Suggested Answers
  • 222 Answers
SOURCE: i have a v12 amp hooked up to 2 12
swithc it to mono
Posted on Jun 13, 2010
Just bought the mixer and when i hook up the mixer to the amp the amp showing it clipping and no sound to the main speakers
If you are getting signal from you mixer at leaves tha are clipping your amp, then the mixer is working and at least the front end of your amp is working to register the clipping. In that case, your problem is-
1. The amp outputs are blown, check by hooking up to a different amp.
2, The speaker wires are connected incorrectly.
3. The speakers are not working. Try a different set.
May 21, 2016 | Mackie 1604 Vlz3 16 Channel Mixer
How can I get an instruction manual?
Audiopipe website
is apparently not very well organized, so that the access to the support area for PA speakers is not available.
You can read how to use your speakers in the review hereafter.!Audiopipe-DJAP1577AUSB-Review/cx9u/556af6710cf2adc1ad6bd5bd
Oct 21, 2015 | Audiopipe DJAP1577AUSB 15" Dj Speaker...
Speaker humms only. what causes that?
Incorrect connections or volume settings.
• In powering up, mixer first then amp
• In turning off , amp first then mixer
If hum still persist, without the mixer connected
then speaker amp may need servicing.
Jul 31, 2012 | Samson Auro D415A Speaker PA Active
Would I need a mixer or amplifier with this product: Pyle-Pro Rack Mount 8 Channel Wireless Microphone System with 8 Lavalier/Headsets (PDWM8900)
The unit has a built in mixer as well as individual outputs. You would need an amplifier/speaker that could receive from teh mixed output jack of this. Use BALANCED TRS cable.
Aug 20, 2011 | Pyle PRO 19 RACK MOUNT PRO DJ MIXER SFX
Peavey XR800F 8 channel - I can't get but very little sound to my big speakers. Help
Troubleshooting is always a "process of elimination." Have you tried hooking up your Peavey powered mixer to another set of speakers? How about connecting the speakers to another audio system? Your term "very little sound" could mean audio input problems, mixer/amp settings or failure and possibly speaker damage (internal passive crossovers). Please be more specific.
Jun 12, 2010 | Peavey Pv 2600 Power Amplifier
How do I connect my behringer mixer desk to
The first thing to do is to swap teh L & R INPUTS to the amplifier. Did the speaker that works change?
If som the problem is with the setting of the mixer deck. If it did not change, then the problem is with your speaker wiring of the dead speaker, the speaker itself, or that side of the amp.
If the working speaker did swap, that means problem is with the mixer. The question then becomes how are you connecting to the mixer. You should be using TRS 1/4 inch connectors or preferably XLR from the MAIN outputs. These are balanced outputs connections.
If the inputs are from one of the mono inputs, the PAN control for that channel will control how much goes to each speaker... If at center, both will get same signal.
There are so many possibilities that I can't evaluate them until you try the test to find if it is problem of the amp or the mixer that I have given you to try.
Dec 28, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
I want to hook up a an interface to a mackie mixer. What is the common denoinator to hook up, let's say a digi 002 and a mackie mixer so i can have a mac computer with pro tools operational with also the...
you can just piggyback the mixers - take the outputs from the mackie mixer (assuming it is NOT a powered mixer) ... those should be line level outputs - send them into a line level input on the digi 002 and then set that channel on the digi 002 and once set, just leave it, and control the mackie channels individually ... should work fine ...
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at
Oct 14, 2009 | Digi 002 Rack FireWire-based Pro Tools LE...
I have a xenyx 2442fx mixer and ep2500 power amp hooked up to 2 1800x subwoofers and 2 1520 pro speakers. i am using a peavey xr 684f powered mixer to power my monitors. i would like to add another power...
You would need a 2 or 3 way crossover, depending on whether or not you biamp your tops. Simply go out of your main outs on the mixer into the input of the crossover. Go from the low output of your crossover to your low power amp input (subs), and the high output of the crossover to the high power amp input (tops). Then go from your outputs of your amps into the speakers themselves.
Jan 04, 2009 | Behringer B1520 Pro Eurolive 15" 2-Way...
Can I use these to Power 2 x 200 w 8Ohms
I think you should, the power supply could cost up to that price ( for a good one 13.8v ) and you could have a ground problem for the amps, humming sound if not properly ground.
Your welcome.
Dec 05, 2008 | Sony XM-222 Car Audio Amplifier
Dj equipment
SEnd all the high notes to the small speakers and the bass to the sub. Ran.
Apr 27, 2007 | Gem Sound GemSound PA-585 2-Channel...
Car Audio & Video Logo
299 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
