Question about Western Digital 160GB Caviar ATA-100 Internal s - 2MB Cache (5-pack) 160 GB EIDE Hard Drive
Upgrading HDD From 40GB To 160 GB
Have a Emachines T1450 With 40GB HDD, 256mb RAM, 64MB VGA Card, CD RW/DVD ROM Drive, I Have Installed 2X 512MB Ram Modules, GeForce FX5200 128MB Graphics card, but when upgrading HDD to 160 GB WD Caviar PATA (40GB PATA Originally Installed) I can format, Partition and install windows via Windows XP CD, when install finnishes and pc tries to boot from HDD error message reads ntldr is missing press ctrl-alt-del, (Which Doesn't work, holding down power button is all that restarts), I have looked around for solutions and have tried making a floppy with 'ntldr' 'boot.ini' and 'ntdetect.com' and copied it to C: root directory using recovery console, but to no avail, I know it is something to do with high capacity PATA HDD's but I would really like to sort this if possible, I have Western Digital Data Lifeguard Tools but since I cannot get into Windows it is useless, This Emachines PC has a 1.5ghz processor and I have tried the 160 GB on another PC and all is fine, I have even installed another 40GB HDD on it and that works fine too, Please if anyone could help I would be greatful, and of course have learned something in the process, I have been formatting the HDD NTFS (The slow option) and have had no luck (6 Times Tried) Any Thoughts Welcome. RGK!
  • realgonek909 Feb 23, 2009
    This post has been resolved here is the link to the problem being resolved by the great techsperts over at cdfreaks.com, fast responses to my problems, thanks again to themhttp://club.cdfreaks.com/f7/160gb-hdd-wd...
    CDFreaks rule!!!!
    RGK
  • 12,061 Answers
  1. Use the Windows XP Setup disks to restart the computer, or use the Windows XP CD-ROM to restart the computer.
  2. At the Welcome to Setup screen, press R to repair the Windows XP installation.
  3. Press C to repair the Windows XP installation by using the Recovery Console.
  4. Type the number that corresponds to the Windows installation that you want to repair, and then press ENTER. For example, type 1, and then press ENTER.
  5. Type the Administrator password, and then press ENTER.
  6. Type map, and then press ENTER. Note the drive letter that is assigned to the CD-ROM drive that contains the Windows XP CD-ROM.
  7. Type the following commands, pressing ENTER after you type each one, where drive is the drive letter that you typed in step 4 of "Method 2: Use the Recovery Console," of this article: copy drive:\i386\ntldr c:\
    copy drive:\i386\ntdetect.com c:\If you are prompted to overwrite the file, type y, and then press ENTER.
Posted on Jan 24, 2010
E-Machines T2798 specs
Key FeaturesOptical Drive TypeDVD-ROM • DVD Burner • CD-ROM • CD BurnerForm Factor DesktopProcessorIntel Celeron 2.7 GHzOperating System Microsoft Windows XP Home EditionProcessorProcessor ManufacturerIntelProcessor Type Intel CeleronProcessor Speed 2.7 GHzMemoryInstalled RAM 512 MBCD / DVDOptical Drive Type CD-RW/DVD-ROM (Combo)MiscellaneousFamily LineeMachines TProduct MPNMPNT2798
Mar 06, 2012 | E-Machines eMachines Desktop PC
I have been given a Toshiba MK 4025GAS laptop, it has 240 MB of RAM. How much more RAM can I put on it?
click start right click on my computer select properties you should how much ram you have installed and how much available it looks like it is capable of 4GB of ram remember when adding more ram try to keep the same brand/type as some motherboards will only work with the one type of ram together and always place the larger ram closest to the cpu central processing unit
Toshiba Mk4025gas Pm ... Shipping: FREE Total: $98.72 Memory Specifications Module Size(s): 2x4GB Type
CPU
Intel Celeron M 370 1.50GHz BIOS Phoenix BIOS. Press F2 to enter Chipset SiS 661 Memory 512MB PC2700 DDR SODIMM (2 memory slots. Max 2GB) ** Hard Drive 40GB Toshiba MK4025GAS CD Drive Philips DVD+-RW SDVD 8441 Screen 14" TFT (Native Res.1024x768) Video Card SiS 661FX (64MB shared) Sound Card Realtek AC'97 audio Network Card SiS 900 integrated fast ethernet
Atheros AR5BMB5 Wireless LAN * Modem Agere systems AC'97 modem Ports 1x Headphone
1x Microphone
1x PC Card
4x USB 2.0
1x Modem
1x LAN
1x VGA
1x S-Video (TV-Out) Touchpad Synaptics Touchpad Battery SQU-504 (11.1v 4400mAh) Dimensions 33 x 314 x 258 (HxWxD in mm) Weight 2.3kg Made By Quanta LE1D
The full system specs are:
CPU: AMD Sempron LV 3000+ (1.8 GHz.)
