Home | RCA | F31317 31" TV | I plugged the cable wire
RCA F31317 31" TV
Problem for RCA F31317 31" TV
By johnlundgree on Feb 19, 2009
I plugged the cable wire into my RCA 31"guide plus F31317 model.2003 .....my color is bandedto the left and right and blue in the center.
Best Solution
posted on Feb 19, 2009
Very Helpful)
bestdarngood
Rank: Guru
Rating: 89%, 434 votes
Well, first to trouble shoot the easy parts
Try a different cable, and also try a different tv at that spot with that cable and see if either fixes the problem. If not then either the signal is bad or you most likely have a part in the tv needing replacement which requires more troubleshooting
Please post the results of the two tests first
Benjamin
Solution #2
Not Rated)
michtech
Rank: Guru
Rating: 88%, 93 votes
I don't know how this happened from what you've described but it sounds like the purity of the CRT (picture tube) has been affected by a magnetic field. The purity refers to the CRT's ability to light the correct phosphur dot at the right time. So, for example, if the picture was supposed to be all red, it would now have areas where the red dots were either not lit or the green and blue dots were being lit erroneously. Try disconnecting the cable from the TV. Unplug the TV and allow the set to cool down. When the TV has cooled down, plug it back in. When you turn it on, you'll hear the buzz of the TV's degausser circuit. ( de-magnetizer) This may return the picture to normal.
michtech
Solution #3
Not Rated)
rylee_smith
Rank: Guru  Televisions & Videos  Expert
Rating: 87%, 954 votes
Hi
Is there a cordless phone or a high voltage electrical device near the TV.If there is you need to remove that and plug it elsewhere.
Solution #4
Not Rated)
mohammed387
Rank: Wiz  Televisions & Videos  Expert
Rating: 77%, 851 votes
ple can briefly ur dought
Comments:
Feb 19, 2009
- There are two other types of video connectors left: composite and S-video. Both are analog connections, and neither is capable of carrying better than a standard definition signal. Composite uses a single RCA connector, which is usually colored yellow. The S-video connector is a round DIN plug (which gets its name from Deutsches Institut für Normung, a German standards body) with four connections.
Popular Solutions for RCA F31317 31" TV
Questions and Unsolved Problems for RCA F31317 31" TV
Do you recommend RCA F31317 31" TV?
Answer
Answer
My RCA Model F31317 has intermittent picture display. The sound works but the picture will cut out... (More)
Answer
my sat went out and during the reset process I lost picture. just snowy static screen. still plays... (More)
Answer
my tv will not recinize when a cable box is hooked up to it. it keeps asking for a G-link for the... (More)
Answer
picture on my rca f31317 seems darker than normal, have adjusted to the brightest setting. any... (More)
Answer
changes channel down on it own nonstop
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For RCA F31317 31" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
