Question about ASUS A8S-X Motherboard
Not message, not beep, not at all, this motherboard a8s-x is new, have connect the memory, cpu, fan, video card, keyboard, el power supply is of 400 watts,the fan work.
    President:
  • 1,865 Answers
Asus motherboards are garbage, the board is warrantied for 3 years. Asus warranty dept. has earned a reputation of damaging products that are returned under warranty, and then refusing to repair their junk. Take pictures of your motherboard before sending it Asus for repairs.
Posted on Jun 29, 2009
    Problem Solver:
Who have a solution for this problem of my asus a8s-x not boot up, not beep, not message, have connect the memory, cpu, fan , video card, keyborad, this is new, only the fan work.
Thanks
Posted on Feb 19, 2009
3 beeps at Startup no video
The beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
make sure that your RAM modules and Cmos battery are securely seated
on some motherboards Cmos batteries are soldered in
Common beep codes include not having a monitor or keyboard properly connected; not having a CPU fan connected, or not attaching internal power cables to the video card.
This black-screen-and-beeping issue is most common with newly-assembled computers.
Check external cables to make sure they're properly connected.
The most important external connections to check are the monitor's signal cable and the keyboard.
If your monitor cable looks damaged or kinked, try replacing it with a spare.
If your keyboard's cable looks frayed, try a spare keyboard.
Also, a PS/2 keyboard plug (round, with holes in it, about the diameter of a finger) is often color-coded purple.
If you have plugged it into the green port in the back of the computer (for PS/2 mice) switch it to the other one.
If there is no color coding, the proper port should have a small, embossed icon of a keyboard on the back of the computer.
If it does not, refer to your motherboard manual for the correct port. If all else fails, try a spare keyboard, preferably USB (Universal Serial Bus), which can be plugged into any USB port on the back of the computer.
Check for additional motherboard power connections.
Yours may require multiple cables attached from the power supply.
There is the standard wide plug, which you know is connected properly because your motherboard is beeping.
However, there may also be an additional, four-pin cable that connects elsewhere on the motherboard.
Check the board's manual to make sure it has all the power connections it needs.
Check your internal cables.
Make sure that the CPU fan is plugged into the motherboard header nearby.
Without that, the CPU fan will not spin, and the motherboard may detect this lack of connection and produce a beep code.
Your video card also may have one or two internal power plugs that need to be attached to the power supply's cables.
These cables have unique ends on them, similar in shape to a USB plug.
Refer to the case or video card documentation if need be.
If those cables are not attached, your motherboard may refuse to boot the system.
Your video card may be faulty.
If this is a new card, it may have arrived to you broken, in which case you will probably need to request an RMA (Return to Manufacturer Authorization) to receive a replacement.
If this card was previously working for you in this system, you can contact its manufacturer yourself to receive a replacement, if the device is still under warranty.
Hope this helps
Oct 28, 2012 | Computers & Internet
Computer has alarm sound when turned on and screen is black
  • INSTRUCTIONS :-
  • 1
    Refer to your motherboard manual, since the motherboard is the beeping device. These beeps are like Morse code, and each "beep code" is explained in the manual. Common beep codes include not having a monitor or keyboard properly connected; not having a CPU fan connected, or not attaching internal power cables to the video card. This black-screen-and-beeping issue is most common with newly-assembled computers.
  • 2
    Check external cables to make sure they're properly connected. The most important external connections to check are the monitor's signal cable and the keyboard. If your monitor cable looks damaged or kinked, try replacing it with a spare. If your keyboard's cable looks frayed, try a spare keyboard.
    Also, a PS/2 keyboard plug (round, with holes in it, about the diameter of a finger) is often color-coded purple. If you have plugged it into the green port in the back of the computer (for PS/2 mice) switch it to the other one. If there is no color coding, the proper port should have a small, embossed icon of a keyboard on the back of the computer. If it does not, refer to your motherboard manual for the correct port. If all else fails, try a spare keyboard, preferably USB (Universal Serial Bus), which can be plugged into any USB port on the back of the computer.
    • 3
      Check for additional motherboard power connections. Yours may require multiple cables attached from the power supply. There is the standard wide plug, which you know is connected properly because your motherboard is beeping. However, there may also be an additional, four-pin cable that connects elsewhere on the motherboard. Check the board's manual to make sure it has all the power connections it needs.
    • 4
      Check your internal cables. Make sure that the CPU fan is plugged into the motherboard header nearby. Without that, the CPU fan will not spin, and the motherboard may detect this lack of connection and produce a beep code. Your video card also may have one or two internal power plugs that need to be attached to the power supply's cables. These cables have unique ends on them, similar in shape to a USB plug. Refer to the case or video card documentation if need be. If those cables are not attached, your motherboard may refuse to boot the system.