RAM: 1 GB. DDR-333, Kingston
Chipset: ATI Radeon Xpress 200M (RS480M/SB450)
GPU: ATI Radeon Xpress 200M
HDD: Toshiba MK4025GAS (40 GB., IDE, 4200 RPM)
ODD: TSSTcorp Combo (DVD-ROM/CD-RW 8x24x24x24)
Other:
- Texas Instruments UltraMedia Card Reader PCI xx21/xx11
- Broadcom 802.11g Wireless LAN
OS: Windows 7 Ultimate (32 bits, obviously
as you can see there is a contradiction in how much ram but if its a windows 7 it will need a minimum of 2 gb of ram but it could use 4gb
hope this helps
Jun 17, 2011 | Toshiba MK4025GAS (c99529) 40 GB Hard...
Can't watch blue ray movies on my acer aspire model 5334
Taken from the acer support website.
" Optical media drive 8X DVD-Super Multi double-layer drive:
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM
  • Write: 24X CD-R, 16X CD-RW, 8X DVD-R, 8X DVD+R, 4X DVD-R DL (double-layer), 4X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
This model of computer does not have a blu-ray drive unless you got a third party upgrade. In this case, you will need to track down special drivers, which can best be done by whomever sold you the drive.
Jun 10, 2011 | Acer Aspire One PC Notebook
Sir i am using acer 4736z i got problem with my dvd driver when i am inserting blank dvd for writing operation it shwos 0 bytes used free sapce 0 bytes not able to write data so what to do pls help me...
you have to make sure you are using the correct format for your drive i.e (+/-)
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 8X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 8X DVD-RW, 8X DVD+RW, 5X DVD-RAM, 4X BD-ROM, 4X BD-R, 2X BD-RE, 4X BD-ROM DL (double-layer), 4X BD-R DL (double-layer), 2X BD-RE DL (double-layer)
  • Write: 24X CD-R, 16X CD-RW, 8X DVD-R, 8X DVD+R, 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM, 4X DVD+R DL (double-layer), 4X DVD-R DL (double-layer)
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 8X DVD-RW, 8X DVD+RW, 5X DVD-RAM
  • Write: 24X CD-R, 24X CD-RW, 8X DVD-R, 8X DVD+R, 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
Apr 09, 2011 | Acer Computers & Internet
Can I Play gta IV/4 on my pc? Specs Ar As Follow: DELL PRECISION 650 With: 2X Seprate Intel Xenon CPU's @ 2.40Ghz Each (4.80Ghz Tot) 1.50GB RAM (Memory) 80GB IDE Primary, 40Gb IDE Seccondary, 40GB...
Minimum System Requirements
  • OS: Windows Vista - Service Pack 1 / XP - Service Pack 3
  • Processor: Intel Core 2 Duo 1.8Ghz, AMD Athlon X2 64 2.4Ghz
  • Memory: 1.5GB, 16GB Free Hard Drive Space
  • Video Card: 256MB NVIDIA 7900 / 256MB ATI X1900
Recommended System Requirements
  • Processor: Intel Core 2 Quad 2.4Ghz, AMD Phenom X3 2.1Ghz
  • Memory: 2 GB (Windows XP) 2.5 GB (Windows Vista)
  • 18 GB Free Hard Drive Space
  • Video Card: 512MB NVIDIA 8600 / 512MB ATI 3870
Source :- IGN PC
this is what it says on the box...so if you dont have these specs..forgett it!!
Jun 15, 2010 | Rockstar Games Grand Theft Auto™ IV for...
