Question about Vizio L37 Television
Can't tape record TV programs onto combo DVD/VCR.
Zenith combo DVD/VCR, Model XBV713, connected with S video cable from back of Zenith to AV1 side of Vizio VX32L, HDTV. Audio connected from red & white outputs on Zenith to AV1 on Vizio. Can't playback or record DVD's or tapes through AV1.
Use of red, white, yellow jacks from DVD/VCR outlets on Zenith to AV2 inlets on Vizio works well for playback of DVD's or tapes. Can't record TV programs though with AV2.
How to record TV shows onto Zenith VCR?
3 Suggested Answers
  • 244 Answers
SOURCE: AV1 / AV2 Connections don't work
No picture or dark picture
Check R516 (56Kohms, 0.5w) or R517 (27Kohms, 0.25w) for high
Will not come out of standby, no picture
If at power on voltage on pin 37 of the micro drops low then reverts to 5v suspect memory chip ICA07 (Toshiba 23319016)
No picture No sound
Faulty IC TDA6107q on crt board
No picture on e-e, I.F output ok
This was due to switching chip IC3901 (M51292FP) on the scart panel
Posted on Nov 26, 2007
phongnv
  • 56 Answers
SOURCE: my vizio vx32l will not turn on. vizio logo will
The main board has failed. Replace the main board will fix the problem.
By the way, where did you buy the TV? If you have bought it from Costco then try to give them a call to see if it still under warranty.
Hope this will help.
Posted on Feb 19, 2009
How do I hook up the DVD/VCR to cable box and Vizio HDTV?
both should be hooked directly to tv
VCR side of combo should be hooked up with composite video(yellow, red, white wires) to video 1 input
DVD side of combo should be hooked up component video (red, blue, green wires and red white for sound)
cable box should be hooked up HDMI or component to TV if HD or composite video if SD
hope this helps
good luck
Mar 13, 2011 | Samsung DVD-V4600 DVD Player/VCR
Can't get video on vhs sound but no picture, is it broken
I had the same problem, so I took it back to basics. Hooked cable into VCR/DVD player and another cable from player to TV. S cable too, plus red/white audio. Plays DVDs on AV1 and VHS on Channel 3 on TV setting.
Jun 30, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have cable hooked up to my tv. Now I am trying to add dvd player, but nothing is showing up like I have it connected.
If you look at the rear panel, you will see the sticker showing AV1 and AV2 for the composite Video and Audio in.
Use AV1 inputs, just match the colors of the RCA JACKS at both ends of the cables, Yellow is for Video, Red is for Right channel audio, White is for Left channel audio. Just match the color. The using the remote to select AV1 then you can watch DVD. I have same model.
User manual: http://www.vizio.com/l32hdtv10a.html#support
http://s807.photobucket.com/albums/yy352/budm/VIZIO%20L32HDTV10A/
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 15, 2010 | Vizio L32 32 in. LCD HDTV
How do I RECORD FROM A CAMCORDER TO THE DVD SIDE OF THE UNIT
  1. Connect the camcorders yellow, red, and white (Audio/ Video) to the input on the back of the combo called AV1 or Video 1.
  2. Then turn the channel on the DVD recorder to AV1 or Video 1. (A couple channels down from channel 2)
  3. Make sure camera is in VCR mode and hit play on camera
  4. You should see your camera video on your TV and rewind to the place you want to start recording and hit stop.
  5. Put an empty DVD in recorder and hit Rec. Button (usually red)
  6. Then hit play on your camcorder until you would like to stop
  7. Then hit stop on your DVD recorder and each section like this will be another chapter.
Good Luck
Oct 09, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
All my problems are with the hookup of tv and dvd/vcr combo. Just can't do it. Is there anyone I can call tv repairman? I hear the Geeks only work on computers.
Simple matter. The Yellow cable will connect from Video Out of VCR to VIDEO IN of TV. Red cable will connect from AUDIO OUR (R) of VCR to AUDIO IN (R) of TV and AUDIO OUT (L) of VCR will connect to AUDIO IN (L) of TV. Play VCR or DVD and select AV1 or AV2 of TV using TV remote control.This button may also be labelled as TV/VIDEO on your TV's Remote Control
Jun 09, 2009 | Sony Televison & Video
Hook up Memorex MVD4544 DVD/VCR combo
ok on the back of the dvd player look for the yellow red and white plugs you should have gotten a cable with yellow white and red plugs match the colors from the dvd player to the colors on the back of the tv labeled VIDEO 1 then plug the power in and tune the tv to video 1
Mar 27, 2009 | Televison & Video
Need a region code hack for Zenith DVD/VCR combo XBV713
you might want to region hack it.
the procedure can be found here
Dec 30, 2008 | Zenith XBV713
I need a region code hack for Zenith DVD/VCR combo XBV713
OK... now some DVDs cannot be hacked / or unlocked for regions BUT
go to e-Bay and search for dvd region unlock code... there are some there BUT go into a couple to see if they will let you contact them FIRST to see if yours can be unlocked BEFORE YOU BUY.
Good luck...
Blue screen
At least a couple of possibilities, check the yellow video cable that runs from the VCR to the TV, is it plugged into the side of the combo unit that says vcr?
Is your TV on the right source? You could have plugged the audio into say AV2 and the video into AV1, causing a mismatch. Make sure the yellow, red, and white are all plugged into one input section on the TV (AV1, AV2, Video 1, Video 2, etc).
Dec 09, 2008 | Philips MRV700VR DVD Recorder/VCR
HOW DO I CONNECT MAGNAVOX DVD/ VCR TO VIZIO FLAT SCREEN
Is simply. get the audio/vido cables and look on the back of the TV and connect from the audio video outputs from the combo to the audio video inputs on the tv. remember the colors of the terminals and connect them that matches the red, white (audio) and the yellow (video). Using the remote locate the button "input" or "source", and select video 1 or 2, depending where you connected it.
Nov 18, 2008 | Philips Magnavox DVD/VCR Dual Player
Vizio L37 Television Logo
265 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
