Question about Yard Machines Red Edger
I cant open up my whipper snipper, yard machine, the cord is not coming out so that i can use it.
    Top Expert:
  • Yard Machines Master
  • 51,185 Answers
Many times when using the line gets too hot and welds it's self together and we have to PULL it out manually
Posted on May 24, 2015
2 Suggested Answers
SOURCE: my stihl fs36 Whippersnipper continues to flood what is the cause
needs a carb kit with needle valve $20 at a small engine store
Posted on May 22, 2011
How to remove Rockwell whipper snipper cutting hub
cutting hubs on trimmers are held on by a left hand thread nut
turn the hub center / nut in the right direction ( as if doing it up)and it will come undone
Jan 09, 2016 | whipper snipper Garden
Restringing a talon hawk whipper snipper
There may be a latch that has to be released in order to rotate it.
Jul 19, 2014 | whipper snipper Garden
Pope whipper snipper starter cord problem
The first thing you need to do is take the recoil cover off. There are several parts to a recoil and one or more parts may be worn and coming out of place then jamming.Replace worn parts if this is the case. If the cord pulls freely when removed then you may have a problem in the engine, try turning the flywheel by hand with the spark plug out. If it does not rotate there is something inside the cylinder or broken in the crankcase. If it is a 4 stroke engine you may have fluid above the piston,you will find this out when you remove the spark plug. drain the fluid from the cylinder and replace the plug you will be good to go. Good luck
Feb 09, 2014 | Garden
Sthil whipper snipper fs38 won't engage the starting pull mechanism, it turns but won't grab drive coupling
remove the recoil cover and check the dogs that engauge the starter to the flywheel
Jul 28, 2012 | whipper snipper stihl fs 38
What would have caused my talon whipper snipper to seize?
hello, lack of lubrication will make engine seize up,and also when the trimmer is hung up with the engine down the cylinder will fill up with fuel to where you cant pull rope,found this out myself,hope this helps,,
Feb 20, 2012 | Garden
Homelite whipper snipper amnyal needed. I need to know the size of the cutting cord or citting line size and the fuel mix for the homlite whipper snipper model HBC265JSNB SN1008015039 LwA N197 are all...
This Homelite gas trimmer runs on a 50:1 mix of unleaded automobile gasoline and two-cycle engine oil. That is equivalent to 2.6 fluid ounces (80 ml.) of oil to one gallon of gasoline or 4 tsp. (20 ml.) of oil per quart of gas, or 2 tsp. (10 ml.) of oil per pint of gas. Don't use automotive motor oil or two-cycle outboard motor oil in your Homelite gas trimmer; they contain additives detrimental to trimmer performance. Use mixed fuel within 30 days.
Feb 07, 2018 | Garden
My stihl fs36 Whippersnipper continues to flood what is the cause
Mar 17, 2010 | Yard Machines Garden
Yard Machines Red Edger Logo
1,026 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
