Question about RIM BlackBerry Pearl 8100
Wet my cell won,t work
Loading icon in the middle of the screen and later a sign appears with the tittle (error 507) under.
    Problem Solver:
  • 7 Answers
I remember once i swimmed in a pool with my cell phone all you have to do take the battery out MAKE SURE IT IS NOT PLUGGED INTO A WALL JACK and BLOW DRY your phone this helped me .. not to hot just warm so it can dry up all the water on the circuit board.
Posted on Feb 19, 2009
A few days ago noticed my C7 was dark at top of the screen like a shadow. Touch screen works fine. Several days later the shadow has slowly spread down the display leaving the top third of the screen...
Sometimes when we are wearing tight clothes and put mobile phones in the pocket, the screen gets pressed against coins or keys in the pocket. This damages the screen. I think this is the case with you. Now, the only solution remaining is replacing the LCD.
Sep 11, 2011 | Nokia C7 (8 GB) Smartphone
Ello. My PSP won't read UMDs. The loading
Most likely the laser is weak. It has been awhile since I have changed a laser in a psp. But first off you should clean the laser with a q-tip and isopropyl alcohol and dry it with the other end of the q-tip. It doesn't take much for them to not be able to read a disc. If it still doesn't work you will need to replace the laser if you aren't that great at working on electronics or very small things you need to find someone to do it for you.
Nov 01, 2017 | Sony PlayStation Portable (PSP) Slim...
Lately, my T-Mobile Samsung t239 phone's buttons on the slider part with the monitor attached to it won't work, like for example, the right side button that, when the home screen is on,...
i gues you have dropped it or it got wet. Bring it to your local telephone shop and ask to clean it. That only cost like 10 dollars and when they put it back together the align the keyboard
thats the best way to go
good luck
rene
May 28, 2011 | Samsung T239 Cell Phone
I got a toshiba satellite l655d and it was working fine, two days ago i tried to start it up and it didn't, the screen returned an error (File:\Boot\BCD Status:0xc000102 , info: An error ocurred while...
When the TOSHIBA splash screen is displayed or when you first turn on your computer, a boot menu prompt may be displayed for a few seconds near the bottom of the screen, indicating that a key (F2 or F12, for example) can be pressed to display a menu of boot options. The time allowed for detecting the keypress is very brief, so you'll need to be both prepared and quick.
On some models this prompt reads Press F12 for boot menu. On others, it may say Press C to boot from CD-ROM. On still others, there may be a row of colored icons representing the various boot devices (HDD, FDD, CD, LAN, PCMCIA, etc.) Press "F12" or "C" while these icons are displayed, and then use the arrow keys to move the cursor from one to another. As new models are released, the wording of these prompts may change.
Now if above steps works for you then it will start booting up from CD and then we have a shot to fix the problem you have with a simple command.
Once the computer boots up fine, go to the screen which says "Install Now". On this screen, look at the bottom left corner, you will see "repair your computer". Select this option & Choose your keyboard & language on next screen.
It will take you to the screen which will have 5 options:
Startup Repair: This option can repair the booting up problems automatically.
System restore: It startup repair doesn't works, Try this option to restore your computer to the day it was working.
Memory Optimizer: This is used to diagnose any problems with memory.
Complete PC restore: With this option, we can restore our computer to the factory settings. Performing this will result in loose of all data and software installed but it will bring everything back which you got preinstalled with your device.
Command prompt: In this option you can try some advanced command line instructions to fix the errors.
First let's try the best option "Command Prompt" to fix your problem:
>>Select "Command Prompt".
Type Bootrec /RebuildBcd, and then press ENTER.
  • If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type Yes. A confirmation message appears that indicates the entry was added successfully.
>>If the command prompt doesn
May 15, 2011 | Toshiba Satellite L655D-S5102 Notebook
Got n95 wet didn't drop it in water just in my pocket in heavy rain, it did work but stopped about 15 min later and now 24hrs later it turns on appears to have a backlight but blank screen what can i do?
Dear user,
Immediately put if off, remove the sim and battery, removable panels if any and keep it for drying preferably in an area with +35 C temperatures but not too hot also.
This should have been done when it got wet itself, but still try this out.
If it does not work fine after doing this then you need to send it for repairs.
May 03, 2011 | Nokia N95 Cellular Phone
Cell got wet . insert battery hello moto appears appears on the screen. later the becomes blank
You should not turn on your phone while is wet because you don't know the inside components got wet too. Now your phone got short circuit inside. First thing you have to do if you encounter the situation again is to clean your phone from inside and outside and make sure it is well dry. Now what we can do to your phone is to have it check personally with a cell phone technician and hoping it will be revived.
Hope this could help..
Don't forget to rate..Thanks..
Mar 25, 2010 | Motorola Mobility SLVR L7 Cellular Phone
Code 507 with circle as soon as i switch it on wont let me do anything else
Error 507 appears when any subsequent attempts to perform an Application Load or upgrading the software
on the BlackBerry smartphone are unsuccessful
Solution :
1. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
2. Click on the Application Loader icon.
3. Click Update Software.
4. Type your BlackBerry smartphone password (if prompted) and click OK.
5. Select Options under the Device software options section.
6. Select the check boxes next to the names of the applications you want to install.
7. Click Settings, and remove the check mark from the check box for Back up device data automatically during the installation process.
8. Click OK.
9. Click Next > Finish.
10. When the process has completed, the message The loading operation was successful will appear. Click Main Menu to return to BlackBerry Desktop Manager.
If it shows the same error then please visit to the nearest Service centre.
Oct 31, 2009 | RIM BlackBerry 7290
Reload 507
cant say this enough www.crackberry.com this sight is a must have for any blackberry user
Jul 13, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
It's all black with a white apple sign
ok try reseting it and no reseting the ipod dose not erase it hold the power and home button at the same time for at least 10 sec or untill the ipodreset it should sjut off and a few sec later you should see the apple logo hope this helps
May 22, 2009 | Apple iPod touch
RIM BlackBerry  Pearl  8100 Logo
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
