Question about Sanyo CLT2054 20 in. EDTV-Ready LCD Television
Sanyo CLT1554 has sound but no picture. When you
Sanyo CLT1554 has sound but no picture. When you try to program channels the menu says no antenna. I have it plugged to my cable and the menu is on cable, not vhf or uhf.
  • Derek Gorrell May 11, 2010
    Are you using a cable or satelite receiver?
  • 327 Answers
SOURCE: Sanyo clt1554 has sound no picture.
its the error of the faulty ic on the main board that has to be replaced.to make it work.
Posted on Dec 15, 2008
  • 73 Answers
SOURCE: Does my Sanyo CLT1554 15 in. EDTV-Ready LCD have a digital tuner?
Your specs are here, http://reviews.cnet.com/flat-panel-tvs/sanyo-clt1554-15-lcd/4507-6482_7-32013875.html?tag=mncol;psum
unfortunately you have a
  • Analog TV Tuner NTSC
and
  • Enhanced Definition Television (EDTV) Monitor - EDTV Monitor refers to a monitor or display with the following minimum performance attributes:- Display Scanning Format: Has active vertical scanning lines of 480 progressive (480p) or higher- Aspect Ratio: None specified
You need a tv that has this:
Enhanced Definition Television (EDTV) Tuner - EDTV Tuner refers to a RF receiver with the following minimum performance attributes: - Receiver: Receives ATSC terrestrial digital transmissions and decodes all ATSC Table 3 video formats.
So Sorry, the tuner is not Digital.
Posted on Jan 05, 2009
romsky79
  • 822 Answers
SOURCE: Sanyo Flat screen
try to check the settings of your tv if all ok. if ok its a problem in your TV circuit board try to resolder maybe some sections is cold solder. if not its a service mode. trust me!
Posted on May 20, 2009
SOURCE: how to connect?no instructions
ok maybe this will help.
make sure the video and audio are in the right place... setup:
  O OOX yellow OOX white OOX red OOO OOO
then turn device on (dvd/vcr) and on the remote press input button at the very top. this would set your device to video one screen, and you can watch whatever it is that you hooked up.
for cable or antenna hook that up then press reset button on remote ( bottom right hand side)
Posted on Jul 06, 2009
  • 222 Answers
SOURCE: Sound but No Picture
Connect your outdoor antenna directly to your antenna in, in your TV see if it works and do the same with your cable input if it works then the A/B box is at fault.
Posted on Jun 15, 2010
When I hook up my sanyo model#clt1554 to my hdtv rabbit ears it does't work why?
Rabbit ears are a poor man's antenna. Maybe you have no analog stations in your area. If you do, then the signal is likely very poor.
Sep 30, 2014 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
Sanyo drw-500 dvd recorder will not recognize channels from antenna in setup
Have you set the Sanyo to "antenna" or to "cable" ?
If you've tried one setting, try the other.
Apr 16, 2014 | Sanyo DRW-500 DVD Recorder
I have a Sanyo DP32648 that keeps losing only one channel in the program. When the TV is turned off, that channel disappears from the program. I have to manually reboot the entire list. How can I solve...
It sounds like there is some electrical noise interference that would not be "fixable". If though, we reconfigure the way that they are connected together, we may be able to avoid the noise.
Instead of allowing the antenna signal to "pass through" the 625 we will skip it.
After following the directions, switching between satellite and antenna will be done by selecting on the SANYO "Input 1" for satellite, and selecting "Ant" for antenna. K?
Try this:
From the 625 Tuner 1- using RCA cables (a.k.a. composite cables, or red, white, yellow cable), connect to "Input 1" on the Sanyo TV. To see composite cables go to http://www.wowvision.tv/settingsandconnections.htm
Next, remove the coaxial cable between the Sat box and TV. (Sanyo "Ant. In" port and 625 "Out to TV" port) Set that cable aside.
Now, remove the incoming antenna cable from the 625 "Ant. In" port, and connect it to the Sanyo's "Antenna In" port.
Finally, scan for channels and check for the presence of CBS.
Once verified, test the TV by turning off and on.
Turn on the satellite receiver and switch Sanyo to "Input 1" to verify sat picture.
I believe this solution will satisfy your needs. Please let me know if it doesn't work, and I will need to talk to you about signal strengths, again.
God bless,
Highdefjeff
Jun 13, 2010 | Sanyo DP32648 32 in. LCD TV
Channel scan doesn't complete
if you're only using antenna, maybe your signal is weak try using a better antenna, and aerial one.
Dec 28, 2009 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
Sanyo CLT1554 Vizon TV no picture no sound.
overheat is likely
but check the internal fuse
Aug 04, 2009 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
Sound but no picture
might be the heaters on the tube
Jul 05, 2009 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
I dont know if my lcd tv supports 720i, 1080i, or 1080p
Sorry. It does not. 480i and/or 480p.
http://www.generalmanual.com/Televisions/Sanyo-CLT1554-STEREO-LCD-TV-EDTV-Monitor.htm
Picture Resolution: 1024 x 768 (XGA);NTSC (480i) EDTV (480p)
Dec 24, 2008 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
New dp 19648 sanyo hdtv no signal detected
You gotta have a way to get signal to the tv . If you don't want a outside antenna use rabbit ears .After you hook them up hide them behind the tv then do a channel scan. If you don't pick up all the stations set them on top and scan again or get satillite or cable hd boxes.
Dec 24, 2008 | Sanyo DS27820 27" TV
I have a Sanyo CLT1554 (2 1/2 years old). Has perfect sound but no picture. The picture will come after several times turning it off/on and pressing the Reset button. It is very anoing to do this evey time. PLEASE HELP
Dec 15, 2008 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Oct 28, 2007 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
Sanyo CLT2054 20 in. EDTV-Ready LCD Television Logo
126 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