      Your video card may be faulty. If this is a new card, it may have arrived to you broken, in which case you will probably need to request an RMA (Return to Manufacturer Authorization) to receive a replacement. If this card was previously working for you in this system, you can contact its manufacturer yourself to receive a replacement, if the device is still under
    • Jul 21, 2012 | Systemax Venture Computers & Internet
      Powers on but only power to all fans cpu,case,video card nothing els and no beeps
      leave only the motherboard and power supply connected. power on. listen for beeps....then put in the processor, check for beeps, memory, then video card,, then hard drive. test power supply voltage, or try with a known working power supply. if you still cant find the problem its most likely the motherboard
      Jul 15, 2010 | Gateway GT5670 Desktop PC
      Sony pcv rx550 beep codes?
      Hi , here are the codes. listen closely.
      Beeps
      Error Message
      Description
      1 long, 2 short Video adapter error Either video adapter is bad or is not seated properly. Also, check to ensure the monitor cable is connected properly. Repeating (endless loop) Memory error Check for improperly seated or missing memory. 1 long, 3 short No video card or bad video RAM Reseat or replace the video card. Repeating High/Low
      CPU Either the CPU is not seated properly or the CPU is damaged. May also be due to excess heat.
      Check the CPU fan or BIOS settings for proper fan speed.
      Phoenix BIOS beep codes
      Beeps Error Message Description 1-1-2 CPU test failure The CPU is faulty. Replace the CPU. Low 1-1-2 System board select failure Replace the motherboard. 1-1-3 CMOS read/write error The real time clock CMOS is faulty. Replace the CMOS if possible. 2-x-x RAM failure Replace the RAM module if possible. 3-2-4 Keyboard controller failure The keyboard controller has failed. Replace the IC if possible. 3-3-1 CMOS RAM power bad Replace the CMOS battery or CMOS RAM if possible. 3-3-2 CMOS configuration error The CMOS configuration has failed. Restore the configuration or replace the battery if possible. 3-3-4 Video memory failure There is a problem with the video memory. Replace the video adapter if possible. 4-3-1 RAM test failure System RAM addressing circuitry is faulty. Replace the motherboard.
      Good Luck
      Mark
      Sep 17, 2009 | Sony VAIO Digital Studio PCV-RX550 PC...
      I have a power supply that is turning itself off immediately after switching it on it is a new motherboard as well Any ideas why ?
      I think either the MB or the CPU is with problems.
      Try (2 after 1 works, 3 after 2 works...):
      1) only PSU+MB+CPU and Fan - works? beeps like crazy?
      2) add memory - works? single beep?
      3) add/connect video - any image?
      All other connectors off (disks, etc) only PSU, fan and case buttons.
      If you don't get past 1), go back to the store and have it tested/returned there.
      Mar 20, 2009 | OEM Systems Xion / 400-Watt / ATX / 80mm...
      Motherboard problem
      These more up to date cards have a special PCI-E connector actually on the card which you have to connect to your psu too.
      It shouldnt beep if theres no problems
      If you cant get video or anything , make sure that the cardrs power conenctor is plugged into the psu
      Jan 07, 2009 | Computers & Internet
      Bios problem
      Standard Original IBM POST Error Codes1 short beep Normal POST - system is ok
      2 short beeps POST Error - error code shown on screen
      No beep Power supply or system board problem
      Continuous beep Power supply, system board, or keyboard problem
      Repeating short beeps Power supply or system board problem
      1 long, 1 short beep System board problem
      1 long, 2 short beeps Display adapter problem (MDA, CGA)
      1 long, 3 short beeps Enhanced Graphics Adapter (EGA)
      3 long beeps 3270 keyboard card
      PCHELL.COM Newsletter
      If you would have read my E-book on Internet Security, you may not have ended up in PCHELL. Join the PCHELL.com mailing list and receive your free E-book now.
