Wireless or Hard wired ethernet ?
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc You only need to check the BIOS if you cant install the driver Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"ima Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all of your internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 or you could download one cnetdownload.com on the homepage you will see a search bar type in the ethernet controller freeware you want/need Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html http://download.cnet.com/network-drivers/3150-2112_4-0-1-4.html i device arrows key scroll to nstalled.
