Question about Coleman Tools & Hardware - Others
Evcon hallway furnace pilot light won't ignite or stay lit.
I have an Evcon furnace in a closet enclosure in my hall way, model # BGM08012CX. Inside the front cover is a small, brown-colored box with a cable attached and the other end of the cable going to what looks like the in-coming gas valve. The auto pilot light will not light or stay lit if the cable is not pulled up hard to insure contact somewhere inside the brown box, I guess. My question is, can I replace the brown box or some other part causing the problem, or will I need to buy a whole new furnace? Thank you for any help you can provide for me, I really appreciate it.
Sincerely, Bert Brown
  • Thomas F. Schneider May 11, 2010
       You should be able to get every part for your furnace w/o replacing the whole thing. Even the burners are cheeper that the whole unit. Conrol or other elecricial parts are usually common to get, although I have not worked on you particular brand. Try a supply parts house first , then the dealer , if not available from the parts house?
jgwhomeequip
  • 1902 Answers
SOURCE: Pilot light will not ignite unless cable is tensioned up
No you do not have to replace the whole furnace, the bad news though since it has something to do with the gas, This is the ignition module (or brown box), you have to be a certified HVAC-R Technician or company to buy the part or do the repair
Posted on Feb 09, 2009
SOURCE: no problem-just want info
This unit is electronic ignition
Posted on Oct 04, 2009
  • 115 Answers
SOURCE: Evcon Coleman mobile home furnace needs repair
if you know what the flame sensor is try gently cleaning it with sandpaper they get gummed up sometimes and don't sense the piolet flame, if they don;t see a piolet it will not allow it to kick the gas on
Posted on Oct 10, 2009
  • 3238 Answers
SOURCE: My evcon furnace will not lite... The igniter
Hi try the pressure switch jump it out see if this helps
Posted on Jan 28, 2010
  • 105 Answers
SOURCE: My furnace is in a 1994 manufactured home. It is
i think it is your fan because when it is supposed to come on (when hood is hot enough) it won't,...and when the gas valve doesn't get the o.k. from the fan that it is working, the unit will shut it self off so it doesn't over heat. Gas boilers and furnaces have alot of safety things like this,....see if the fan has an oiling place on it. I've seen control panels cause this too,....replace whatever is cheapest first. good luck
Posted on Jan 31, 2010
Testimonial: "Thank you very much for your response. That makes sense and narrows it down. I will keep an eye on it. The fan motor when running is quiet & smooth"
Pilot light wont light
Rita, Check the attached links,instruction and guides to trouble shoot pilot light, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Gas Heater Pilot Light Troubleshooting
What to Do if Gas Furnace Pilot Light Won Stay Lit DoItYourself com
Furnace Won Ignite Why and What to Do
Aug 03, 2016 | Heating & Cooling
Colman gas furnace wont light
Is it natural gas or propane? If propane, make sure you are not out of gas. Does it have electronic ignition or a manual pilot? if pilot, make sure the pilot flame is still lit and the control knob is turned to the "On" position. If it has electronic ignition, shut off the power to the furnace and then turn it back on and see if resets and lights.
Feb 16, 2015 | Coleman 7990-319p Evcon Gas Furnace...
Why wont furnace light past the thermol coupler
There is really not enough information here to go on. If this furnace has a thermocoupling, the pilot will need to be lit manually. Follow the manufacturers lighting instructions carefully. If it still will not light you may have a dirty pilot assembly or a defective gas valve. Modern furnaces do not use a thermocoupling. There is no standing pilot light. Each time the furnace needs to be lit it will be done electronically. Many reasons why it wont light in this case. Safety control could be preventing it from lighting for safety reasons. A bad ignitor, ignition module, circuit board, gas valve, pressure switch, gas supply, induced draft motor, blocked or restricted flue pipe, cracked heat exchanger, dirty flame sensor, ect. ect. ect.
Oct 07, 2014 | Coleman 7990-319p Evcon Gas Furnace...
Coleman evcon furnace
For sensor if you mean thermocouple that sits in the pilot light I say this is usually the problem. The thermocouple needs to heat up to a preset temp before it will allow the gas to remain on. Does the pilot light stay on? If so make sure you turn the gas knob to on from pilot/light
Oct 15, 2013 | Heating & Cooling
Lennox furnace model G11Q3-110 v.2 burners light but go out before fan comes on
Troubleshoot an ignition problem on a Lennox gas furnace ...
? 2:44
https://www.youtube.com/watch?v=yXIxgzwMkPs
Nov 17, 2012 - Uploaded by grayfurnaceman
This furnace should light its pilot with a spark then the pilot proves its on ... Troubleshoot an ignition problem on a Lennox gasfurnace .... Pilot and no inducer but is the same model as that great video! ... You probably have dirty burners. ... How do you know spark module is not sending 24 volts to mv and pv ...
Lennox Furnace Model G11Q3-82-2 - RepairClinic.com
Nov 19, 2012 | Heating & Cooling
When I tried to light my furnace, the electrical wires from the thermostat don't spark all the time, therefore my furnace won't stay lighted. What can I do to fix this?
Is this an older furnace where you have a pilot light? Are you saying the pilot light will not stay lit? If thats the case then likely you need a new thermal couple. That is what the pilot light keeps hot while it stays lit. It is a safety device that is there so your furnace will not come on if there is no pilot light present. Very common. Hardware store item. Need Furnace's make and model #'s.
If this is an electronically controlled furnace, you will need a service call.
Jan 13, 2012 | Heating & Cooling
Pilot won't stay lit on furnace
Is that pilot automatic? If so then a quick easy fix for this is to located the sensor and replace it or clean it up with sand paper. After ignition the control is looking for verification of ignition from that sensor. How to videos
Sep 30, 2011 | Heating & Cooling
Feb 09, 2009 | Coleman Propane Forced Air Heater...
Not getting any fire
Can you give us a make and model number?
Nov 11, 2007 | Heating & Cooling
Tools & Hardware - Others Logo
446 people viewed this question
Top Coleman Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Coleman Tool and Hardware - Other Expert? Answer questions, earn points and help others
