Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Fisher paykel intuitive eco washer fills with water starts wash cycle then machine stops all lights start blinking rapidly
  • Fisher and P... Expert
  • 555 Answers
The LCD display panel needs new capacitors installed,
Get a technician to install new capacitors.
Posted on Dec 14, 2013
3 Suggested Answers
SOURCE:
  • 250 Answers
SOURCE: Fisher Paykel Intuitive Eco Washer is squealing
You need to pull out the washer, TURN OFF THE WATER, then take the water hoses off the back of the washer. Check the screens inside the water inlets for debris. If that doesn't fix the problem you may need to ask fisher paykel if it's safe to put a chemical like limeaway in those holes to remove hard water deposits that have built up inside the valves.
Posted on Sep 20, 2009
jnchahn
  • 252 Answers
SOURCE: Water sensing level not working on Fisher &
Your pressure value switch is malfunction. First thing you can try that is cheap to fix is to try clean the hose that connects to the outer tub. A lot of times there is algae develops after years of washing.
Posted on May 07, 2011
Water sensing level not working on Fisher & Paykel Eco Intuitive washing machine . The water just keeps filling up until I stop it manually . We can't use the machine to wash clothes as the Service...
May 07, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
My washer no longer produces cold water, only hot, except for the start of the cycle. The machine will tell me that it's not getting cold water. It doesn't matter whether I set the water temperature at...
It sounds like the fill hoses are inverted. Most of the Fisher washers only fill with cold water after the initial fill. So if the hose are inverted then it will only fill with hot. Beyond this I'm at a loss. Good luck
Apr 23, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
058 model does not fill up continuously, water in and stops starts and stops does that a few times and stop completely and beeps all lights stays on. Please help. Thanks
I have the same problem, just checked the switch and its all ok. But the machuine also stops and starts when its trying to empty after the last rinse cycle to start the spin cycle. Starts to drain then stops and repeats, it does empty some without stopping but starts to go silling when its nearly empty?
Jan 15, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Sep 20, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
After filling, stops, lights up cold temp and beebs
are you using the pre soak cycle ? if so it wil start up after the soak time cycle is up.otherwise skip this function.
Jul 03, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Wont stop filling
If when you press pause while filling and it keeps filling then you have a faulty valve. If the filling stops then valve is ok.
If you filling keeps going until overfilling the machine which is what i understand is your problem, then most likely that you have a small pinhole in your pressure tube.
Apr 18, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel 6.5 smart drive washer
My F & Paykel washer did this. There was a baby sock under the wash basin. I called for repairman and he found the problem.
Jan 05, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washer
If your washer does not stop filling, you have a problem with your inlet water valve at the rear top of the machine. You simply have to replace this.
Nov 30, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Machine cant get any water.
Does the water fill to the correct level ?
Sep 09, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
242 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