Gateway mx3222b laptop ram upgrade problem
your computer does not support 1GB memory sticks. The max memory for that system is 1GB which would be 2 sticks configured as 512MB
see below for the specs (i bold, italics and underlined the main part)
Processor Intel® Celeron® M Processor 370
1 MB L2 Cache | 1.50 GHz | 400 MHz FSB Display Screen 14-inch Widescreen Ultrabright™ WXGA TFT Chipset Via VN800 Memory 256 MB DDR2 (1 × 256 MB) SODIMM
Total slots: 1 DDR2 slot | Available slots: 0 DDR2 slots
Expandable to 1 GB Video S3 Graphics UniChrome™ Pro IGP
Up to 64 MB shared VRAM Audio AC'97 2.3 Compliant Hard drive 40-GB 4200 RPM hard drive Optical drive DVD +/- RW Multi-Format Double Layer
Write maximum: 8X DVD+/-R, 6X DVD-RW, 8X DVD+RW, 2X DVD-R DL, 2.4X DVD+R DL, 24X CD-R and 16X CD-RW discs
Read maximum: 24X CD-R/RW/ROM, 8X DVD-R/RW/ROM, 4X DVD+/-R DL, RAM discs Media Reader 4-in-1 Digital Media Manager
Secure Digital™, Memory Stick®, Memory Stick-Pro®, and MMC™ Modem 56K ITU V.92 ready fax/modem Network 10/100 Mbps built-in Ethernet
802.11g integrated wireless (up to 54 Mbps) Interfaces
  • 2 - USB 2.0 ports
  • 1 - VGA external connector
  • 1 - RJ11 (modem)
  • 1 - RJ45 (Ethernet LAN)
  • Microphone jack
  • Headphone jAck
Pointing device Touchpad with vertical scroll zone PCMCIA 1 - Type I or Type II; Card Bus Battery 6-cell Lithium-ion Dimensions 1.1 to 1.24-inches (H) × 13-inches (W) × 9.7-inches (D)
28 to 32 mm (H) × 330 mm (W) × 246 mm (D) Weight 5.01 pounds
  • 2 - USB 2.0 ports
  • 1 - RJ11 (modem)
  • Microphone jack
  • Headphone jAck
  • 2 - USB 2.0 ports
  • 1 - RJ11 (modem)
  • Microphone jack
  • Headphone jAck
Chipset Via VN800
Expandable to 1 GB
Interfaces •2 - USB 2.0 ports
•1 - VGA external connector
•1 - RJ11 (modem)
•1 - RJ45 (Ethernet LAN)
•Microphone jack
•Headphone jAck
Weight 5.01 pounds
Mar 03, 2010 | Gateway Computers & Internet
Need specs
Systemax Ascent KMA3500 Desktop
Processor :AMD Athlon 64 X2 2.3 GHz
Installed Memory :2 GB (DDR2 SDRAM)
Operating System :Microsoft Windows Vista Business
Video Output Interface :PCI Express
RAM :2 GB
Max Supported RAM :4 GB
Installed Video Memory :128 MB
Supported RAM Speeds :800 Mhz
Hard Drive :160 GB
Hard Drive Interface Serial ATA II
CD / DVD :CD-RW/DVD-ROM (Combo)
Graphic Processor NVIDIA GeForce 6100
Integrated Audio Realtek ALC833
Networking
Networking Type Integrated 10/100 Network Card
Dec 18, 2009 | Systemax Ascent PC Desktop
Could I upgrade my Gateway MT3707 160G hard drive?
You can upgrade your hdd as big as they make in 2.5 inch format. Just make sure you get a drive with the same format as your old drive or it will not work. Hope this helps.
Jun 16, 2009 | Computers & Internet
Three things not mentioned 1. Specs for Ram will any 172 pin ram work? 1. HDD type and specs for upgrade. 3. type of DVD drive used for upgrade
You need DDR SDRAM - 333.0 MHz - PC2700 (184 Pin)
The current is a CD-RW / DVD-ROM combo - Integrated, 24x (CD) / 8x (DVD-RW) / 2x (DVD-RAM) this is actually quite sufficient, most CD ROMS never burn at full speed anyway. If you really want more capabilities in my opinion it is much better to go to an external CD/DVD/BR burner, it will work faster and be a lot easier to install.
Current HHD - 40.0 GB - 4200 rpm IDE, you can go to 100 GB if you need to, get a 7200 RPM for more speed.
Jun 07, 2009 | JVC XV841 Notebook
DELL OptiPlex GX150 Upgrading
The fastest processor you can install in a GX150 is a Pentium III 1.13 Ghz processor.
The Socket 370 was a design used only for P3 processors.
Max RAM for that system is 512MB no way to upgrade past that.
If you paid $100 for a GX150, you paid way too much (You can buy a refurbished Dell Dimension C521 for $225 at their refurb site)
Jan 26, 2009 | Dell OptiPlex GX150 PC Desktop
Western Digital 160GB Caviar ATA-100 Internal s - 2MB Cache (5-pack) 160 GB EIDE Hard Drive Logo
241 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
