Question about HP Computers & Internet
Pavilion a350n begins start, HDD and CD activity for 10-15 seconds then activitystops. No video and no beeps. Cannot get to BIOS as it does not boot that far. Motherboard?
  • Aenim4 May 11, 2010
    The motherboard does not POST, it means a critical system component is bad, either PSU,CPU, RAM, Video Card, or motherboard is bad.
    Does every fan spin, did you upgrade anything recently?
  • 60 Answers
Dissamble PC. Carefully clean every component with a wind blower. Use soft cloth if required. Assemble them one by one. Try to power on. If it does not solve, replace BIOS battery with new one and try with another working power supply. Still have problem, replace motherboard. Keep informing.
Posted on Feb 23, 2009
Acer 5742g Beep at boot up
I have a problem that looks like this one.
At boot up, after the POST, each time the HDD led blinks, the laptop produces a loud "beep", and refuses to boot, as if this phenomenon prevented the HDD to be read.
If I press the power button, it stops beeping. When I release it, it starts beeping again.
If I press F8 at the beginning and then ask for a normal boot, It boots normally. Anyway, in windows, I have some strange activity, like I would continually pressing Alt+Tab. If I press Esc, it stops immediately and then all seems to work fine.
Any clue?
Jul 26, 2012 | Acer Aspire 5742G
Beep from the system unit
1) Please make sure that the HDD IDE cable is plugged in properly on both ends. It is a 40 pin female cord which should be seated on IDE channel 1 on the motherboard.
2) Make sure that all the CD/DVD drives are on IDE 2 or on SATA
3) Make sure taht the Jumper setting on the back of the HDD is set to MASTER
4) Login to bios and make see if you can find the HDD from the IDE drives menu. I am sure you will. From Boot menu select the NATIVE mode that will activate both the SATA and the IDE channels. Select HDD as second boot device.
Feb 01, 2012 | Intel Pentium 3 , 450 MHz Pentium III...
HP HP Pavilion dv2000 no display
Oct 18, 2011 | HP Pavilion dv2000t Notebook
Dear Fixya, my GA 6bx7 (Intel bx440) , GA GF400mx,JNC 235 W Power,Cel 900Mhz start clicking just seconds after (or during) Post (no Hdd ). In Bios signal sound more loudly. There is second or more...
your hard drive is dying or dead,mouse and keyboard ps2 will normally work with operating sys,try with another h/drive should work clicking are heads crashing good luck!
Jan 08, 2011 | Intel Motherboard
Dear sir. my laptop hp pavilion dv5, its comming
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Aug 27, 2010 | HP Pavilion dv5000z Notebook
Running a Pavilion dv9700. Upon boot, the display
Yes this is a video card failure issue.you need to contact the Hp Tech Support for getting it repaired.
Feb 03, 2010 | HP Computers & Internet
My laptop won't boot from cd
to reset the BIOS, there is a small battery somewhere in your computer. if you unplug it for 3 seconds, it will reset the BIOS. I RECOMMEND THAT YOU DO NOT TRY THIS! get a service professional. If this doesn't work you might need to get a new laptop.
Dec 29, 2009 | Toshiba Satellite A105-S2712 Laptop
HP a350n - stop message during destructive recovery
Before acquiring a new hard drive try a check disk. Boot on the OS CD-ROM - guess it's a Win XP - and through the Recovery console do a complete check disk. chkdsk /p and chkdsk /r.
Mar 26, 2009 | HP Pavilion a350n PC Desktop
New HDD inserted into Pavilion ZD7000 - will not boot from XP CD
Try your old HDD in it and see if that works. If it does work then nothing is damaged except your DVD drive/Controller. Try putting the new HDD in another computer, installing windows then putting it back in the HP. If all else fails then flash the bios with an updated image and see if that rectifies the problem.
Feb 01, 2009 | HP Pavilion zd7000 Notebook
HP Cpmpaq Presario V6000
XP wont be able to detect your hdd as you are using a SATA drive. You have two options here
1. Disable SATA function in the bios (easier to do) and use again your XP cd to install the software, it should be able to detect the hdd this time around
2. You have to slip stream the SATA driver to your XP CD and recreate another CD from it. (harder to do). Google "SATA driver slipstream XP" you will be directed to the proper sites
Apr 05, 2008 | HP Compaq Presario V6000T Notebook
Computers & Internet Logo
81 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
