Question about Kenmore 14.1 cu. ft. / 399 liter Upright Freezer 23414
How do I find Upright freezer size? Model: 253.9264110
What size is a frigidare 297080400 upright freezer
Hello friend, thank you for your post!
In order to provide you accurate information could you provide me with your model number please? Normally you can locate the serial tag (which lists your model number) on the inside wall of your freezer. With that information I can provide you with the cubic ft. of your freezer. I look forward to helping you further. -Matt
Oct 04, 2014 | Frigidaire Freezers
What tool do I need to remove a kenmore upright freezer door
A Torx bit for a power screwdriver or a Torx wrench size T20 or T15 probably.
Aug 05, 2014 | Kenmore Freezer 20.3 cu. ft. Frost Free...
What size is a frigidaire freezer mfu17f3gw6 ?
Good Afternoon Claus, that's a great question!
Your Frigidaire freezer (MFU17F3GW6) has a total capacity of 17.0 cubic foot. I do hope this information proves to be helpful. Should you need any further assistance please feel free to respond.
Jul 12, 2014 | Frigidaire Freezer Refrigeration White...
Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
Feb 05, 2010 | Freezers
Slow icecube maker
the harvest mode is started when the ice cube reaches around 14 degrees so lower the temp in the freezer or decrease the size of the cubes also make sure the fan vents in the freezer is unblocked. check the temp in the freezer should be around 0 degrees.
Dec 12, 2008 | Frigidaire Freezer Refrigeration White...
Door gasket for Kenmore upright freezer model 2539239712
Go to sears parts direct website. It's part #3206261 and is in stock, $93.07. Good Luck! countrycurt0
Aug 08, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Old Kenmore Freezer
It is uaually coded into the model #. Usually in the middle. I can usually eyeball them. another solution is measure the outside dimensions of a refrigerator or freezer you know the size of then compare them. This will give you a rough estimate.
Jun 25, 2008 | Freezers
Kenmore 14.1 cu. ft. / 399 liter Upright Freezer 23414 Logo
513 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
