compaq presario V6000 and my OS is windows xp sp3, thank u so much for ur response. compaq presario V6000 and my OS is windows xp sp3, thank u so much for ur response.
I have hooked up two different laptops and both show "No Signal." It cycles through all the options for connecting but never finds a signal. I have used an Compaq Presario 3000 using Windows XP SP3, which used to work with it, and a Compaq Presario F500, using Windows Vista, SP1(?) which also used to work with it. TIA.
Hey! on some laptops you need to connect the projector. If you tell me what type of laptop you have, i will try and solve the problem:)Hey! on some laptops you need to connect the projector. If you tell me what type of laptop you have, i will try and solve the problem:)
You can't post conmments that contain an email address.
Hello
The Display driver may not installed properly, or not configured because the display has dual display mode which could be switched from Fn+Function Key, or by restarting the computer while projector is connected.
Hope it will helps, feel free to contact for more assistance, do rate the solution if got help
Good Luck
Toshiba's s8. Designed to deliver stunning images in breathtaking XXL format, the TDP-S8 features 2000:1 contrast, the latest DLP technology for brilliant color and sharpness, and 2000 ANSI lumens brightness for top performance. The product retailed for close to two thousand dollars. Due to problems production was discontinued. If it works for you then you got a good deal. Replacement parts are easily available on ebay.com for reasonable prices.
after installing the new lamp, hold the volume top & bottom key simulteniously, when green light indicate at panel start the projector & go to service there you may found reset lamp ? press yes the lamp will reset.
First make sure your signal cable is ok and well connected.
Next check the projector input settings in the menu, and confirm that you have the correct input selected.
Also make sure your Laptop display settings allow for an external monitor.
Baba Anji
