Question about Microsoft Xbox Console
Original Xbox disc tray not opening properly
I have just bought an original xbox system used. The problem is the tray will not open by itself when there is not a disc inside. If you tap on top of the tray then it will pop open. When the disc is inside it opens fine. Is this worth keeping or is it a serious problem.
  • 39 Answers
I found this posted on cheapassgamer.com
Greetings, Ladies and Gentlemen.
Since I was able to solve my Xbox's tray problem completely (for now) due to this site, I felt it necessary to contribute to the forum, in order to (hopefully) help the next person with the same problem.
First, let me note that my Xbox has a Samsung drive. This method may only work if you have a Samsung or Hitachi drive, as they have the lever action emergency release.
Issue:
A) Xbox DVD tray will not eject when eject button is pressed, instead making a clunk / thump noise, as if being blocked from ejecting due to media inserted incorrectly – irregardless if media is present in the tray.
B) Tray will sometimes eject if button is pressed multiple times.
C) Tray will only eject if Xbox is thumped upon directly above the tray.
Solution:
A) First, go to http://www.xbox-mod.co.uk/index.php?...mergency-eject . Then, scrounge up a paper clip and proceed to manually eject your DVD tray.
B) Next, remove the Xbox logo front panel from the DVD tray. This is fairly easy to do, but you must be gentle, or you might break the tray or the front panel. The way to remove it is to take a pair of needle nose pliers and use them to gently pull the bottom clips away from the tray's underbelly before pushing the front panel up. You can also unclip one side, then the other if you are having difficulty.
C) Use the eject button to close the tray. Now open it again. If it still refuses to open (as did mine), use the paperclip and manually eject the tray.
D) Now, loop your finger through the open DVD laser slot in the tray, and gently pull the tray towards you – it will come out a wee bit more, and then stop. Do not force the tray to extend any farther than that.
E) WHILE THE DRIVE IS STILL OPEN, use your paperclip on the manual eject lever. It may take a moment to trigger it, as it is currently depressed, but if your Xbox and DVD Rom are like mine, it will actually draw the tray back in.
F) Poke the Eject button. It should pop open without any argument at this point. Try it a few times, just to be sure, if you'd like. Then, slide the front panel back onto the tray, and you should be good to go… until the next time the P.O.S. decides to slip a gear.
What's that? Slip a gear? Yep. As far as I can tell, that's exactly what is causing the trouble with the drives. Pushing them closed with your finger will force the motor to engage, yes? Well, eventually it seems the cheap DVD Rom's in the Xbox get fouled up, the motor kicks in a bit too late, closes the tray too far, and slips a gear. Then it will clunk / thump at you impotently until you fix it. What we have just done seems to reset the engagement point on the motor, and allows the eject button to work properly again. An easy solution to this problem is to always use the eject button to load and eject media, but you can't always ensure your guests are going to adhere to that policy (Or that the Xbox won't pull it shut too hard just to spite you, the foul tempered little…).
For Thompson and Phillips Drives, that use a gear to manually eject the tray, I would assume that pulling the tray forward, then advancing the gear manually until it refuses to do so, and then pushing the eject button might work. If anyone tries this and succeeds, reply to this message and let us know.
Thanks again for leading me to my solution (even if it may only be temporary), and I hope my suggestions have led you to yours."
Hope this helped please rate.
-Ryan
Posted on Feb 19, 2009
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
My xbox 360 is acting up, when you put in a disc, the system will say open tray. it sounds like two low woop sounds as it tries to read the disc, but overtime it says open tray... and just yesterday it was...
This is a problem occurring in all the xbox 360 consoles....... this is mainly because of the poor quality of thedisc,.....as a result it leads to the damage of ur xbox lens..............usegood original discs........the heating effect is due to the long usage ofpirated discs ...
check your lens if its working good then betterdownload this Repair Guide for further information .........
all the best........
click here to download
Dec 07, 2010 | Microsoft Xbox 360 Console
I have never played XBox and have just been given an XBox original. I have hired a game from local shop, turned on Xbox put in disc, what do I do now to start to play
to play a game in the original xbox you just put the disc in and close the tray. They load automatically. For more information on how to use your newly obtained xbox original here is the user manual in PDF form you will need a pdf reader to open it such as adobe reader. click here for original xbox user manual. Im wondering since you say you just got a game from a local shop, Make sure it is an original xbox game. If you need further assistance please let me know and i will be glad to assist you further. thanks, Midwest-tek
Aug 28, 2010 | Video Game Consoles & Games
Original XBOX will not read games or DVDS
original xbox??..
meaning the black one???
or the xbox 360..
if its original xbox, send it for a replacement already
if its 360,
does it say reading and just goes back to open tray??
-check the time and date settings on the console, even the time zone
-check if there is any corrupted file on the hard drive
-try to load a disc without the harddrive,if this works you need to perform system maintainance on the xbox
Jun 27, 2009 | Microsoft Xbox 360 Console
Xbox disc tray not opening. seems like disc is hung up in loader but just won't open.
Right after your push the button to open the try and the light is flashing, gently push the tray to one side or the other. My xbox does that to me and it seems to work in my case. I hope this helps you.
Apr 13, 2009 | Microsoft Fable for Xbox
Disc wont read
Hi
Are you using a modded Xbox 360 console?, if not then the disc you are trying to play is probably a copied Xbox 360 disc which would not work on an original Xbox 360
Regards
KreativeGeek
http://gamingbox.wordpress.com
Aug 30, 2008 | Microsoft Xbox 360 Console
Original xbox disc tray
Hide the remote. Does that help?...accordianman
Jan 24, 2008 | Microsoft Xbox Console
Disc tray stuck closed
Is it making the noise like it will open then getting stuck? If so, this can be tricky! It happens with me sometimes. Press the open button and as it goes to try and open push the disc tray in slightly and up and it should pop open, it does with me anyway.
Oct 22, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
3,071 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
