Question about Amana DRB1901C Bottom Freezer Refrigerator
A loud intermitant buzzing coming from the back of the fridge
Bottom freezer Amana DRB2101There is a loud intermitant buzzing coming from the back of the fridge. Sounds like something is being turned off and on every 5 min. I turned the icemaker off but the buzzing continues. Thanks A Buzzing noise every 3-4 minutes. Nothing else wrong that we can tell. Another person has a simuler problem with same type of fridge DRB2something, on this web site.
    President:
  • Amana Master
  • 2,651 Answers
Either the noise is coming form he ice maker fill valve( but if its of and still aking noise i doubt it. it also possible that the noise is coming from the compressor itself, overheating nad trying to restart in which case would give a slight "buzz" noise for 5secs or so then "click" off, and wait maybe 3 min to restart again. look for melted ice andperhaps your ice dream ont as hard as it should be???
Posted on Feb 19, 2009
Loud buzzing noise
Yes that is your relay they are pretty common use your model number to track one down may tag is owned by whirlpool so most local places will have them
Mar 01, 2014 | Maytag MFD2560HES Bottom Freezer French...
Amana fridge stopped working for 2 days
Do you see any ice buildup on the back wall of the freezer or behind it?
Dec 03, 2012 | Amana AFF2534FE Bottom Freezer French...
Hi! I have an amana bottom freezer. The freezer wasnt as cold as usual and I noticed some frost on the back of the freezer. I melted it with a hairdryer, and cleaned the back of the fridge with a vacuum....
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 16, 2011 | Refrigerators
Amana side by side, buzzing, no fan in fridge.
that sound is the relay/overload. it is trying to start the compressor. the problem is either that relay or the compressor itself
Feb 05, 2010 | Refrigerators
Loud buzzing/Humming noise.
I have a Amana ASD2622HRW Lately there is a loud buzz that comes and goes. We cleaned everything and blew it out under and behind the fridge. And it still is happening. Any suggestions? It still cools fine. But this Buzz is so loud that you can hear it through the house. Please help!
Apr 24, 2009 | Amana ASD2622HR Side by Side Refrigerator
Buzzing noise from back of freezer
need to remove rear panel inside of freezer section. check for normal operation of evap fan motor. check for ice build up on evap.
Apr 21, 2009 | Amana ARS2464B Side by Side Refrigerator
Samsung frost free fridge freezer ices bottom of freezer
it means that the freezer heater is bad, it's located after you remove the racks from the freezer and removing the back panel, it's at the bottom or below the condenser.
Dec 11, 2008 | Samsung RS2630WW Side by Side Refrigerator
Freezer won't chill beyond fridge temp
compresoor sounds like its tryin to start but cant, should be covered under 5 yr manufacture warr.
Feb 21, 2008 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
ARB2214CB - Condensor is Noisy
It sounds as if the thermal limit on the compressor is cutting off power to the compressor when it gets too hot. There could be 3 reasons for this. One, the compressor is just bad...should be covered under the 5 year sealed sytem warranty (if its less than 5 years old of course) if this is the case. Two, the thermal overload and start relay assembly is bad. They are mounted directly to the compressor (big round black thing) and can be changed for about$14 in parts (unplug the unit before replacing!) Three, the fan that runs in the bottom near the compressor that cools the compressor and condenser is jammed or not rotating for some reason. It should run any time the the compressor is running. If it doesnt, it need replaced or the compressor will do exactly what you are describing. Hope this helps!
Oct 22, 2006 | Amana ARB1905C Bottom Freezer Refrigerator
Amana DRB1901C Bottom Freezer Refrigerator Logo
1,506 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