      Name:
      Email:
      Tools for Removing Spyware, Adware, and Malware
      PC HELL
      Other Pages
      Spyware/Adware Removal Help
      MSBlast.exe Worm Removal
      Welchia (Dllhost.exe and SVCHost.exe) Worm Removal
      Uninstall McAfee Instructions
      Uninstall Norton Instructions
      Uninstall Avast Instructions
      Uninstall AVG Instructions
      Uninstall Antivir Instructions
      How to Manually Run the Microsoft Malicious Software Removal Tool
      Bloodhound.Exploit.6 Virus Removal
      MyDoom Virus Removal
      MiMail.C Virus Removal
      Swen Worm Virus Removal
      SoBig.F Worm Removal
      Dumaru Virus Removal
      BugBear.B Worm Removal
      SoBig.E Worm Removal
      Pop Up Ad Removal Info
      KAK Worm Removal
      MiMail.A Worm Removal
      W95.MTX Virus Removal
      Snow White Virus Removal
      BadTrans Trojan Removal
      Wininit Virus (Bymer Trojan)
      Happy99 Worm Removal
      VBS Netlog Worm Removal
      Pretty Park Worm Removal
      Sasser Worm Virus Removal
      Backdoor SDBot.H Trojan Removal
      VBS.Loveletter Help
      Computer Security Information
      Back Orifice Information
      PC HELL Main Page
      IBM POST Diagnostic Code Descriptions
      100 - 199 System Board
      200 - 299 Memory
      300 - 399 Keyboard
      400 - 499 Monochrome Display
      500 - 599 Color/Graphics Display
      600 - 699 Floppy-disk drive and/or Adapter
      700 - 799 Math Coprocessor
      900 - 999 Parallel Printer Port
      1000 - 1099 Alternate Printer Adapter
      1100 - 1299 Asynchronous Communication Device, Adapter, or Port
      1300 - 1399 Game Port
      1400 - 1499 Color/Graphics Printer
      1500 - 1599 Synchronous Communication Device, Adapter, or Port
      1700 - 1799 Hard Drive and/or Adapter
      1800 - 1899 Expansion Unit (XT)
      2000 - 2199 Bisynchronous Communication Adapter
      2400 - 2599 EGA system-board Video (MCA)
      3000 - 3199 LAN Adapter
      4800 - 4999 Internal Modem
      7000 - 7099 Phoenix BIOS Chips
      7300 - 7399 3.5" Disk Drive
      8900 - 8999 MIDI Adapter
      11200 - 11299 SCSI Adapter
      21000 - 21099 SCSI Fixed Disk and Controller
      21500 - 21599 SCSI CD-ROM System
      AMI BIOS Beep Codes
       1 Short Beep One beep is good! Everything is ok, that is if you see things on the screen. If you don't see anything, check your monitor and video card first. Is everything connected? If they seem fine, your motherboard has some bad chips on it. First reset the SIMM's and reboot. If it does the same thing, one of the memory chips on the motherboard are bad, and you most likely need to get another motherboard since these chips are soldered on.
      2 Short Beeps Your computer has memory problems. First check video. If video is working, you'll see an error message. If not, you have a parity error in your first 64K of memory. First check your SIMM's. Reseat them and reboot. If this doesn't do it, the memory chips may be bad. You can try switching the first and second banks memory chips. First banks are the memory banks that your CPU finds its first 64K of base memory in. You'll need to consult your manual to see which bank is first. If all your memory tests good, you probably need to buy another motherboard.
      3 Short Beeps Basically the same thing as 2 beeps. Follow that diagnosis above.
      4 Short Beeps Basically the same thing as 2 beeps. Follow that diagnosis above. It could also be a bad timer
      5 Short Beeps Your motherboard is complaining. Try reseating the memory and rebooting. If that doesn't help, you should consider another motherboard. You could probably get away with just replacing the CPU, but that's not too cost-effective. Its just time to upgrade!
      6 Short Beeps The chip on your motherboard that controls your keyboard (A20 gate) isn't working. First try another keyboard. If it doesn't help, reseat the chip that controls the keyboard, if it isn't soldered in. If it still beeps, replace the chip if possible. Replace the motherboard if it is soldered in.
      7 Short Beeps Your CPU broke overnight. Its no good. Either replace the CPU, or buy another motherboard.
      8 Short Beeps Your video card isn't working. Make sure it is seated well in the bus. If it still beeps, either the whole card is bad or the memory on it is. Best bet is to install another video card.
      9 Short Beeps Your BIOS is bad. Reseat or Replace the BIOS.
      10 Short Beeps Your problem lies deep inside the CMOS. All chips associated with the CMOS will likely have to be replaced. Your best bet is to get a new motherboard.
      11 Short Beeps Your problem is in the Cache Memory chips on the motherboard. Reseat or Replace these chips.
      1 Long, 3 Short Beeps You've probably just added memory to the motherboard since this is a conventional or extended memory failure. Generally this is caused by a memory chip that is not seated properly. Reseat the memory chips.
      1 Long, 8 Short Beeps Display / retrace test failed. Reseat the video card.
      Oct 18, 2008 | Computers & Internet
      New computer won't POST
      have you tried different memory as no matter what the board says they don't like some memory .
      also take the board out of the case and connect pwr supply.
      cpu and fan ,video card , and 1 memory stick
      no cables ,keyboard ,mouse or drives connected.
      this is called bread boarding.
      reset the bios jumper, then put jumper back.
      and power up.
      Mar 31, 2008 | Computers & Internet
      4 seconds long beep
      I think that either you have a bad power supply or it is not connected properly. I suppose it could also not be supplying enough power.
      Try disconnecting all of the connections to the Motherboard and reconnecting them. Make sure they seat properly. Try a new power supply. You can get a good one from Newegg.com
      Jan 26, 2008 | ASUS Intel 850 Chipset P4T-E (P4T-E/WOA)...
      Beep: 6 seconds on, 3 seconds off
      Pull all the cards out. Put in the CPU and fan, just one memory chip, the video card and the hard drive. Plug in just the power supply and the powerbutton switch to motherboard. Don't connect anything but the monitor, mouse and keyboard. If you still get beeps, try another memory chip (just one). I don't know the beep codes for your motherboard so we have to do this one step at a time.
      Jun 30, 2007 | FIC VC19 Motherboard
      ASUS A8S-X Motherboard Logo
      325 people viewed this question
      Top ASUS Computers & Internet Experts
      Alun Cox
      Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
