Question about HEWLETT-PACKARD Hewlett Packard Compaq Presario SR1130NX PC Desktop
Mouse won't work on Presario
Even changing the mouse using different USB ports for mouse doesn't fix it
  • HEWLETT-PACKARD Master
  • 5,660 Answers
Does the I/O area at the back of the computer, have a PS/2 port?
http://en.wikipedia.org/wiki/PS/2_connector
Suggest try using a PS/2 to USB adapter,
http://www.directron.com/diusadfrusbf.html
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Feb 27, 2013
Logitech wireless laser mouse not working my computer
If your computer has Windows XP or later your computer should automatically install generic drivers for it so that it works. So if that's the case and it still doesn't work then try changing the battery in the mouse, or plug the wireless adapter for the mouse in a different USB port.
Jun 25, 2012 | Acer Computers & Internet
Usb port on presario F500 quit working, they are seen by device manager but will not reconize a flashdrive when incerted, a mouse or any thing else. Using win 7,64 bit t3500 cpu.
This should be pretty easy to fix. I have seen this many times before. Here's what to do:
Go into device manager and expand 'universal serial bus controllers'.
Start at the very bottom, and start deleting the usb root hubs one by one. You will lose your touchpad control at some point, as the touchpad is actually a usb device. One of thwo things will happen.
1. The usb hubs will automatically be re-detected and re-installed.
2. You will just lose touchpad control after deleting one of the root hubs. If this happens, then shut down using the power button, and restart. Th usb hubs will be reinstalled once you log back into windows. Please let me know if this doesn't fix it.
Joe
Apr 07, 2012 | Compaq Computers & Internet
Several times each day my mouse on my laptop (Dell Lattitude E5510) becomes unresponsive. I can then use the touch pad to restore my control or the mouse works if I switch USB ports. It doesn't se
Some mouses stop responding if you do not use it for a few minutes. This is usually a battery saving feature. Usually all you got to do is use the scroll button to reactivate the mouse by scrolling up or down. This will bring the mouse back to life. When you change the ports you are actually doing the same thing (reactivating). Also check whether battery needs changing.
Mar 01, 2012 | Computers & Internet
Mouse pointer has stucked on prisario c 500 Lalptop
The first thing I would do is try a different port to plug in the mouse.
Then if that doesn't work, try a different mouse.
You could also do a system restore back to when it worked.
Feb 20, 2012 | HP Compaq Presario SR1230NX (PJ518AA) PC...
Team promark keyboard won't work
If it has a USB plug, try attaching it through a different port hub, i.e. not the usb port right next to the one that didn't work. If that doesn't work, test the usb port with something else first. If the USB port is not the problem, you may need to download a driver for the keyboard.
Jan 03, 2012 | Team International Team ProMark Carolina...
MOUSE WILL NOT WORK
You haven't said what kind of mouse you have or whether it used to work.
I'll offer some suggestions for the most common problems:
If it used to work but now doesn't, try a system restore back to when it did work.
If that doesn't work--are you using a wireless mouse? If so, are the batteries fresh and are they inserted correctly?
If you are using a wireless mouse, have you pushed the little "connect" button on the bottom?
You haven't said, but is the other mouse a wireless one or a USB mouse? If your USB mouse doesn't work, try another USB port. If you go into the device manager, do you see a "human interface device" or a "mouse" listed? If so, it will tell you the system recognizes the device. If that is missing, there is a good chance the mouse is dead.
Oct 31, 2011 | Computers & Internet
I cannot get my keyboard or my mouse to work with my dell computer. what can i do?
Please add more information to get specific assistance. Are these wireless devices? If wired, do they use USB or PS/2 connections.
For wireless devices, try replacing the batteries and resynching to the receiver. (You may want to check putting the receiver in different USB ports.)
For wired devices, disconnect and reconnect. For PS/2 devices, you will need to restart the computer to check if the devices work. For USB devices, try connecting to different USB ports.
Next step, try using a different keyboard and mouse (that work on another computer (stick to USB or PS/2 to match the current pair)). Try a wired set if the problem is with a wireless pair. If those work, continue diagnostics on the wireless keyboard and mouse. Check if the mouse and keyboard work on another computer. If they don't work with another computer, replace them.
If another USB keyboard and mouse pair don't work in any port, your USB ports may have failed. Check if even one port works enough to access the Device Manager. (Start > Control Panel > Hardware and Sound > Device Manager (Win7); similar directions in other versions of Windows) Check for a problem with the drivers (For USB ports, scroll down to the USB drivers and look for a triangle with a yellow exclamation point or red x). Try to update the driver or roll it back. If that doesn't help and one USB port works, a USB hub may solve the problem.
Otherwise if the USB or PS/2 ports do not work with any devices and the driver fix doesn't work, then I'd suspect a problem with the ports on the motherboard. Replace the motherboard/computer.
I hope this helps.
Sep 12, 2011 | Dell Computers & Internet
I have a USB Cable connected to it but it says the printer is off line. I've tried different USB Cables and it just won't print. I'm lost please help me!
please assure the number of port USB in setting properties with your plugin the your lap top.
edy_bubat_4.jpgif doesn't changed, you can email me....
May 23, 2011 | Lexmark E332n Laser Printer
Mouse freezes
Is it wireless mouse or usb? or serial connector? if its usb mouse try to use different usb port and check the status, if its wirless it will be connection or battery problem, try to charge it, if its serial connecter try change the mouse . Or use the keyboard port for mouse and see the difference. if all this not work let me know so i can show you the windows steps in order to fix it.
Best regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 02, 2009 | E-Machines eMachines T3830 PC Desktop
HEWLETT-PACKARD Hewlett Packard Compaq Presario SR1130NX PC Desktop Logo
66 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Marvin
Marvin
john smith
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
