Question about Proscan 32LB30QD 32 in. LCD TV
I'm experencings a buzzing noise coming from the speaker when I turn on the tv....How can I get rid of this noise?
  • 1 more comment
  • Anonymous Feb 26, 2009
    This is the second problem with this tv. First one would not turn on out of the box. We returned it, now this one has a loud buzzing noise, too.
  • Christian73 Mar 02, 2009
    It has a buzzing noise coming from the speakers. it starts a few minutes after i turn the it on.
  • Anonymous Mar 08, 2009
    Annoying buzzing sound on mine too !!
    Any solutions ??
Give this a shot, it should fix the hum issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone.
Let me know if this works.
Posted on May 21, 2009
There is a loud buzzing sound, like a weed whacker trimming grass, coming out of the TV. It started suddenly when I turned it on 2 days ago; this has not happened before. How do you get rid of the...
U can't the buzzing noises are comming from the tv power supply board itself have some short of problems on it high voltage transformers parts,not easy to get rid of,must know how to troubleshoot and replaced electronic components parts to fixed it.The simpliest way just do a replacement of the whole power supply board,that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 18, 2011 | Soyo DYLTO37A 37 in. LCD Television
Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
Apr 07, 2010 | Vizio VW32L 32 in. LCD HDTV
Samsung 4663w rear projection tv loud buzzing
Hai,
Buzzing can be caused by a bad ballast, colorwheel, or cooling fan... Nothing else makes a noise, unless it's comming from you speaker.
Hope it Helped U!
Aug 04, 2009 | Samsung Televison & Video
Vizio speakers make a buzzing noise
The audio board on your 47" Vizio has gone bad. Replace that board will fix the problem.
Jan 21, 2009 | Vizio VO47L 47 in. LCD TV
Vizio 42'' HDTV flatscreen
The TV usually hums when the backlight setting is too low. So turning it up should get rid of the problem. To do this please follow these instructions:
1. Turn the TV on.
2. Press the Menu button on the remote, located right below the channel changing button.
3. Press the down direction button, located at the middle of the remote. Press that button until the backlight is highlighted.
4. Press the right direction button until the backlight is at 100.
5. Press the OK button and then the Exit button until you get back to your picture.
Oct 22, 2008 | Vizio GV42L 42 in. LCD Television
Vizio Speaker Making a Buzzing Noise
My 32" vizio I bought a week ago does the same things.
Buy an external sound system for the tv. Turn the speakers off in the TV menu. Hook the sound system up to the out speaker hookups on the tv.
You will not only have better found, you will fix the speaker buzz problem.
Feb 19, 2008 | Vizio L32 32 in. LCD HDTV
RCA 56 projection
Does the buzzing come from the speakers or the back...turn the volume down.. is it still there?
Nov 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Very loud fan or vibration noise
Listen from the back of the TV and locate the source of the noise. There may be fan with a bad bearing. The noise will lead you to it.
Nov 06, 2007 | Soyo Dymond DYLT037A Television
Proscan 32LB30QD 32 in. LCD TV Logo
387 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
