Question about Kenmore Washing Machines
Kenmore 44152 3.5 high capicity washer will not spin
Water will drain, wash cycle ok but no spin dry, cloths come out wet
  • leobolton Feb 19, 2009
    it does click, its just skipping the spin cycle on everything, i ran several normal cycles and a couple drain and rinse with no cloths or detergent, it just skips spin:(
  • leobolton Feb 21, 2009
    replaced door latch switch 79.00 parts store, working fine now. thanks for the info!!
  • 117 Answers
Open the lid of the washer and let it down gently to see if you hear a click when it closes. There is a lid switch that sometimes fails and prevents the washer from going into a spin cycle. If you don't hear the click when the lid closes, then you may need to have the lid switch replaced.
http://tclaundryrepair.com/home
Posted on Feb 19, 2009
  • nailuj12 Feb 19, 2009
    The problem may be a faulty timer with contacts for spin not connecting or a faulty gearcase but you will need to have a technician verify which.
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Clothes still wet after cycle is over
Be sure drain hose is not kinked and no higher than the top of washer to drain pipe. Remove clothes as soon as it stops spinning
Jun 23, 2010 | Kenmore 23822 Top Load Washer
Clothes are to wet after spin cycle
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 24, 2010 | Kenmore Washing Machines
I have a Kenmore frontloading washer, model no. 417.42042100. At the end of the wash cycle, the clothes are still very wet; that is, still SOAKED with water, even though all the water has been drained...
HI. your unit is equipped with a spin control board. this board, if damaged, will not initiate an adequate spin. This will not allow for proper drainage and drying of the clothes. The spin motor regulates the rotation speed during the spin cycle. It seems to be the culprit at this time. Have the spin board replaced asap.
This part will usually cost around $150.00 at the most.
Aug 27, 2009 | Kenmore Washing Machines
I have a Kenmore 3.5 washer model # 44152. The washer is going through all the cycles but for the final spin it does not spin. Thus leaving the clothes sopping wet. What is wrong?
Is your pump clear? Nothing is in the pump blocking it? Does it drain ok? Check out your pump buy removing the bottom panel..Then check you drain hose where ever it is draining into, make sure drain isnt tp far into drain, or sink becausewater will syphen back into washer...try checking these simple checks first. i think your pump has a screw in type plastic cap. unscrew and check if you have anything in it and nothing is restricting the inpeller. spin the impeller with you finger make sure it spins around freely. you will feel some tension from the magnitation it is getting. but yeah, try these simple checks first and see what happens....
Jul 31, 2009 | Washing Machines
Clothes way too wet after washing
your washer is not hitting high speed spin thats why the cloths are still wet,bad transmission,sorry-mike
Jun 03, 2009 | Kenmore Washing Machines
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore washer spin cycle doesn't leave clothes dry
SOUNDS LIKE THE TRANSMISSION IS NOT ALWAYS SHIFTING INTO HIGH SPEED MODE,TRY A MED. SIZE LOAD AND SEE WHAT THAT DOES,TRANSMISSION MIGHT JUST BE GETTING OLD WHIH IS NORMAL-MIKE
Dec 06, 2008 | Roper RAB2121KW Top Load Washer
Kenmore 90 Series, clothes wet after spin
First thing you need to check is the speed of the spin cycle. As long as you are not overloading the machine, it should spin the clothes pretty dry. the basket drive may need to be replaced. If it is spinning very fast, then check the drain hose, make sure the water is coming out nice and fast. If not you may have a water pump problem even lint clogged inside it.
Nov 29, 2007 | Kenmore 22422 Top Load Washer
Not draining
it will be the pump they have a small fan inside them they get weak and with the pressure of the water they stop spinning which doesnt push your the water through the motor fast enough to drain properly replace and you will see the difference
Aug 22, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
398 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
