Question about Velbon DF-60 Tripod
Removing tripod pan head
Hi. I have a Velbon PH 460B tripod with a pannhead. I purchased a Velbon 51Q ball head as an upgrade. How do I remove the panhead from the Velbon unit?
5 Suggested Answers
SOURCE: How to remove pan head from velbon 530, it feels
I have the Hakuba HG-503MX which came with basically the same pan head you have already attached to the center column. First remove the center column from the tripod, with the pan head attached. Tighten the knob that prevents the pan head unit from rotating 360 degrees on the center column and gripping the head with one a hand and the center column near the plastic plate firmly twisting the head counter clockwise. The pan head will unscrew from the plastic plate which sits on top of the center column, given enough force. My pan head was also very tightly screwed onto the shaft, since it came already attached to the tripod. Hope this is helpful.
Posted on Oct 17, 2009
SOURCE: I have a velbon Victory 460Q tripod with a PH-252Q
www,digitalcamerawarehouse.com.au
Posted on Mar 09, 2011
SOURCE: Velbon DV 7000 replacement parts
Hi I need a locking clip for one of the Velbon Tripod legs any suggestions?
cheers
Wayne
Posted on May 20, 2011
I have a velbon SHerpa 200r Im trying to find a head for or sell for parts
Posted on Aug 05, 2013
How to remove stock pan head on velbon el carmagne 530 so I can replace it with a ball head?
I presume this is a tripod, although you have not stated. On good quality tripods, the head attached to the centre column with a screw thread, either 1/4" or 3/8". Grasp the centre column firmly, and rotate the existing head anti-clockwise, first checking to ensure there are no grub screws restricting its movement. When you have removed it, attach the replacement.
Oct 15, 2017 | Velbon Photography
How can I dissasemble the head of the tripod to clean it and lubricate it and what lubricant should I use for a smooth panning?
i think these where made by rocket scientists!!!
twist the panning handle counter clockwise till it comes out...on the side should be 2 small covers for the screws remove cover and screws BE CAREFUL of the tension tab (holds camera on) lube with silicone or any automotive grease.... reverse instructions!
Nov 11, 2014 | Velbon DF-60 Tripod
How to remove pan head from velbon 530, it feels very tight
Aug 10, 2009 | Velbon EL Carmagne 530 Tripod
cheers
Wayne
Apr 15, 2009 | Velbon Sherpa DV7000 Tripod
Tripod plate leveler thumb screw
Try tripodquickrelease.com. They sell some repair parts for velbon tripods.
Feb 27, 2008 | Velbon Victory 550 Grounder Tripod with...
Missing part on Tripod - Velbon Victory 550
Where can I get parts?
I got from friend a Velbon Victory 550 tripod. The handle that prevent the head from tilting is missing, and so is a piece of plastic that apparently held the rod upon which the head of the tripod is placed from shaking.
thank you
Jan 20, 2008 | Velbon Victory 550 Grounder Tripod with...
Need parts to repair pan handle
I just had this problem! I took it to Ace hardware and the guys helped me out, big time. I have a PH-358 panhandle and the same piece fell of during a shoot into some brush and dirt outside.
We (they) fixed it using a #6 metric bolt and butterfly wing nut along with two grommets (3/8 ID and 5/8 OD). It worked perfectly! Not only does it hold the handle together but you can tighten or loosen the handle as well using the butterfly wing nut.
Sep 17, 2007 | Velbon VideoMate Deluxe Heavy-Duty...
Velbon DF-60 Tripod Logo
183 people viewed this question
Top Velbon Photography Experts
JP Services
JP Services
Bill Eager
Are you a Velbon Photography Expert? Answer questions, earn points and help others
