Question about Brother IntelliFAX 4100 Laser Fax
When printing or faxing there is a one to two inch blank spot
Printing or faxing there is a one to two ich blank spot on the left side of the page. There is about 50% toner left.
INSPECT THE DOCUMENT READER GLASS THIS SOMETIMES GETS WHITE OUT OR OTHER JUNK ON ON THE LENS AND LEAVES A VOID AREA.
Posted on Feb 23, 2009
There is a blank strip down the page about 2/5
Try going into your "Printer Propeties" and reset all parameters to the factory default. Thank you, Dana
Feb 06, 2010 | Office Equipment & Supplies
Printing blank pages when receiving fax
Ask if the ones sending are sending legal size, it may be using 2 sheets to get all from a legal size document.
Jul 29, 2009 | Brother MFC-8460N All-In-One Printer
It has plenty of ink and the drum is good but it stopped printing
All blank pages could either mean: On the scanner side: * Mechanical error, you'll need to perform service on it to reanimate it again. * You can check if it is on the scanner side by printing a test page on the printer. If it prints fine, the problem is in the scanning process.
On the printer side: * Dirty connectors between toner/drum unit and machine. Remove the toner/drum package and clean the metallic cylinders on the left and right side of the toner/drum unit, then reinsert package into machine. * Bad toner and/or drum unit. Replace should solve it. * Mechanical error, you'll need to perform service on it to reanimate it again. * You can check if it is on the printer side by either scanning to a connected PC or sending a fax to someone. If the scanned/faxed page looks fine on the pc/fax that receives the fax, the problem is in the printing process.
Jun 02, 2009 | Brother MFC 9700 All-In-One Laser Printer
Paper tears when printing
Helllo sir; I would say 99 % you have paper chip stuck in the paper path , ckeck the fusing unit,
Apr 14, 2009 | HP Color LaserJet 2600n Printer
Samsung MFC-SF560 fax not printing complete page
If you have already try another image unit, you should try to make a copy or print a report. If the prints came out ok, the problem could be the telephone line. GOOD LUCK.
Nov 21, 2008 | Samsung SF-560 Plain Paper Laser Fax
Printer prints top 1" of page, then just spits out blank pages
If the printer works ok on another PC, it seems quite clear that the problem is definately software (Driver) related. If you haven't done so already, I recommend adding the printer through the Printer\Faxes Add Printer Wizard and pointing it to take the drivers off the install CD (if you have one) rather than installing the printer from the CD Autorun. Just make sure that you've deleted the printer completely from Printers\Faxes and rebooted before each install attempt.
I hope this helps!
Cheers,
Matt Coyote
Feb 24, 2008 | Canon PIXMA MP780 All-In-One InkJet...
140XiIII left side print right side completely blank
Verify your LCD Display Print Width setting is set wider than your actual label width. The printer will only print to the width of the PRINT WIDTH setting. Also verify any driver or software settings as these override your printer settings.
Jun 30, 2007 | Zebra 140XiIII Plus Thermal Label Printer
Brother IntelliFAX 4100 Laser Fax Logo
106 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
