Question about GE 24 in. GSD2000Z Built-in Dishwasher
Leaks drips under solenoid when dishwasher clicks to drain
  • 70 Answers
Any leaks from the pump/motor assbly requires
the pump/motor to be replaced.
part number:WD26X10013 approx cost is 155.00US
Posted on Feb 19, 2009
  • 547 Answers
Replace the seal
Start light flashing. Dishwasher wont start
I'm guessing as you did not list the model number. Something similar happened on mine. Due to a freeze, there was a small crack in the inlet and water had slowly leaked. As a safety feature, the Asko has a tray under the dishwasher inside the overall dimensions. It has a float. When the float rises, the drain pump starts and the dishwasher will not start. In my case, the drip pan is not connected to the drain which gave me the drain sound, but did nothing to remove the leaky water.
I suggest you take the front bottom panel off the dishwasher and check for water/leaks.
Oct 29, 2014 | Asko 24 in. D3121XL Free-standing...
GE dishwasher inlet valve leaking
see this steps and fix it. God bless you
Dishwasher Not Leveled
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily.
Door Seal
This is not very common in most dishwashers. To check this look for rips and distortion of the seal. If it is ripped or distorted you will need to replace.
Dispenser Seal
This is a more common place for a leak to develop. This is easy to check, remove the front panel and carefully inspect around the seal for water dripping or stainage. If any is found replace the dispenser gasket.
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace water inlet valve.
Drain / Circulating Pump
Some dishwashers have separate drain and circulating pumps Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. Follow the tutorial on replacing the pump
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust the switch until properly aligned.
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the toe kick and maybe the front panel to inspect.
Jul 13, 2013 | GE Dishwashers
How can I get to the inside
If your dishwasher is Leaking check the following
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily. Watch the video on leveling your diswasher
Door Seal
Dispenser Seal
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace the water inlet valve
Some dishwashers have separate drain and circulating pump. Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. .
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust switch until properly aligned.
Door Hinges
Drain:
This is usually caused by a syphon effect or your drain line improperly installed. You can not attach your drain line from the dishwasher without having a loop in it. If you go directly under the floor with your drain hose, all water will drain out upon fill. Safest and recommended installation of drain hose is to your kitchen sink and attach the hose somewhere so it is higher then the bottom of your sinks.
be65763a-411f-4910-88d8-4712ce0a8d7e.gifda9b96d7-ebd5-4e03-8f4c-4d0c49063e70.gifGod bless you, Use the VOM very important
Apr 05, 2013 | Kenwood Dishwashers
Water wont drain
You use your dishwasher so often with no problems that any issue can seem like a major disaster. But you can fix a drainage problem with a trip to the hardware or plumbing supply store and a few minutes of effort. If your dishwasher doesn't drain properly, the drain hose is probably kinked or damaged, interfering with the flow of water out of the dishwasher. You can fix the problem by replacing the drain hose yourself.
Difficulty: Moderately Easy Instructions And 4 Tools (Material) Needed To Solve The Drain Problem.
  • Shallow dish,Pliers or screwdriver,Replacement drain hose,Replacement hose clamps
  1. Turn off the water supply to the dishwasher. Turn off the dishwasher's power supply by unplugging it (under the sink) or turning off the appropriate circuit breaker.
  2. Pull the dishwasher all the way out from the cabinet so you can access the drain hose and pump near the back.
  3. Locate the drain pump and hose. The drain hose is the larger of the two hoses attached to the dishwasher and is generally located close to the bottom back of the dishwasher.
  4. Place a shallow dish under the drain pump. Loosen the clamp on the drain hose close to the drain pump, using pliers or a screwdriver. Pull the drain hose off of the pump, allowing any water to drip into the dish below.
  5. Remove the other end of the drain hose from the garbage disposal or drain by loosening the hose clamp and pulling the hose off of the connection.
  6. Attach the replacement hose to the drain pump and the drain or garbage disposal. Attach new hose clamps, and tighten them to hold them in place.
  7. Turn the power and water back on, and run the dishwasher through a cycle to make sure that the dishwasher drains properly and the hose doesn't leak. Tighten the hose clamps if you find any leaks.
Good luck and thanks for using fixya.
Jan 30, 2011 | Kenmore Dishwashers
Dishwasher leak dripping down side of drain solenoid
it is possible that the plastic has developed a crack at the end of the threaded section
if you are handy with tools , turn the water off and remove that assembly( turn the power off at the plug)
check with a service agent spares department first as that part may not be available because of the age
Jun 13, 2017 | GE 24 in. GSD2220Z Built-in Dishwasher
Wont drain hear clicking noise
Hi
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 03, 2009 | Electrolux Kenmore 24 in. Built-In...
Kenmore Dishwasher won't drain
If you opened and closed the door and it started, that sounds like a bad, door switch in the console.
But you did hear a hum sound when it tryed to drain, it could be the drain solenoid, or the motor/pump assembly.
Take off the bottom access and look at the solenoid when it starts to drain, the piston in the solenoid should move freely, up and down with the white drain flapper that it connects to.
Also check for bad wiring connections at the power junction box where the power hooks up to it under the dishwasher, i have seen the wire nuts either come loose or burn off due to loose connections.
Jul 02, 2009 | Kenmore Dishwashers
WATER LEAKS UNDER THE SINK WHEN DISHWASHER IS IN
Check the connection to the drain tailpiece from the dishwasher under the sink and make sure the clamp hasn't slipped off and is tight. Check the drain hose from the dishwasher and be sure it's not split or damaged. Check the drain spur on the drain tailpiece and see if it's corroded or leaking. Check the trap under the sink as well and make sure it's not leaking.
Mar 27, 2009 | Jenn-Air Dishwashers
GE 24 in. GSD2000Z Built-in Dishwasher Logo
153 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
