Question about Kodak EasyShare Z612 Digital Camera
When I inset my memory card into my camera it reads memory card requires formatting. What does this mean? New memory card causes prompt to format card but camera does not complete formatting successfully. Kodak EasyShare Z612. SanDisk HC 8GB memory card.
    Genius:
  • 1,234 Answers
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Posted on Aug 27, 2010
    When i turn on my camera it says the memory card needs formatting i follow the instructions but it doesnt work and keeps saying to format the memory card. this happens over and over and i cannot take...
    To understand the photo loss situation, consider a scenario: You format a memory card in Digital Camera, and start to capture some pictures. However, while capturing pictures, your camera shuts down due to low battery. Now, after recharging battery, when you try to access those photograph on the card, you receive the following error message on camera screen:
    The Card requires formatting: Additionally, the camera is unable to capture any new photographs.
    The main cause for the above error message is corruption of memory card due to conking of battery while a read/write operation was running.
    These memory card needs to be formatted before you save any new pictures. It is always a good practice to take backup of card and format it before use. This enables you to fight with any damage done to the memory card and to erase the old data saved on the card. However, the probability of card getting corrupted again (after you have saved new data) still exists.
    First try formating with an external SD Card reader connected at PC and test it.
    Oct 13, 2011 | Kodak EasyShare C143 Digital Camera
    Just purchased new Toshiba SDHC 8 GB memory card to use in Kodak Easy Share C743 digital camera. Put disk in camera prompt says "Memory Card requires formatting"...press continue, and go to formatting and...
    No. Can you get into the camera menu when you turn the camera on? If so, go to "format" by way of the menu rather than clicking on continue. Also, be sure the slide switch on the side of the card is in the unlocked position.
    Sep 01, 2010 | Kodak EasyShare V550 Digital Camera
    After inserting the new SanDisk, SDHC Card, 8GB the camera prompts "Memory card requires formatting", press continue; warms that formatting will delete everything on memory card; pres continue;...
    First thing; check owner's manual and USA distributor, make absolutely sure that this camera is able to read/write to a 8GB card!
    If so, put that card into your computer, directly into appropriate slot or through a "reader" and the USB port. If computer runs Windows, access My Computer, click on external memory device, and RIGHT CLICK. You will get a box which offers to format the card. You can rename the card at the same time. The computer's format routine is stronger that the one in the camera. If problem still happens, consult distributor. May be fixable with a cable from camera to USB port, you download new software from distributor. Follow their instructions EXACTLY.
    May 14, 2010 | Kodak EasyShare Z650 Digital Camera
    We insert a memory chip into our Kodak EasyShare C190 camera. The read-out informs us that the memory card requires formatting. We click on "OK." The camera goes into a "formatting" mode, then informs us...
    Your camera is only supporting SD/MMC Cards (up to 2 GB) and KODAK SDHC Cards (up to 8 GB).
    The card that you currently have might be faulty. Please try another card.
    You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
    Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
    Jan 04, 2010 | Kodak Easyshare C190 12MP Digital Camera...
    When i turn the camera on....it saids memory card requires formatting. then continues to say formatting will delete everything on memory card. i press continue and nothing happens. goes back to say memory...
    Use a computer with memory card reader, and read the card using a computer.
    If the computer says the same and does not read the card, then the pictures inside the card are usually lost.
    If computer instead does read the card, then transfer all picture on computer using the memory card reader, and format the card using complete formatting.
    If you need to use the camera tonight, then buy a spare memory card.
    If the camera returns same error on different card, then you may have a faulty memory card slot, but that is quite uncommon.
    Regards
    Jun 18, 2009 | Kodak EasyShare C875 Digital Camera
    When I inset my memory card into my camera it reads memory card requires formatting. What does this mean? used several memory cards they all say the memory needs formatting, i'm screwed
    if you used already different kinds of memory and it has the same problem and no changes happen.
    i think the probem is in your camera maybe you can bring your unit to a service center and try to ask them to reformat or reprogram it for you.
    thanks,
    May 30, 2009 | Sony Alpha DSLR-A100 Digital Camera
    I cannot format my brand new memory card in my Kodak Easyshare.
    The I would have to say bad card. Do you have another to try?
    May 11, 2009 | Kodak EasyShare C360 Digital Camera
    New memory card will not format
    You are probably using a 4 gigabyte memory card and your camera will only support a 2 gigabyte card. Get the right card and it will format properly.
    Larry
    Mar 23, 2009 | Kodak EasyShare V550 Digital Camera
    This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
    Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
    Kodak EasyShare Z612 Digital Camera Logo
    99 people viewed this question
    Top Kodak Cameras Experts
    Tony
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
