Question about Pioneer Audio Players & Recorders
Home Amp fuse keeps blowing
I have a pioneer home amp and the 6.3 amp 125v fuse keeps blowing. i went to a Electronic store to get some more fuses for it but they didn't have the 125v, but they recommended that the 250v would do the same job. all of those fuses blew as well.
  • vadavid Sep 15, 2012
    Did you ever figue this out? I have the same problem. I found two bad capacitors on the same board as the fuses and replaced and now at least the relays click over again but the fuses still continue to blow resulting in no soundoutput from the speakers or headphones. blow.
    BTW, the make and model is the pioneer VSX-D1S
  • 4,234 Answers
This usually happens when there is a problem with the main power supply and is relatively rare. If you can post the make and model, I can give you some things to check if you are somewhat familiar with electronics.
Posted on Feb 19, 2009
My pioneer SX 20 blowed fuse and unhooked all external wires and keeps blowing fuse
If you've disconnected everything and the amp is still blowing fuses you'll need to have a technician look at it. Most commonly I find that condition caused by a failure in the power supply section of the amp.
Good luck.
Mar 21, 2015 | Cars & Trucks
My 20 amp fuse keeps blowing even though I have disconnected everything from all the outlets
You have a short to ground somewhere along the wire starting from fuse box to recepticle.
Jan 26, 2015 | Heating & Cooling
Power amp for pa system stopped working
Sounds like you have a power supply problem in the amp. I am assuming the fuse you are replacing is intergraterd into the AC connection. You need to dig deeper. If you are not an electronics person you will need a tech.
Jul 02, 2010 | Phonic Power Pack 620 PA Package B-Stock...
The unit won't power on at all.
You can try replacing it with any 10 amp fuse just to see what happens. If a new fuse keeps blowing out then you have a shorted power amplifier inside(they consist of transistor or a single chip). These device look normal most of the time short out with any visual indication. If you desolder the power amp chips(they are mounted against an aluminum heat sink to dissipate heat) and the fuse quit blowing then it is the problem.
Aug 11, 2009 | Samsung HT-TX72 Theater System
Im having trouble i keep blowing fuses on my amp?
you have you gain and freq knobs turned up too far, try turning them down and turn down subb level from deck
Apr 13, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
Keep blowing fuse under hood when i put power wire in to amp
disconnect the negative battery terminal, replace the fuse with all the wires hooked up to the amp and reconnect the battery terminal, that way the initial surge of power goes through the negative terminal and not your inline fuse. That should solve your problem.
Mar 29, 2009 | Pioneer GM-5200T Car Audio Amplifier
Pioneer sd-643hd5
Sony Convergence
Nov 03, 2007 | Pioneer SD-643HD5 64" Rear Projection...
338 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
