Oregon Scientific BBQ Thermometer Logo
Anonymous Posted on Feb 27, 2013
I have Model AW131 Grill Right wireless Thermometer. It shows no transmission signal no matter what I do. Any suggestions. It is brand new.
The batteries are new out of the package. I have tried to move closer with the reciever and farther away. still no transmission.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 21, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
677
Points
You are supposed to hit the RESET button within 1 minute of each other to sync the products together.
The reset buttons are inside where the batteries are on both units. Hit them withing a few seconds of each other and they will sync. Then you should see an antenna symbol on top left of the receiver's screen.
  • Kelli Barr
    Kelli Barr May 15, 2014
    Thank you SO much for posting that answer, Paul. I could not figure this out so I googled. Did what you said, and mine works again! Unfortunately I spent $20 on a new probe before I did the research. Live and learn. :)
susan godbey
Level 1:
New Friend:
  • Posted on Jan 02, 2015
susan godbey
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
677
Points
Thank you for posting this answer. It's exactly what we needed to know!
I hav an AW131 and need to know how to change from C to F
Inside the battery compartment on the AW129 is a slide switch to change the temperature from C to F.
No current temp
Inside the battery case is a "reset" hole. Use a paper clip and push it in while the temperature probe is on. The screen will flash and the unit will synchronize once again with the probe.
ACU RITE Wireless Thermometer Model L5C0668TX cant set the date
I have misplaced the user manual for the
Acurite L5C0668TXACU RITE Wireless Thermometer Model L5C0668TX. Where can I get another?
My digital thermometer on my brand new echelon 660 has an erradic display of the actual temp for all 3 zones even after calibration. The temp probes are not in contact with anything to short it out. I...
Steve, these thermometers have been plagued with problems and short of a total replacement of the thermometer module, there is not quick fix. Since yours is new and and still under warranty, contact the R H Peterson Company, the manufacturer of Fire Magic Grills (800) 332-3973 and ask for Technical Service. As they are the ones who make the determination on a total replacement of the module or not. Be sure to have the grill's Model Number and Serial Number handy, when you call.
Thanks for choosing FixYa.
I replaced the porcelain enameler flavorizer bars on my Weber genesis gas grll less than a year ago--four out of the five bars are bent and misshapen--no longer straight. Why??? They still look brand...
You are overheating the grill - make sure the thermometer is working on the right side of the grill lid. You should not heat above 550F (preheat) and you should not cook above 500F.
Secondly, you must clean out the drip tray (not just the aluminum foil tray but the bigger tray it is attached to (it slides out the front of the grill too). The grease that piles up on this tray can catch fire and overheat the grill (including the flavorizor bars).
Last suggestion is to get stainless steel bars next time (make sure you get the size that fits your grill because the stainless steel sizes also come a bit longer). The stainless bars are high temperature stainless steel and do not corrode. They are a bit heavier and cost about 30 to 50% more but well worth it. They clean up very easily and transfer heat to the cooking surface well. Keep them clean to keep the cooking surface hotter.
I just replaced and old worn out built in Turbo with a new model. Both are propane versions. After installing the new model works fine but does not generate enough heat. With all four burners on high...
If you are using a 20Lb LP Gas Tank, rather than hard piped to the grill or you're using Natural Ga, here in may lie the problem. If it is Natural Gas, was the grill converted or ordered for Natural Gas? If not, that's why it' not heating well.
If you're using a 20Lb grill tank, do the following:
1. Turn the Propane Tank Valve OFF and disconnect the hose from the tank.
2.Wait 5 minutes and reconnect the hose to the tank. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
3. Once the valve is fully open, light the burner farthest from the tank first and turn the control knob to HIGH. Does the flame height look correct for being on HIGH? If so, light the remaining burners the same way, Do all the flame hieghts look correct? If co, close the lid and allow the grill to preheat for at least 20 minutes. Did the grill thermometer go higher that 200 degrees F. If so, you solved the problem. Always remember to turn the tank valve ON very, very slowly.
If that did not solve the problem, the thermometer may be incorrect/faulty. I had this happen myself, with a new grill. To test it, invest $5.00 in an Oven Thermometer, like you use in a regular oven, It sits on the oven shelf. But, in this case it will sit on the center of the grill's cooking grates.
Light the grill and preheat it for 20 minutes. Loo k at the grill thermometer and then lift the hood and look at the oven thermometer. The oven thermometer may be as much as 200 degrees higher. That's because it's actually reading the temperature at cooking level, not up in the air, where the grill thermometer is.
I never replaced my grill thermometer. I continue to use the inexpensive oven thermometer, because it's giving me the actual temperature, at the level I'm grilling at. And I, do a lot of grilling.
Hope this helped you troubleshoot and solve the problem. Pleas let me know and Happy Grilling.
No matter how long I let it heat up never goes past 250 degrees
First, do the flames on the burners, when they're on high, appear to be normal? Or are they lower than normal, despite the burner knob(s) being turned to high? Do you turn the tank OFF after grilling each time?
If you answered yes, to the last two questions, here's what you need to do. Turn the tank valve OFF. Disconnect the hose from the tank. Wait 5 minutes and reconnect the hose. Turn the tank valve ON VERY, VERY SLOWLY, until it's completely open. Light each burner individually and turn the burner knob to high. Once all the burners are lit and turned to high, do the flames look taller than before?
If so, you just solved your problem. Remember to turn the tank valve on VERY, VERY SLOWLY each time you turn it ON.
If the above is not the problem, the grill thermostat may be faulty. To test this theory, purchase an inexpensive Oven Thermometer and place it on the grill grates, when preheating your grill. Close the lid of the grill and ten minutes later, take a look at the Oven Thermometer and compare it's temperature with the grill thermometer. If the grill thermometer is reading significantly lower than the Oven thermometer, you need to replace the grill thermometer. You can purchase one directly form Weber.
Hope this helped you solve your problem. Happy Grilling!
Hi Top oven only gets warm no matter where you set
I have a 720ef and the top oven is not that good. The wattage rating is low, from memory about 750 watts and it takes a month of Sundays to warm up. I bought an oven thermometer from Lakeland a little while ago and when the top oven is turned on the Lakeland thermometer is showing that the oven thermomostat is running the oven at 20 degrees below what it is set to. If the thermostat neon is clicking off and on, then the thermostat/oven is working, albeit not as we expect.
3helpful
My acu-rite wireless thermometer model #00604RX isn't capturing the wireless sensor signal..both have new batteries and worked before changing old battery..reset the buttons too...help
Double check the batteries and the direction in which they are installed. If there is one backwards in the sending unit that is outside, it will not send a signal. Also, there is typically one battery in the indoor unit that is responsible for receiving the signal from the outdoor unit. If all of the batteries are in correctly except that battery, you will see the display, but will not get the data transmitted from the outside sending unit.
I have a Toshiba L25 laptop and a D-Lin Air DWL-650 wireless card. I'm not getting the best connection with the wireless card while my other computer has a much stronger signal. I'd like a recommendation...
im assuming its a cardbus adapter right? well that model is a wireless b signal, which isnt very strong, so any wireless g model should have a much stronger signal. it doesnt matter which one it is, as long as its wireless g, which most new cards are. hope this helps, goodluck
Top Oregon Scientific Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Oregon Scientific Home Expert? Answer questions, earn points and help others
