Question about Linksys Ultra RangePlus Wireless Routr Router
Linksys rangeplus drops wireless connection ever 5-10 mins
Have the rangeplus wireless router and my wife's DELL 1525 laptop works just find wireless anywhere (other homes, work, panarea bread, etc), but at home the connection constantly goes down and comes back every 5 mins or so... drive us nuts !!! and the DELL is brand new and works everywhere else....
  • Linksys Master
  • 4,338 Answers
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware. For instructions, click here
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Mar 02, 2009
My Alienware M14X, running Windows 7, cannot connect successfully to the Internet through my Linksys Rangeplus WRT110 wireless router. It can pick and and technically connect to the router's signal,...
try reseting the router (pressing the button the size of the tip of a pen)
Do not try this if this is the main internet router (unless you dont have any choice).
It might need to be reset from Server side (your phone/internett company).
There might be some setings lost and you need to set a new password (the old one back)
Aug 23, 2011 | Linksys RangePlus WRT100 Wireless Router
I currently have 2 sony computers connected to my Linksys WRT310N Router. I just bought a new Dell Laptop for my home business and I can't get it connected.
I'm assuming your new computer uses Win 7, so try opening Control Panel, Network and Sharing Center - then elect to set up a new wireless network. You should 'see' your wifi network - if not, then come back with that info & we'll take it from there...
May 03, 2011 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
Linksys WRT100 won't connect wirelessly
Has the adapter in the laptop been enabled?
Ryan Frame
Creative Energy Associates Technical Center
Sep 05, 2009 | Linksys RangePlus WRT100 Wireless Router
Linksys Rangeplus works fine for short periods
improve your PC's cooling system and your wireless adapter will work fine. you can attach a USB cooling fan to do the trick.
Jan 25, 2009 | Linksys Rangeplus Wireless Pc Adapter
Wep key
You need to remove the wep key from the linksys configuration
to enter the configuration of the router, in Iexplorer, go to http://192.168.1.1
there must be a security access confguration than refer to wep active/inactive
switch it off, it should go.
Nov 20, 2008 | Computers & Internet
Internet connection
What is the model or the brand of your modem from Verizon?
Can your computer get online if its wired to the router?
Jul 21, 2008 | Linksys Ultra RangePlus Wireless Routr...
Can not use internet wirelessly all the time with Linksys rangeplus wireless router
Sounds to me like your modem is hanging up on you. In the software to configure the modem tell it to stay connected all the time.
BXH_5
Jun 17, 2008 | Computers & Internet
Can not use Internet with new Linksys rangeplus wireless router
Okay chances are your 2wire's ip address is conflicting with your router's ip address. Set up your router to use 192.168.2.1. Save the settings then everything should work for you.
Jun 14, 2008 | Computers & Internet
Linksys Ultra RangePlus Wireless Routr Router Logo
170 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
