Question about Nokia 6681 Cellular Phone
Nokia 6681 Restarts automatically
Sir my Nokia 6681 will restart automaically or Off totally when I am trying to start it again It cant start easily,when I tyies to start it again & again the it will start. mobile is restarting again and again automatically
  • 60 Answers
Type *#7370# and give phone security code. This is a soft format. If no result, go to a better mobile servicing center. Make a whole flash (mobile phones OS repair). Still have problem, change UM chip. Keep informing.
Posted on Feb 19, 2009
6085 Cellular Phone: dear sir i have nokia 6085 model. my problem is wh...
hai, try to reset your phone, set to orignal factory setting..some time this process take a few minute, make sure power of battery must be fully before you make this proses.
May 18, 2010 | Nokia 6085 Cellular Phone
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
Nokia 6681 UNLOCK CODE
dear u default code is 12345. u can try giving it. if not work then the way reinstall ur phone application.
Jul 27, 2009 | Nokia 6600
Nokia 5610 stops while booting
dear there is just problem in the button of start and plz let it chek..
May 25, 2009 | Nokia Cell Phones
Insert sim card
dear cheak your simcard if it s ok thne u need to chnage simdriver
Jul 24, 2008 | Nokia 6681 Cellular Phone
You phone sounds as if you need to have the firmware reflash and that will take care of the issue with the phone.
Take the phone to a mobile service center or a professional mobile technician.
Feb 09, 2008 | Cell Phones
How to prevent my nokia 3230 from restarting by itself?
it may be a virus infection . dial *7370# and *7780# to fromrt ur phone evey time it restars and formt itself when u enetr the code . remove ur memory card first . many viruses take esidence in mmc
Dec 19, 2007 | Nokia 6681 Cellular Phone
Nokia 6681 Cellular Phone Logo
145 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
