Problem with my pc toshiba 1045
Hi there i still can get my pc started...my pc is now askin me for WINDOWS ROOTSYSTEM32/NTOSKRNL.EXE. but i don't know how to do it at this point. i need some help..thanks!!
Hai,
You have insert windows XP os cd after change the booting device and run the repair optipon after it will getting ready
Regards
Veeramani.G
Posted on Feb 19, 2009
How can i reinstall the ntoskrnl.exe when it is corrupt
Assuming a couple of things:
1. Your OS is Windows XP
2. This is the error message you are getting -
"Windows NT could not start because the following file is missing or corrupt:
Winnt_root\System32\Ntoskrnl.exe
Please re-install a copy of the above file."
To reinstall notskrnl.exe, do this:
  • Start the computer by using your Windows XP CD-ROM. Press any key to boot from the CD.
  • After the setup files are finished loading press R to repair using Recovery Console.
  • When you are in the recovery console, select the installation to log on to (usually number 1), and then press ENTER.
  • Login to the Administrator account by typing the password for this account, and then press ENTER.
  • At the recovery console command prompt, type the following command, and then press ENTER:
    For Uni-Processor systems: expand <cd-drive>:\i386\ntoskrnl.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exe
    For Multi-Processor systems:expand <cd-drive>:\i386\ntkrnlmp.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exe
    Note In these two commands, the <cd-drive> placeholder represents the drive letter of your CD drive, and the <hd-drive> placeholder represents the drive letter of the hard disk on which windows is installed.
  • If you receive a prompt to overwrite the file, press Y.
  • Type exit, and press ENTER at the command prompt.
  • You should now be able to boot up properly.
  • Oct 14, 2013 | Dell LATITUDE Computers & Internet
    My ntoskrnl.exe file is missing or corrupt
    To repair missing system file/s orcorrupted system file/s, boot up with the Windows installation CD then -Press R to repair wheninstructed.Press 1 or Enter to repairthe C:\Windows folder.Then type chkdsk /r and then press Enter.The repair process willtake quite a long time.
    May 23, 2012 | Toshiba Satellite A135-S4527 Notebook
    Windows root system32 ntoskrnl.exe.
    this might help you out...
    http://www.computerhope.com/issues/ch000646.htm
    Apr 02, 2010 | Microsoft Windows Vista Home Basic Edition...
    <windows root>\system32\ntoskrnl.exe.
    If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
    1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
    2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
    3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
    4. Select the operating system you wish to fix, and then enter the administrator password.
    5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
    6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
    7. Type exit to reboot the computer.
    Feb 11, 2010 | ASUS MPM1 (ASS5200) PC Notebook
    WINDOWS COULD NOT START BECAUSE THE FOLLING FILE IS MISSING OR CURRUPT:WINDOWS ROOTSYSTEM32 toskrn1.exe.how to re-install a copy if when the recovery files only gets to 39% and then freezes.I started by...
    I think your system window is corrept(window toskrn1.exe file is currept).if u have a window auto-run CD,please insurt the CD in CD drive and run the window setup and follow the instruction..
    This is helpful to you.
    Thanks,
    Dec 01, 2009 | Gateway GT5056 PC Desktop
    Will not boot, error message
    Hello
    Im sorry to hear about your luck. Basically this error message is letting you know that one of your important windows system files is corrupt or missing.
    Problem is every solution requires you to use a cd. Does the PC have USB drives ?
    Oct 18, 2009 | Computers & Internet
    Problem with a corrupt system32\stoskrnl.exe
    check out the article given below to view the detailed information to troubleshoot the issue:
    http://support.microsoft.com/kb/314477
    Oct 17, 2009 | Toshiba Satellite A35-S159 Notebook
    <Windows root>\system32\ntoskrnl.exe.
    Do you have a Windows CD that came with your computer? If so do you know how to boot from it by inserting it into the drive and then pressing F12 just after you switch on your PC? If you can do this then you could try the "repair" option from Windows Setup, this might fix your missing PC problem.
    May 17, 2009 | Compaq Presario 700 470024-192 Notebook
    Blue screen - kmode exception not handled - ntoskrnl.exe
    Did you install anything on your computer right before this happend to you??? Usually when this Dreaded Blue Screen comes up its a hardware issue, You may have installed Memory, USB, ECT... check that out and remove some of your memory first and see if that helps you out any. try also a F`12 or F8 start. see if that helps you out any, Get back to me if you have any other Questions Thanks Bear001
    Jun 21, 2008 | IBM Think Centre A50 P4 (841923u) Network...
    I feel some program running in the background is causing the problem.
    Try using msconfig and disabling unneeded softwares from startup. Then restart the PC and try to shut it down check.
    Let me know what happens.
    May 01, 2008 | Compaq Evo D500 PC Desktop
    Computers & Internet Logo
    57 people viewed this question
    David Payne
    David Payne
