Question about Sharp Office Equipment & Supplies
Looking for an owners manual for fax machine fo-1700r
Need to take out old owners name on paper header and add ours
eagle338
  • 4889 Answers
SOURCE: Canon fax/copier
1 Data Registation
2 Set
3 Set (when User Settings displayed..includes date, name etc.,)
4 Time & Date
5 Set etc..
Posted on Nov 15, 2007
checkitright
  • 1362 Answers
SOURCE: panafax uf585
here is the manual
http://service.us.panasonic.com/OPERMANPDF/UF585.PDF
Posted on Feb 15, 2008
  • 2072 Answers
SOURCE: Hard reset to clear paper jam error
Most likely you need to carefully go through the paper path and look for the locations of all the paper path sensors.
You probably have one stuck on the frame or a spring came off the flag and its not actuating properly.
Follow the paper path carefully from the feed rolls out to the exit. I am sure you will find a sensor not operating properly.
Actuate every one and make sure they have no resistance and that they return to the proper position.
Posted on Mar 01, 2008
robotek
  • 1512 Answers
SOURCE: owners manual
Hi tedkollias40
Here is your fax machines manual
Thankyou for using FixYa, a FixYa rating would be great for tracking this down for you. Cheers :)
regards
robotek
Posted on May 08, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Brother Fax Machine 4100 - check or remove original message
Sounds like something is going on with your ADF. It should be looked at by a technician.
Posted on Jun 13, 2008
How do I change the company header on this fax machine?
with function key go to entry mode and own number set .change name and number
May 20, 2010 | Sharp FO 5700 Plain Paper Laser Fax
How can i chanche de fax number dat is printed. That number is not good, i wil chanche this
you need to go into the menu and look for settings fax the n look for the fax ID here you can change the number and the header the header is the name you want printed on top of the page ie your company name.. you can find the sections by looking on the right hand side of the display and you should see a button called reports here you can print off the section rep[ort which tells you where to find the settings in teh menu
Sep 29, 2009 | Canon FAX-L350 Plain Paper Laser
Fax header Ricoh 1013F
GEEZ, the 1013f, I beleive you have to access the user tools buttom, it is on the left side of the control panel. From there slect fax features, then select general/settins adjust, then program fax information, then slect fax header, from there you will use th alpha keys on the left side that double as the one touch keys. When you are done select ok!
http://copierquestions.websitetoolbox.com/
Aug 13, 2009 | Ricoh Aficio 1013F Copier
Need operation manual for Sharp FO-1460. Can
Turn your fax off then back on. If the problem persist try a memory clear. Press function 9 * 8 # 7 then press start , then keep pressing your # key until you see memory clear then press start. You will lose #'s that are stored. If the problem still persist try another phone line(analog line). This problem will not be in your owners manual, but if you still need one I would do a google search.
May 17, 2009 | Sharp FO 1460 Plain Paper Thermal transfer...
I need to change the company's name on the printout page when someone receives it.
The 6600 opeations are very similar to the 6700. Go to the Sharp site at
http://www.sharpusa.com/products/TypeManuals/0,1083,23,00.html
download the FO-6700 manual, follow the instructions for setting the sender name and phone number beginning on page 29 of the manual.
Please make sure to rate this solution.
May 15, 2009 | Sharp FO 6600 Plain Paper Laser Fax
Add and delete names and numbers from broadcast
How do I change the name and phone # on my fax machine. Sharp UX-510
Nov 25, 2008 | Sharp UX 510 Plain Paper Thermal transfer...
Need to change name and number
Press the MENU button and press 7, then 2 on the numbers keypad. You can then use the keypad to change the fax header. Press the keypad numbers corresponding to the letters you need. It will cycle through lower case first, then upper case. Press the RIGHT arrow button to advance one space between letters.
Jul 18, 2008 | HP 920 Plain Paper Fax
Problem
Usually, you can just leave the thing unplugged- from the power supply- for a while and clear its memory. There may also be a reset button on the machine, look for it near where the ports/connectors are, and hold it down- most devices will flash a light or beep if the reset is done properly.
May 23, 2007 | Sharp FO DC600 Plain Paper Laser Fax
Ricoh Aficio 5000L Fax Printer-Adding names to Group name
On every fax i've worked on, you cannot edit groups. You have to delete the group and start over.
Apr 17, 2007 | Ricoh FAX5000L Plain Paper Laser
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
