Question about Power Acoustik PEQ-70 7-Band Car Equalizer
Wiring Troubleshooting Power Acoustic PEQ-70 7-Band Car Equalizer, Support & wiring
My power acoustic per-007 is demanding more voltage than normal to operate. If I probe the power source to it with the connector unplugged I have battery voltage. Once I plug it in the voltage drops to 8...
Sounds like you need to run a heavier Gauge wire for power source. If power source wire is too small, you will get a voltage drop. Check your source wire gauge compared to connector on equalizer. You may end up having to run a heavier gauge direct to battery, with fuse link in line. See what the amp requirements are in manual, and make sure wire is heavier than minimal. Example: if 15 amp required, I'd go to 12 gauge minimum, or to be safe 10 gauge. (longer the run, heavier the wire.) Be sure all connections are good as well.
Apr 15, 2011 | Power Acoustik PEQ-007 7-Band Car...
What is the blue/white wire on a kgc-6042a car equalizer and the yellow which is the power
blue/white would be the "turn on signal" wire, i.e. one that gets 12v when the unit is supposed to be on (this would correspond to the amp turn-on or power antenna wire from your CD player) whereas the yellow wire is the 12v constant power wire.
Jan 25, 2011 | Kenwood KGC-6042A 9-Band Car Equalizer
Need wire diagram for pioneer eq-6500
Pioneer EQ-6500 9-Band Car Equalizer .i want to buy this equaliser.i need 10 pieces ,please send me through my email febiano22@yahoo.com
Nov 24, 2010 | Pioneer EQ-6500 9-Band Car Equalizer
I need a manual for a zapco PEQ 9 band (old school) equalizer. can you help me?
i got a wiring paper that comes with the peq plug,its not a manual but it shows how to wire up a zapco peq
Nov 07, 2010 | Zapco Car Audio & Video
I need a wiring diagram for the pyramid 10 band graphic equalizer. Where can I find this diagram?
Click on MANUAL DOWNLOAD
LOOK PAGE 4 INTO THE PDF FILE!!!!
http://www.pyramidcaraudio.com/sku/903G/10-Band-Half-Din-Power-Booster-Graphic-Equalizer-Amplifier-200-Watts#
Oct 10, 2010 | Pyramid 903G 10-Band Car Equalizer
I need a wire diagram for equalizer 903g
Jan 29, 2010 | Pyramid 903G 10-Band Car Equalizer
How to wire an eq to car stereo without an outboard amp?
no those wire is not for speakers out put that for signal in put only if there is rca jack follow the instruction and run your cable if your dont know dont guess you will burn unit audio out put if install wrong
Jun 28, 2009 | Power Acoustik PEQ-70 7-Band Car Equalizer
Power supply connection for pioneer eq-6500
top left - orange.....goes to aux or memory wire
top right - blue.......goes to the remote wire used with amps
bottom left - black.......goes to the ground wire
bottom right - red........this goes to your hot wire
May 31, 2009 | Pioneer EQ-6500 9-Band Car Equalizer
Need info on wiring for audiobahn aeq6q 5 band equalizer
Yes, This connects to the Blue Remote Wire. This will allow the EQ To Power on when in ACC or Start on the Ignition. Please Rate My Response! Thanks!
Feb 03, 2009 | AudioBahn AEQ6 5-Band Car Equalizer
Alpine equalizer wont work
to have them work you have to connect the yellow wire to constant 12 volt power,and the red to blue and white wire coming from the radio if you dont have a blue remote wire on the radio connect it to the accessory of the car wire that power the radio
Nov 04, 2008 | Alpine ERE-G180 11-Band Car Equalizer
Power Acoustik PEQ-70 7-Band Car Equalizer Logo
117 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
