Question about Zebra TLP 2844 Label Printer
PROBLEM:PRINTER IS ONLY PRINTING 1/2 - Zebra TLP 2844 Label Printer
1-shut the printer down and hold the feed button
2-power up the printer 3-the printer will print data about the firmware version...
4- when it stops press feed button to get out of dump
5- then press feed again the printer should feed label by label
6- if it does not work try to download the firmware from the website.
Regards
Posted on May 19, 2010
My printer isn't printing
Solution 1 On the Computer:
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Click Open or See What's Printing 3. Click the option that says Printer on the upper left corner of the window that pops up. 4. Make sure the only thing that is checked under that menu is Set As Default Printer. 5. If Use Printer Offline or Pause Printing has a check mark. Uncheck it.
Try printing again. I hope this helped.
Solution2 On the Printer:
1. Go to Set-up 2. Go to Network Set-Up 3. Choose Restore Network Defaults 4. GO Back and then Choose WIreless Set-Up WIzard
Feb 03, 2011 | HP DeskJet 3745 Printer
Hp officejet 3680 not printing
Feb 03, 2011 | HP J3680 Officejet All In One Printer
My printer continually goes to offline what is the solution
Dec 13, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Change from printing on both sides of paper to one
Use the LCD panel and the buttons on the printer to change from 1+1->1 to 1->1 printing.
Jul 31, 2010 | Canon iR 2022i Printer
Printing and counting problem with Zebra ZM400. We have connected a Zebra ZM400 to our network and we now have a problem with printing. When we print he prints the labels 1 by 1 instead of de total...
if you sending a file (ex. pdf or picture). to the printer, can do this, if you send the proper format with normal fonts (caracteres))to the printer, work fine. build new label from zebradesigner
May 20, 2010 | Zebra Z4Mplus Label Printer
When printing lines are running through the sentences.I have a brother mfc440cn printer
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Dec 09, 2009 | Brother MFC-440CN InkJet Printer
920c is printing very slow, like 1 copy in 5
it is possible that your printer settings is set print high quality for a photo paper. try to check if you are printing on plain paper, select paper type as plain paper and quality to normal.
Nov 06, 2009 | HP DeskJet 920c InkJet Printer
Paper does not feed from Tray 1.
Check your printer settings.
Sometimes if your printer or the program you are printing from has the paper source set to "Letter" it waits for you to press the continue key on the printer which allows you to insert headed note paper before printing.
If it is set to letter, change it to A4 and this should solve your problem
You may need to change this in both the printer settings and/or each program from which you are printing
Jan 12, 2009 | Lexmark C532dn Laser Printer
Printer cuts off top 1 inch of PDF document
Go to the printer properties and try setting it up with border less printing.
Cheers
May 23, 2008 | Lexmark X4270 All-In-One InkJet Printer
Zebra TLP 2844 Label Printer Logo
103 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
