Question about Roper FGP305 Gas Kitchen Range
Roper gas stove
I have a roper gas stove which takes about an hour to boil water on all four burners. The flame is completely blue and very low. I need to know how to turn up the flame or how to fix this problem asap.
5 Suggested Answers
Amigaman
  • 248 Answers
SOURCE: cannot adjust flame on gas burner
Is this lp or natural gas? The screw you turned adjusts the low flame only. Did this just start, or has it always done this? Let me know.
Posted on Nov 20, 2007
aborcass
  • 2651 Answers
SOURCE: burner goes out on simmer
look down the shaft of the burner valve(remove the knob). with a very thin and somewhat long screwdriver you should be able to adjust this flame, with the burner on MED hold the shaft of the valve with a pair of pliers and turn the screw slowly( you'll need to hold the shaft tightly because if not you'll be turning shaft and not adjustment screw. small increments yield big changes in flame
Posted on Mar 07, 2008
MNTECH
  • 1543 Answers
SOURCE: Insufficient gas for cottage during winter
Sure, there are lots of regulators, but one commonly used for gas grills should be fine. (maybe the brother in law used a step down regulator for natural gas, which won't work for you) I don't know your location, but another factor might be your outdoor temperature. If it is very cold, the liquid petroleum (LP) in your tank will not vaporize fast enough to satisfy demand, regardless of regulator size. A full tank in a warmer location would help immensely, but it is not real wise to have the tank indoors.
Posted on Dec 04, 2008
  • 1833 Answers
SOURCE: roper stove fes330 - element
One of the four burner switches has a stuck contact causing the indicatorlight to stay on. There are two types of infinite switches used in electricranges. Each one of the terminals on infinite switches is labeled. When theinfinite switch is turned to the ON position, terminal "P" contactcloses and completes a voltage path to the Pilot light and it glows. You canuse the process of elimination to find which switch is bad. Turn the breakeroff inside your house breaker box dedicated for the range or if it has a powercord you can unplug it. Once the voltage supply has be disconnected to therange, remove the control panel and disconnect just the one wire connected toterminal "P" and then turn the power back on. If the light stays off,replace that switch. If the light comes back on, disconnect power again andthen go to the next switch and remove the wire on terminal "P" andrepeat these steps until the light stays OFF and then you found the bad switch. Remember to disconnect thepower supply before removing and reinstalling the wires back onto terminal"P". Hope thiswill help you. Good Luck.
Posted on Jul 07, 2011
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
Just recently our 10 year old stove started smelling funny only when its on. the burner burns but the flame is yellow and was normally blue. I understand the air fuel mixture could be off, how Do I fix...
Gas flame on all gas appliance should burn clear blue.
Yellow flame means you need to clean the burners.
This applies to stoves, oven, furnaces, water heaters
I did a google search for: clean burners on gas stove.
There was more information and helpful tips on those links than I can honestly repeat here, including how-to videos.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on appliance.
Jan 03, 2011 | Hardware & Accessories
My ge gas stove works, but the flames just don't seem big enough. even on high, it takes forever to bring a covered pot of water to a boil. The flames seem even, mostly blue with some orange/yellow. any...
There can be poor air mix ( oxygen) for the flame to grow up. so remove the burner and use a good metal brush and air jet to clean off allt he crust and dirt of food lodged into the burners.
Now if the regulator gas fflow is down then your jet is blocked. If so you might have to remvoe the regulator to see that the jet is cleaned out . use a thin pin and airjet to clean.
Sep 16, 2010 | GE Spectra JGBP35 Gas Kitchen Range
My roper stove keeps clicking even when all knobs are off!!!
spilling water around spark control switches closed to burner control valves could cause that...may stop clicking in a day or so..or if on low flame setting the orfices on the burner head are carbon restricted? clean orfices with torchtip cleaners..
Jun 24, 2009 | Roper FGP210 Gas Kitchen Range
JGBP89SEMSS BURNER HEIGHT
Sounds right long as you did the conversion okay did you change the spring in the reg ? lp gas does burn lower than nat gas smaller blue flame . you could see if the aeration can be adjusted to the burners You could also check the pressure at the burners lp working pressure is 14in wg .
You could check the reg outside . That's all I got .
Mar 17, 2017 | GE JGBP88SEKSS Gas Kitchen Range
Zanussi gas stove
three problems with slow ignite on stoves.. first one is clean ignitors and burner caps. make sure that the caps and burners are correctly assemble. and make sure the stove is grounded correctly.. Do you flames have orange to yellow tips then there is a unburn carbon thst will form soot. soot productions is not achieving complete or efficient burning...again you may have dirty ot clogged burners..the flames should be all blue...let me know what you find out
Aug 31, 2007 | Kitchen Ranges
Funny Smell
ALL YOUR FLAMES SHOULD BE CLEAN BLUE FLAMES WITH NO WHITE OR YELLOW TIPS OR FLAMES !!!! YELLOW FLAME = DIRT OR PAINT? WHITE = LACK OF AIR SOUNDS LIKE YOUR STOVE IS NOT GETTING ENOUGH COMBUSTION AIR. INPROPER AIR ADJUSTMENTS OR LACK OF AIR WILL CAUSE A WHITE TIP ON THE FLAME ... THAT IS CARBON-MONIXIDE !!! A CLEAN BLUE FLAME EMITTS CARBON-DIOXIDE AND IS NORMAL. IF YOU USED AN AIR-GUN TO PAINT, CHANCES ARE YOUR BURNERS HAVE A SLIGHT COATING ON THEM AND HOPEFULLY WILL BURN OFF IN TIME. TRY OPENING ALL YOUR DOORS AND WINDOWS IN YOUR HOUSE ... AND TURN ALL BURNERS ON AND LET THEM BURN FOR AN HOUR. DO NOT LKEAVE SIGHT OF THE STOVE, BUT KEEP NEAR A OPEN WINDOW. NOTICE !!! MOST GAS COMPANIES WILL COME OUT AT NO CHARGE TO CHECK GAS, AND FOR CARBON-MONOXIDE.(C0) NOT (CO2).
Apr 28, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Roper FGP305 Gas Kitchen Range Logo
103 people viewed this question
Top Roper Kitchen Ranges Experts
Justin Duby
Justin Duby
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Are you a Roper Kitchen Range Expert? Answer questions, earn points and help others
