Check under the ribbon, in front of the carrier, there is a ribbon/ stencil button. Push the button in the middle. The ribbon mechanism may be in stencil.
Painting a pattern on your wall can be very difficult if you want all the shapes to be the same size and level. But just like when you were little and had letter or shape stencils to help you draw perfect drawings, you can make stencils yourself for what ever it is that you want to paint on the wall.
Using a sheet of cardboard or a contact sheet draw and cut out the shape that you want to paint. If you want to make a pattern that goes all the way around the room then you should make two or three stencils so you can level them.
To use the stencils first prepare the wall you want to paint, you want to paint the base color before you use the stencil because painting around your design can be very challenging. When the wall is dry take your stencil and using painters tape, tape the stencil to the wall so it doesn't move. Making sure that you don't over load the paintbrush paint inside the stencil trying to be careful around the edges. When you finish filling the stencil carefully lift it off, make sure that there isn't any paint on the underside of the stencil because if there is and its wet it will leave unwanted marks on the wall.
Repeat the process of taping, painting and lifting until you have finished painting your pattern on the wall. When you are finished step back and enjoy your handiwork.
You have a stencil and use this to print ink in a
design onto a material. You can also use more than one stencil to make
different colored images. This is also known as silkscreening or serigraph
printing.
Behind the cutter unit is A black sponge roller, turn it manually by hand, you will find A small piece of master/stencil there. Remove it and reload the master/stencil roll.
Just take the 6 x 9 spkr that you intend to install and lay it face down on a piece of cardboard and trace the shape with a pencil, mark the spots for the screw holes and cut out with scissors. this makes a perfect stencil.
I am a major seller of these machines in ebay. The machine may need a new potentiometer. Build a carrier. Put two pieces of transparency plastic sheets together with a piece of tape and use this to carry your stencils. This will reduce the heat of the lamp. Rouben ([email protected]).
