Question about Car Audio & Video
Hi pitch tone on old AM car radio
I have an old, original AM car radio c 1972 installed in a MGB. The radio is marked Bendix 2BAMBL. Since it's the radio that came with the car I'm trying to fix it.
The unit powers up OK. When turned on it ''squeals''...probably 3Khz to 5 KHz tone. The audio amp works. I can find and hear one or two AM stations very weakly (they are local stations so should be OK).
The radio schematics are available online thru Sams but before I lay out $30 I'm just wondering if a knowledgable AM radio receiver person could suggest possible problems. Could it be something with the IF section?
  • Anonymous Mar 25, 2009
    I have a high pitch tone that comes on my fm stations in my 1991 stealth
Having a high pitch whistle shows that the unit is somewhat unstable somewhere in the circuitry causing it to oscillate where it shouldn't, due to one or more components going faulty. What I would suggest is open up the unit, clean the circuit board thoroughly and replace all the electro capacitors with ones of same value, sometimes problems occur in radios this old because the capacitors dry up, like oscillation may happen if the capacitor that is used to smooth the voltage that feeds the automatic RF gain loses value or goes open circuit. Sometimes IF transformers can go open circuit at random (which can cause oscillation and weak signal too), and so do transistors, which can be hard to track down unless you have an oscilloscope?!? Are there any cracked soldering joints? to check for dry joints; use a plastic tool to tap, press, and rub on the solder side of the board. Having all the gear??? You go through each stage to see if it is working properly. Dont fret too much if you cant fix it yourself due to not having the gear, sometimes multimeter measurements may help, and also blindly poking your finger around... maybe, but it is very challenging and does not find all faults, if you have any friends who are Amateur radio operators, they would have the gear to help you as they always tinker with radios and actually make some of their gear, otherwise I am sure that TV repair persons are fully qualified to fix it for you, with a price! have fun ;)
Posted on Apr 01, 2009
Phone line repeatedly without reason goes to "in use" and will not go to a dial tone when receiver is picked up. the phone line does not do this when this att phone is not plugged into phone line
My first question would be, have you recently installed any after marked speakers, or radio into the car? You could have a grounded speaker wire, or connections not properly paired that could be causing the issues.
Jul 14, 2015 | Vtech AT&T CL82313 3 handset cordless...
Diagram of distributer to coil for a 1955 nash
Wire from the ignition points goes to the negative side of the coil. It may be marked #1 on the coil. Power goes to the + side of the coil which might be marked # 15. Should be the only wire from the distributor to the coil. Real good modification for your Metro is replace the transmission with a fully syncro unit out of a 68 or newer MGB. You can also replace the engine with a 68 or newer MGB 5 main bearing engine and keep the positive ground electrical. The engine are identical on the outside but much better power and reliability. It will look all original but drive like a dream. I want a Metro convertible at some point in my life. I love those cars.
Oct 21, 2014 | Cars & Trucks
How to wire tachometre mgb gt 1972
The tach goes to the power and the ground and the signal lead goes to the negative terminal of the coil.
Nov 05, 2012 | Cars & Trucks
How to wire in my tachometre on my mgb gt 1972
your tacho should have 4 wires 1 black =ground 2 green=ignition 3 white/black =ignition coil contact breaker side 4 red=illumination make sur your tacho is for the correct system ie. pos or neg ground
Oct 23, 2012 | MG B Cars & Trucks
I hooked up my cb radio. my friend could hear me i couldnt hear h
Is the tone high pitch? if so he was too close to you (feedback).
If the tone was low then could be a voltage problem, or a microphone fault.
more like to be an incorrectly wired microphone if the radio is new?
Jun 18, 2010 | Radio Shack TRC-521 CB Radio
High pitched ear piercing tone when turned on.
sounds like you have a crossed wire somewhere
May 19, 2009 | Car Audio & Video
Tone in sirius radio using aux. input
Do you have a thicker audio cable you can use? It might cut down on the interference that way.
Mar 16, 2009 | Sirius Satellite Radio Receiver
High pitched tone comes on whenever radio is turn on
Hi,welcome to fix ya. if this is a bose system you have a bad amp behind the rear seat they short out inside and cause the speakers to emit a high pich squeel. you can buy these amps on e-bay pretty cheaply or send it to bose for repair .
Nov 30, 2008 | 1994 Acura Legend
Car Audio & Video Logo
210 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
