Question about HP DeskJet F4280 All In One Printer InkJet
Even thought there is NO paper jam, I still get an error message:
The printer has no paper jam. Even after attempting ALL commons solutions as outlined on the web-page the "resume" light continually flashes. Nothing is clearing the error and when I add paper, it flows through about 3/4 way and the same message appears & printing stops.
  • brandonruggl Feb 25, 2009
    I am having exactly the same problem as you are, it even does it without paper in the printer. I am on tech chat with someone, but they don't seem to know what is going on
I hope the following helps.
I was trying to get my son's new F4280 printer set up ... and could never get an alignment page to print. Lot's of loud clunks and scary mechanical sounds ... but no printing of the aligment page. We did get 2 test pages to print ... but eventually nothing would print. The attached computer said that the cartridge cradle could not move.
I tried pulling the cartridges ... and the printer had problems moving the cradle to where I could pull the cartridges ... but it eventually got there.
Still didn't print. Still complained about the cartridge cradle not moving.
I opened up the front panel to look more closely ... and eventually saw that the cradle seemed to be running into something at the back.
Behind the cradle, on the left side, is a narrow ribbon cable ... looks like a piece of white paper. Surrounding this cable is what I assume is a ferrite core ... a dull dark grey band that goes around the cable. This band had come loose and the cradle was hitting it as it went by.
I turned off the printer and used a butter knife to gently push the core around ... and saw that it had a place to which it could snap-in.
After that, the cradle could move.
At this point, I can't say it's fixed ... but I was able to print the alignment, the noises have lessened, and I've printed a "real" page successfully.
I offer this in case it might help others.
MikeB in Tacoma.
Posted on Jun 28, 2009
    Genius:
  • 2,035 Answers
Please try this solution :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Feb 19, 2009
Paper jam no paper jam D7460
after going through your problem, i think that there is a communication failure between your printer and computer, in such cases, it is common to get false error messages like paper jam, etc, even though there is no actual paper jam. I recommend u uninstall and reinstall the printer driver. Im sure your issue will be resolved.
Aug 04, 2009 | HP Photosmart D7460 Printer
Error message keeps appearing "paper jam in tray 2" although there is definitely no paper jam.
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If you don't find anything you may need to disassemble the printer to find it.
May 02, 2009 | HP LaserJet 2300dn Printer
Paper Jam Error Message
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
djiu9ofdfd22
Apr 20, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer paused-unable to read
HI there,
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
Oct 04, 2008 | Brother HL-2070N Laser Printer
"Clear paper jam" error, but there is no jam!
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Error Messages
The false Jam at MP E is a common error caused a manufacturing error/problem. You can download a solution to this problem HERE.
The K dev unit error can only be removed by replacing the dev and completing the service mode adjustments. A service manual will help you with this issue. Get one HERE.
Jun 06, 2008 | Epson Aculaser C1100 Printer
Error 13-jam paper HP Laser 4+
HP LaserJet 4, 4m, 4 Plus and 4m Plus Series Printers - False Error Message 13 PAPER JAM ISSUE: After clearing all jammed paper from the HP LaserJet 4, 4m, 4 Plus, or 4m Plus series printer, the display still reads 13 Paper Jam . Even after cycling the power off and then back on, the error remains. SOLUTION: Open the rear door of the printer. There is a paper sensor near the upper right hand corner of the fusing assembly (just below the right edge of the long yellow warning sticker on the fuser) that can cause paper jam error messages even when there is no jammed paper in the printer. Toggle the thin black plastic lever up and down to make sure it is not stuck or sticky. The lever should be in the down position before closing the back of the printer. If the lever is stuck or missing, the printer will generate a false paper jam message. Hope it will help you !
Apr 02, 2008 | HP LaserJet 4 plus Printer
Paper jam
There are several things that can cause a paper jam error, even though there is no paper stuck. The most common is that the paper pickup rollers are worn or dirty, and can't grab paper. Even though there is no paper jammed in the machine, it will show the error message. The solution is to clean the roller with alcohol and a lint-free cloth (don't use paper towels). If the roller is very worn, you will need to replace it.
Feb 04, 2007 | Canon Image Runner 1630 Copier Copier
HP DeskJet F4280 All In One Printer InkJet Logo
896 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
