have dish receiver 510, channels i need are on transponder 21, reciever changes to transponder 4 and there is nothing!!! this is on satellite 129 only, 110 and 119 work fine
Comments:
Feb 24, 2009
- thanks for your response, the receiver was the problem
Rank: Guru
DISH Network Staff
Rating: 88%, 221 votes
Donna,
I am sorry to hear of your troubles. I am assuming you have another receiver in the house that is an HD receiver as the 510 is not and it would not make any sense for you to have the 129 orbital without it. If you go to the other receiver and are able to get transponder 21 on the 129 bird then the issue lies in either the cabling, connectors, barrels and or wall plate, or the 510 itself. Assuming you were good to go with the hi def receiver move it to the 510 location and see if you are able to still p/u the 21 transponder. If so, the 510 is bad and needs to be replaced. If not the problem lies in the aforementioned areas. if yoou are unable to get the 21 transponder on the hi def receiver also then more than likely the dish needs to be repeaked. If I can be of more assistance let me know. Thanks for using Fix Ya.
my sony tv model KV-36XBR400 randomly turns off. When this happens, a red light next to the word...
(More)
my sony tv model KV-36XBR400 randomly turns off. When this happens, a red light next to the word STANDBY lights up. Whats wrong with it?
This dvr keeps showing either dui or du1. Help . I try to set the box to 1080 and it keeps...
(More)
This dvr keeps showing either dui or du1. Help . I try to set the box to 1080 and it keeps defaulting to 480 evry time I turn off and turn back on,
master tv makes a horrible noise for 2-3 mins and when going to and from commercials. 36" tube...
(More)
master tv makes a horrible noise for 2-3 mins and when going to and from commercials. 36" tube with the standard DVR receiver. Tech says it is an electrical problem. Have tried all troubleshooting suggestions.what do you think? also having some audio issued with the HD tv in living room. tech says that is also electrical
TV showed "Problem Detected" with a possible solution of unplugging my unit for 60 secs....
(More)
TV showed "Problem Detected" with a possible solution of unplugging my unit for 60 secs. and allowing it to reboot. I do this routinely (Once a mo), but did it again. This time it cleared ALL recorded items (including protected items) I had 43 hours available for recording. It also Cleared all scheduled timers, and now will not allow me to record if I try to use "Create A timer" or "Create a Scedule". Is my harddrive fried?? (I've had problems with it locking up for about the last 12 months) Dish Network DVR
