Question about LG 50PG20 50 in. Plasma HDTV
How can I run the audio from lg 50pg20 through old receiver?
I have an LG 50pg20, a 10 year old receiver.
  • yourgraphics Feb 19, 2009
    Thanks-
    Any idea if they make an Optical to RCA cable or converter?
    President:
  • 2,992 Answers
I downloaded the manual for this set from LG's site and looked at the back panel diagram, and their instructions for connecting audio out. This set has only a digital audio output available, and your receiver probably has no input for that. Sadly, this means you can't connect the TV audio to the receiver.
What you can do, however, is connect the audio from an external source such as a DVD player, cable converter or satellite receiver to the receiver, and connect the video from the device to one of the TV's inputs. Then you could listen to the sound through the receiver. If you want to, you can use a Y-adapter (two, actually, since you have right and left channel sound) and connect the source audio to both the TV and then you would have the sound through the TV speakers as well. When using the TV's internal tuner, you would have sound only from the TV speakers.
Posted on Feb 19, 2009
  • Feb 20, 2009
    You can get a converter but it only converts from one optical form to another. The digital audio output is a laser light source (the manual actually warns against looking into the end of the cable), and the RCA inputs on your receiver expect electric voltage on copper wire. It would probably be more cost effective just to buy a new receiver with optical input ...
    Hey, that's an idea that didn't occur to me before. Look around for a cheap receiver with a digital input, and feed its record out connections (sometimes labeled "line out") into one of the inputs on your current receiver. Then you could use the output from the TV.
I have a 50PG2 and it has (& also in the manual) an AV port out for an external second monitor or TV. (2 x audio and 1 x video) . I feed the Audio from this port to my receiver for general audio whn not wanting the full theatre running. Can also use this port to feed audio to standard definition DVR for recording (downgraded) HD programs off air.
Posted on Mar 09, 2009
  • 44 Answers
Use RCA cables from the back of the TV into audio input on the reciever?
Thats how its done in most circumstanes. What model reciever?
Have video but no audio on 50PG20 LG plasma?
mainboard issue replacing the board with fix your problem
Jun 15, 2014 | LG 50PG20 50 in. Plasma HDTV
How to master reset LG tv 50PG20, and do a firmware update
To do a master reset [System Reset] you have to enter its service mode option. Electro help Check this link to get more details. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Jan 06, 2014 | LG 42LC2D 42 in. LCD HDTV
My LG 50PG20 Television has audio , but no picture
If its just your video than I think its your back light inverter. However it could be the main board in your TV. I would call a repair man to come out and take a look.
Mar 02, 2013 | LG 50PG20 50 in. Plasma HDTV
My lg plasma tv popped and now won't come on
Lisa, not 100% on the part you need to fix. But, try these guys out.....http://www.shopjimmy.com/catalogsearch/result/?q=LG+50PG20.
TeeVeeMan2@gmail.com
Oct 06, 2011 | LG 50PG20 50 in. Plasma HDTV
Where are the red and white jack sockets to connect my new 50in lg plasma screen to my old wired 5.1 speaker system?
I am sorry to say that it does not have a left /right analog audio output. It only has a digital optical output on it. Unless your receiver has a optical input, you cannot use your set's audio out. If you are using a cable box or satellite receiver, you can their left /right output for you audio signal.
I hope this helps,
Skyassoc
Dec 11, 2010 | LG 50PG20 50 in. Plasma HDTV
Where can I buy a new power board for my Plasma LG 50pc1dra-ua? I know that I have capacitors that are blown on the board and I want to put in a new one.
I had the same problem and opted to take the board out and replace the caps. They were all the same capacitance. Cost me $6.61 for 10 new caps (needed 9, 10 was cheaper). If you can solder, watch the capacitor videos on YouTube and give it a go.
There is a replacement for the original. You can try http://www.partstore.com/Model/LG+Electronics+Incorporated/LG+Electronics%2fZenith/50PG20.aspx?p=1&z=50&c=6e080ee60c7dbeec930c9d72f2d3d6f7&bs=Category&bd=Asc&ms=Category&md=Asc&k=&on=
and http://www.shopjimmy.com/lg-eay39190301-power-supply.htm
Good luck
Aug 06, 2010 | LG 50PG20 50 in. Plasma HDTV
LG 50PG20 Plasma,, nothing shows on screen its all black
This model was known for issues with the Y-sustain, Y-drives, and the Z-sustain boards. These boards help process the picture image to the screen.
When one or more of these boards fail, the screen stays black, and you only have audio & on/off.
You could call LG and try to get your TV repaired at a discount if you can convince LG to honor this known issue.
Another issue could be the actual panel has gone bad. The plasma panel in your TV has a two warranty and LG would fix that for free. Well…it would be free as long as it’s not past two years of your date of purchase.
What zip code are you in?
Jun 18, 2010 | LG 50PG20 50 in. Plasma HDTV
LG 50PG20 50 in. Plasma HDTV Logo
826 people viewed this question
Henry  Thomas
Henry Thomas
