Question about Frigidaire FEQ332E Electric Dryer
Frigidaire blowing cold air no heat
No heat but drum turns check continuity on all switchs and element, turned out ok?
  • 547 Answers
Timer?
Posted on Feb 19, 2009
Vulcan ducted heating
Do a continuity test on the heating elements, and if they're good then do the same on the sequencers or contactors, whichever you have. The sequencers (or if you have contactors turn on the heating elements). All the fan does is blow air. It blows against the heating element to put out hot air. Either your sequencers/contactor or your heating element is defective.Wait,each sequencers is connected to a fuse.Check the sequencer fuse too. Find the sequencer/contactor wherever the wire feeding the heating element is coming from.
Aug 20, 2013 | Heating & Cooling
Frigidaire Model FEQB2152FE1. Start dryer and after 5 minutes "Ad" code; lights blink dryer drum turns, but does not dry clothes
Check that exhaust air vent is venting air. If not, clear vent and retry.
Check that heating element is heating. if not, check overheat switch for continuity with power unplugged. If you don't have continuity get new switch. If it reads ontinuity then suspect the heating element.
Aug 20, 2013 | Maytag Clothes Dryer Almond Timer Knob...
My dryer is only blowing cold air
It could be the heating element, a safety limit, a control problem, or an electrical problem. A heating coil is used to warm the clothes as they get tossed gently inside the drum. A blower mounted on the motor pulls air through the heating element into the drum and out the exhaust. The element gets old and brittle with use and eventually needs replacement. That is what you check first.f1447b5.jpg On gas dryers vibration and age will cause the igniter to crumble and fail.76b07e9.jpg If it turns out the element is fine then one of the safety's might be blown. These safety's are set to a certain temperature2d03504.jpg
for the dryer to operate safely. The drum temp control (7) for cotton is 160f. A limit on the heater housing is 250f.(3) If it fails another smaller limit is mounted nearby that blows at 300f.(1) If that temp exceeds 350f a duct fuse mounted on the blower housing opens and kills most dryers.(5) On gas dryers the duct fuse will kill the gas assembly but the dryer will still run. If all of those safetys are good the timer could be the problem. The timer has a terminal on it that runs down to the heating element. If you suspect it is bad you can check it with a meter. That leg of the timer should have continuity with other terminals on the timer at different spots on the timer. ee50c38.jpgTurning the timer and checking for continuity will give a clue. If you cannot get continuity with any other terminal on the timer at any position on the dial then you have a burned contact in the timer. If that turns out to be good, you would need to inspect the electrical outlet for proper power to the machine.284caa2.jpg On American models the motor runs on 120 volts but the heating element must have 240 volts. If you have more questions just post a comment. Good luck on repairing your machine. I have some repair photos: HERE
Jun 17, 2010 | Kenmore Dryers
It blows air but it is cold it does not get hot had thermail limi
Depending on the type and make or model of dryer check drum turns,filters are not blocked or condenser is not blocked.then if all ok it could be the safety thermostats or the heating element.
Hope this helps.
May 10, 2010 | Dryers
Ok got a GE DVL223EB1WW Insufficent Heat
Yes think so , what should happen is element heats up controlled by fan blowing cold air across it this then heats to whatever thermostat is set to switch at, which in turn controls heat level..Air is then exausted via hose to waste unless its a condenser drier which then turns the steam back to water / which is collected in a waste condesate drum..hope this is helpful...
Nov 19, 2009 | GE DVL223EBWW Electric Dryer
Frigidaire FEQ332ES-It starts out ok, then trips the breaker, then no heat, continues to run but only blows cold air
sounds like your heat coil element is shorted, this coil is in the inside behind the drum..
replace coil and this will solve your problem, the coils break , you get no heat but voltage goes to heat elem that is shorted, trips breaker
Sep 16, 2009 | Frigidaire FEQ332E Electric Dryer
Tumble dryer running but only blowing cold air
If your dryer is turning then things are not so bad. If a dryer is not heating then you need to check a few things.
First disconnect the power to the unit. Then you must check the heating element and the limits which are mounted on the heating box.
Remove one lead from the element and check for continuity thru the element. If you have continuity then check the limit by measuring for continuity, again you must remove one of the leads. This should solve your problem
Sep 15, 2009 | Dryers
The dryer only blow out cold air.
When I turn the dryer on, only cold air blows out. There's no heat. I cleaned out the vents? What do you think is my problem> Thank you very much. K
Oct 18, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool dryer LER5656EZ3 no heat
If the heating element read 0 ohms with the wires removed, you have an open heating element, (should be around 10 ohms) replace heating element and you should be ready to rock.
Sep 13, 2008 | Dryers
Frigidaire FEQ332E Electric Dryer Logo
180 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
