Question about Samsung HC-R4755W 47" HDTV
Yellow colored screen
I have a Samsung Hc-R4355w, In the middle of the screen is a perfect picture however around that the picture is yellowish. How can I fix this?
  • cwgarza Feb 19, 2009
    its a projection tv not a crt (tube)
    Novelist:
  • 184 Answers
This is a problem with the CRTs(picture tubes) or the coolant chamber(s) of same. The cost to replace the affected parts with be quite high. Expect to spend $400-600 to replace the CRT(s)
michtech
Posted on Feb 19, 2009
What causes the yellowish hue in the centre of the screen
There are several different types of projection sets: some use 3 picture tubes, red,green,blue--if this kind of set is what you have the coolant used in the blue tube is bad-----this type of problem leaves red and green which = yellow.
Most common in Samsung, Philips, Magnavox type sets.
If it is a newer set without picture tubes (a dlp style set) yellow in the middle of the screen would denote a damaged optical light engine.
Let me know brand, model number, date made----all are on back of set.
SD TECH
Feb 25, 2011 | Televison & Video
It maybe a filter problem go through the steps you took when installing the new bulb and check all then test.
Thanks J
Feb 03, 2008 | Toshiba TLP S30 Multimedia Projector
The blue and green are fading into one color
The problems ur tv having is call convergence problems,it dead.Tv have mis colors lines R,B,G any parts of the picture,have colors shadows or 3D pictures look alike?The tv convergence board have dead parts 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the Tv convergence board to fix it to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 31, 2010 | Samsung HC-R4355W 43 in. HDTV Television
Can't fix the color - really blue or really yellow.
Probably Blue CRT shot. Put tint back to center and turn color level to 0. Should look good black and white pic. If blue CRT shot, will look yellowish; usually more yellow around perimeter.
Apr 14, 2010 | Samsung HCM4215W 42" Rear Projection...
Darkened picture in perfect border around main
CHECK TO SEE IF YOU HAV THE TEX ON IN THE MEAU IF SO TURN IT OFF
Aug 24, 2009 | Televison & Video
I left my tv on when I went to bed and the picture was fine. Then I woke up and turned it off. When I came home and turned it back on, the picture was blurry all around the tv except in the middle of the...
is the blurry all around the picture have different color like a smear of red, blue or yellow?
if it is i think the posistor of your tv is not working. it is the one who activate the degaussing coil around the picture tube the prevent color miss-landing upon opening your tv set.
Aug 11, 2009 | Samsung SlimFit TX-S3082WH 30" TV
RED CONVERGENCE SCREEN PATTERN BOWING AND CAN'T ADJUST
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 13, 2009 | Samsung HC-P4752W 47" Rear Projection...
Samsung hc-p4252w - yellow tinge on left side of screen
If you put magnet speaker ( Standard speaker) near the TV, first you must move that speaker away from your TV because this will cause your colour TV screen color scattered. Then switch off your TV for 5 hrs. then switch it ON again your problem will be solved if the degaussing coil working.
Jun 01, 2009 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W 47" projection TV distortion & yellow?
I think you have a fault on the chroma board and on the picture frame board. If you can trace it yourself try these two locations otherwise call out a competant technician. hope this helps.
Sep 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
Help
you need a convergence PCB. your model uses the type 4 samsung convergence PC Board. You can get a new replacement at the following link and they provide free tech support and free shipping. Here is the link.
http://servicemanuals.vstore.ca/
Jun 30, 2008 | Samsung HC-P4241W 42" Rear Projection...
Samsung HC-R4755W 47" HDTV Logo
252 people viewed this question
Henry  Thomas
Henry Thomas
