Question about GE DBXR463GB Gas Dryer
Oily smell on my clothes from the dryer
My husband is a pipefitter and they use some kind of oil on the pipes which gets on his clothes and when I wash and dry, the smell stays on his clothes as well as the rest of the clothes I wash (which I wash separtely from his). WHat can I do to get rid of the smell. I assume the smell stays on everything once the clothes are dried in the dryer. What can I do - it is driving me nuts. Thanks.
  • 547 Answers
Have you tried tide with fabrezze?
Posted on Feb 19, 2009
Washed clothes with gasoline on them. Put into dryer now washer and dryer smell like gasoline. How do I get it out?
To remove gas (petrol) smell from clothing, soak overnight in baby oil (use like you would downy), then wash in baking soda, then wash with normal detergent. It will rid "gas smell" from an entire basket of clothes. Air Dry ONLY
From ehow website:
Step1
Buy a bottle of baby oil. Since gas is an oil based product it is going to take an oil based product to clean the gas out of your clothing. Baby oil is a great product to use as it shouldn't, in most cases, cause further damage to your clothing.
Step2
Soak your clothes with a bit of laundry detergent, water, and a generous portion of baby oil. Also dab some right on the stain before soaking.
Step3
Swash your clothes in the water for a while and let them sit for about five minutes. Transfer the clothes into your washer, once again remembering not to mix them with any other clothing, and let the cycle finish.
Step4
Wash the clothes. If you have a top load washer, let it partially fill up about 1/4 of the way with water. Put some of the baby oil in the wash with the clothes and swash it around a bit. Once the washer cycle begins, add the detergent and let the cycle finish. Make sure that your gas coated clothes are the only clothes you put in the wash.
Step5
Dry your clothing. Make sure you only AIR DRY on a clothes line these clothes. It could take more than one wash to get all the oil out of your clothing. If you use the dryer after the first, or even the second time, you could risk starting a fire in your dryer.
Step6
Check and see if any smell remains in your clothing. If the smell of gas remains on the clothing repeat the wash with baby oil again until the smell is gone.
Sep 04, 2011 | Frigidaire Electric Dryer
Not getting clothes completely dry. Bad smell
The problem is the water in the vent pipe.You will have to empty the water out of the vent pipe. If the vent is running under the house, crawl under, starting at the closest dip to the dryer and work it out to the exterior. Then use some wire or ties to secure it to the floor joists to keep the dips from reoccurring. If there is water in the pipe, then the dryer can't blow the warm, moist air out of the tumbler. It is the equivalent of trying to dry clothes in a sauna. There is nothing wrong with the dryer, it is working correctly. The problem is the vent.
Mar 28, 2010 | Kenmore HE5
I have Kenmore Series 80 electric dryer. The clothes no longer have that good smell when they come out of the dryer. What can I do to get that fresh laundry smell? The clothes smell fresh when they go in...
There may be a build up of excess lint in the inner tubes. You can remove the vent pipe and visually examine the tube. The build up of lint will cause odor if its excessive and could be hazardous. You may want to unplug the dryer and vacuum the tube out if possible. P.S: The best way to get that fresh smell is to use an outdoor clothesline.. and save energy too! lol
Feb 23, 2010 | Dryers
I have a Maytag Neptune gas dryer and recently light colored clothes are coming out with small black marks on them; it looks like grease/oil stains. Where could this be coming from?
my first guess would be something ,someone placed in dryer perhaps coveralls or oily clothing.There is no place that I am aware of on a dryer where you could pick up oil leaks from ..are you sure you did not have a lint fire,the oil stains may be soot
Dec 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
My dryer smells like sulfur . The clothes smell
Run a couple of hot washes with no clothes in the machine
Before you do dissolve some Soda Crystals in 2 liters of hot water and put them into the machine by hand.
Your machine smells because new powders wash at lower settings and do not contain bleaches and soda to kill off the grease which is washed off the clothes
Jun 16, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
When the dryer is running it smells like charcol ligher fluid
Sometime recently there has been a petroleum product used in the house. Possibly an oil based paint, stain, varnish, adhesive or some form of cleaning product.
Anyone of these products or many others like them, contain a distillate of liquid. Check around the house.
Until that oil based product dries or cures, the odor and vapors will remain and so will the dryer smell.
At the end of the drying cycle, use the air fluff cycle to purge out the smell. Besure to return the selector on the dryer back to it's prior postition.
Jun 11, 2009 | Kenmore 62882 Electric Dryer
Clothes smell burndt after drying in a Kenmore gas dryer
Rule number one NEVER EVER use the top of your dryer to stack piles of clothes while in use. That is the main reason why dryers over-heat. Also clean out the exhaust tube to the exterior.
Feb 21, 2009 | Kenmore 73952 Gas Dryer
FUEL LIKE ORDER COMING FROM ELECTRIC DRYER POWERE BY FUSES
Have you recently painted anywhere in your home. And I mean anywhere? Paint fumes or other chemical type cleaners or solvents will get in the elements and put off that whole gas or oil smell. If no, have you put any type of clothes in the dryer that may have had some paint or anything else petroleum based on them to dry. That also could have caused this smell as well. If your hot water heater runs on propane or natural gas, check it careful for leaks. This could be a serious situation as a major explosion could happen if it is leaking. Leave the house and call 911 immediatly from a safe distance. I doubt that this is the problem, but be safe than sorry. Let me know if none of these are the culprits. Thanks and let me know.
Feb 22, 2008 | Whirlpool LER5636P Electric Dryer
Dryer smells of natural gas
Of course, this applies to gas dryers only. If you smell natural gas near your gas dryer, do not light matches or a lighter and don't operate electrical switches or anything that might spark, igniting an explosion. Immediately shut off the gas valve that serves the dryer. If the smell is mild, ventilate the area, wait until the air is clear, and re-light your pilot light. If the smell is strong, move everyone outside, leaving the doors open to ventilate the house. Turn off the gas supply valve --located by the gas meter on the gas inlet pipe-- by rotating the valve one quarter turn with an adjustable wrench. The valve's oblong stem should be perpendicular (at a right angle) to the inlet pipe to stop the flow of gas. Call your gas supplier (or the fire department) from a neighbor's phone or a cellular phone outside the house.
Jan 18, 2006 | AEG T57800 Electric Dryer
GE DBXR463GB Gas Dryer Logo
324 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
