Question about Poulan Pro Chain Saw 46cc 20"
Poulan Pro 36cc won't start
Replaced spark plug and plug wire assembly. Still won't start. If I take the plug out and pull the crank I see no spark.
  • Anonymous Feb 27, 2009
    same problem here sorta . The saw stopped running and then would never restart and I noticed that sometimes I could get a little electicity through the plugwire but usually none at all. So,
    I waited 10 days for the local supply place to deliver me the ignition module
    and it isnt quite the same as the old one but it seems to fit well , but I coudnt get any spark at all through it .
    so I retried the old one and I'm getting a little spark but apparently not enuff to start it .
    I just bought the saw 6 months ago at lowes and have barely used it .
    I dont know what to do . I'm so sick of giving places like lowes my money for their junk cuz they are useless after the sale . I sincerely hope that they manage to go bankrupt soon .
  • josh1111 May 11, 2010
    mabey the magnet on the recoil is rusted is it an old saw.
  • 97 Answers
Spark should jump at least 1/8 inch gap.You would need the correct coil for the application spaced at 10 to 12 thousands inch.
You might unplug shutoff wire and try,it might be shorted a lttle causing weak spark.
Posted on Mar 14, 2009
Poulan Pro 42" with 17.5
you need to find out if there is spark at the plugs
pull the plug put the wire back on hold it away from the engine then crank it over, you should see a nice blue spark arking from plug the engine body
If not then you need the start checking pug , wire , coil, or magneto wich ever your machine has
Jul 23, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a poulan pp3816 pro 38cc that leaks gas out the muffler
Its either well flooded, or the carb needle is leaking, remove the spark plug, with the ignition switch off crank the engine to evacuate any fuel left in the cylinder, leave the machine for a couple of hours, re fit the plug and try to start useing no choke, if it still does not start, remove the spark plug again, rest it on top of the cylinder ( away from the spark plug hole ) crank the engine and check for a spark, if it has a good spark and the plug is soaked with fuel it could be a carb needle leaking, remove the carb, remove the metering cover held with four screws, replace the rubber tipped needle.
Jun 21, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Cut the grass twice now it won't start. Please help
Need more information...
Is it getting gas? If so take a look at the spark plug wire and make sure it hasn't pulled away from the boot.
REport back what you find
Jun 14, 2011 | Poulan Pro 22" Self Propelled High Wheel...
I have a Poulan Pro 295 20 " chain saw that wont start.No spark from plug.Think the magneto is bad. Model no.952-051310 . Need opinion and part no. Thanks.
Do a basic test first, remove the top cover, pull the earth cut out wire from the terminal on the ignition unit ( this will iliminate any problems with the switch, or wires ) now try for a spark, remember that they work off speed of rotation so give it a good pull, make sure you use a good clean plug, well earthed against the cylinder. If there is still no spark, you will need to replace the unit, part no. 530039143
Feb 17, 2011 | Poulan Pro Chain Saw 46cc 20"
New saw - will not start. Have put in premium gas/oil mix. Getting spark from plug when cord pulled. Hasn't even fired once.
It's possible the brake is on. Try pushing the brake forward then pulling it back until you hear it click. Then try cranking it again.
Sep 20, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro 18 inch saw. Once the unit is warm it
start saw when cold and work it hard. if it stalls or quits remove spark plug and hook the plug wire to the plug and ground to the cyl head have switch on and pull the start rop briskly a few times or use a test plug. if there is no spark disconnect ign switch from from the ign wires and pull rope a few more times.spark?= replace ign switch,no spark until engine is cool,replace coil.
Sep 23, 2009 | Poulan Pro Chain Saw 46cc 20"
No spark from spark plug
New Saw? Warranty time
Electronic ignition? Replace entire module. Pinched wire to metal case part for ignition switch. Permanently shorted ignition switch--replace.
Jun 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 6.75 Lawn mower will not start
Remove spark plug, clean and dry. Replace plug. Remove air filter. Spray WD-40 into carb opening; one second blast. Turn over engine, (pull handle). Engine should start briefly and run for 3 seconds.  If not, you are not getting spark to spark plug. If engine starts, you have a dirty carb and you can buy a rebuild kit from manufacture.
May 02, 2009 | Poulan Pro " Pro" Self Propelled Mower
Poulan Pro Lawnmower
i have a 950 zx poulan pro lawn tractor. it will start but when i release the brake it cut off . i can start it up with out sitting in the seat.
Jun 14, 2008 | Dryers
Poulan Pro Chain Saw 46cc 20" Logo
296 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
