Question about GE WBVH6240F Front Load Washer
My GE Washer Door Won't Lock
I have a brand new GE front load washer (WSSH300) and it's been working fine for a week. Now it won't start. It simply beeps at me and the light goes back to flashing.
I think it has something to do with the door lock, but i have no idea how to fix it.
  • 360 Answers
Try this, press the pause/cancel button twice. Open the door, ensure there is nothing blocking the door and close the door fully. Open the detergent drawer fully and re-close the drawer. Select Quick wash and press start.
If this does not correct the problem, call for service under warranty.
clarkco
Posted on Feb 19, 2009
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
Error code FL-maytag neptune front load washer won't lock
replace door latch (fl = faulty latch ) good luck APPLIANCES R EN
Mar 09, 2013 | Maytag Neptune MAH5500B Front Load Washer
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
My kenmore front load washer doesn't want to start all lights are working but nothing happens even the door won't lock
your door switch is the problem,where the door latch goes into the machine a little switch sites behind this a safety feature and if this is broke the machine will still switch on but will not work it will need replaced they are cheap.adrianxxx
Jun 02, 2012 | Kenmore 44072 Front Load Washer
Washer won't start and red lock sign on front
Sounds like a problem with the door lock on the front but what and where is another question ,is the water turned on by any chance as it will not fill and could throw this light on .
Feb 11, 2012 | GE WSXH208A Front Load Washer
Fridgaire FTF530fs3 door lock buzzing and not locking, washer won't start
fit a new door lock as if it doesnt engage it wont allow the machine to start the washing cycle
May 31, 2011 | Frigidaire FTF530FS Front Load Washer
Ge wssh300 will not start may, just beeps
hold the start and select button in for about 30 seconds together until you hear a beep; this resets the control panel
Aug 04, 2009 | General Electric WSSH300G Front Load...
GE WBVH6240F Front Load Washer Logo
876 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
