Question about Dishwashers
Dishwasher isn't turning on
Kenmore Elite Dishwasher model#: 665.16592201 serial #: FP1003581
Dishwasher doesn’t operate. Light on front is lit with “- -“ If you push the cancel button on the front, it acts as a toggle switch either showing the “- -“ indication or turning it so no lights are on. On the top indicators either the “smart wash” led flashes or both the “quick wash” and “smart wash” leds falsh. If I move the latch up to open the dishwasher door there is no change in the display but as I release down the second dash in the display turns momentarily to a 2 so it looks like “- 2”
Thank you for your help!
George
  • george284 Feb 23, 2009
    Kenmore Elite Dishwasher model#: 665.16592201 serial #: FP1003581Dishwasher was operating fine until a sudden change in the electronic control function. It is plugged in with no external fuse issue, and doesn?t operate because the buttons are inoperable. Push and select as you might, the light indicators on the front is lit with ?- -? If you push the cancel button on the front, it acts as a toggle switch either showing the ?- -? indication or turning it so no lights are on. On the top of the door indicators show either the ?smart wash? led flashing or both the ?quick wash? and ?smart wash? leds flashing. If I move the latch up to open the dishwasher door there is no change in the display but as I release down the second dash in the display turns momentarily to a 2 so it looks like ?- 2?I don't want to buy parts until I'm advised and can narrow the parts down but I have to think it is either the a) electronic control assembly b) the panel control or c) something to do with the handle. My guess is it is probably not the latter because the handle switch sounds fine and feels like a switch clicking when lifted and released slowly but, who knows for sure. Thank you for your help!George
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
A couple of ideas yo may want to consider:
  • Initially, I have to agree on your 1st and 2nd suspects. However basing on your subsequent post that the display did change (even momentarily) to -2 in reaction to an action you took, leads me to think that the logic controller board is still doing its job, sensing conditions and displaying error message except that one of its input is causing erroneous conditions.
  • Offhand, I am more inclined to suspect that at least one of your buttons/keypad is stuck on a pressed position in the control panel.
Incidentally, the door switch could be tested with a continuity tester.
Good luck and thank you for using FixYa.
Posted on Mar 01, 2009
  • 547 Answers
Please try unpluging power and wait 5 mins befor pluging back in
Posted on Feb 23, 2009
  • 6,784 Answers
These are a few check marks you can use. the code represents electric motor failure but, i would run the check marks to be sure.
Is the door closed tightly and latched?
Is there power to the dishwasher? Has a household fuse
blown or circuit breaker tripped?
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes.
Is the water shutoff valve (if installed) turned on?
It is normal for certain cycles to repeatedly pause for several
seconds during the main wash.
Posted on Feb 19, 2009
    Genius:
  • 1,075 Answers
George;; switch it off for 5 minutes then turn it back on;;;I mean at the main supply,it should re-set its self if not sorry it needs an engineer to fix it.adrian
    Genius:
  • 1,011 Answers
Sir,
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.
Reconnect power to the range and observe for an hour.
If the error code reappear - replace the control board.
If not - replace the membrane switch.
If you have warranty with your model better contact manufactrer's for claim...
thanks good luck
  • 1,800 Answers
    Brigadier General:
  • 8,619 Answers
Hi
Kindly turn  it off for 10mins and then after restarting press the stop button twice.
  • Rylee Smith
    Rylee Smith Feb 19, 2009
    If restarting doesn't help then please check for the wiring and connections. the thermal fuse on the control panel.
    Also check for the thermal fuse which is in a white box and
  • Rylee Smith
    Also check for the thermal fuse which is in a white box and There is a couple of wires that lead up to a white box with the fuse in it.
    Please ask for any clarifications
    Thanks
    Rylee
What does code F2E2 mean on the display
My Kenmore Elite dishwasher is showing code F2E2..What ...
www.shopyourway.com > Agafia Reutov > Questions
The F2E2 error can be frustrating. The problem is the User Interface is not communicating with the main control board. This error is mainly caused by a poor ...
Kenmore elite service code f2e2 ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Te hose came off the bottom of the washer, then I got the service code f2e2. ... I have a kenmore elite dishwasher model 665.1396 ERROR CODE F2E2 ?
Oct 22, 2015 | Dishwashers
Kenmore Elite Dishwasher will not start
Consider examine inside there is maybe fuse busted on the panel or in the circuit through the control panel of the machine.
Feb 05, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore elite dishwasher manual
The cancel light is on because the cycle maybe paused or canceled. The lit red button should say Cancel/Drain. If you already tried to press start and if it won't finish the cycle then try pressing the Cancel/Drain to drain and start over.
Aug 15, 2014 | Kenmore Elite Stainless Steel 24" BuiltIn...
Kenmore 665 17033400 Elite dishwasher clean light flashes 7 times and it wont run. i used the reset combination, all lights lit and stayed lit until i pressed reset. Then it started a wash. now the wash...
That signals an issue with a faulty heater &/or heater drive circuit.
(that info comes from their troubleshooting guide)
I ran into it this weekend and discovered that the heater coil in the bottom of the washer was broken.
Jan 14, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
Need the model number of the Kenmore Elite dishwasher 1378(2)
The model number will be something like 110.123456
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 25, 2008 | Kenmore 13789 / 13782 Dishwasher
Kenmore Elite Dishwasher Problem
I had this same problem so I took the front panel off to access the thermal fuse.  What I found instead was that food had become lodged in the door latch which was keeping the door safety switch from operating properly.  I took a thin screwdriver and removed the food from the cavity.  Since you did not have the problem in your first five years the cavity just might be the problem since that is about the amount of time it took me to get too much food stuck in mine as well. This solution took five seconds and requires no disassembly.
Oct 09, 2008 | Dishwashers
Dishwashers Logo
623 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
