Most DVD players are region-locked, meaning they will only play disks encoded in the location they are from, or disks without region-specific encoding. For example, if I bought a DVD player in Europe and tried to play a disc from the United States, it would not play. Unfortunately, in order to get past the "area limitations" you will either have to buy a DVD encoded in the same format as your DVD player, or set the player to a different region code (which often will lock the player after a certain number of times).
SOURCE: DISCWON'T PLAY, RECEIVE MESSAGE "THIS DISC CANNOT BE PLAYED, PLAYBACK PROHIBIT BY AREA LIMITATIONS
i am ohamed scondo
i have pdf repair
SOURCE: need unlock code.
I found this region hack here Sony DVP-NS575P region code , check it out:
"Warning
The following guide describes how I managed to make my Sony DVP-NS705V DVD player multi-region.
There are no guarantees that you will be able to do the same. Be
aware that you will probably void any warranty you have and possibly
even break the player.
Put shortly, you proceed at your own risk.
Introduction
First of all, the Sony DVP-NS705V can be made multi-region simply
by applying appropriate service codes, you do not need to install a so
called "mod chip".
This supposedly applies to the entire NS-series of Sony DVD
players. There are some encouraging reports out there supporting this,
but nothing has been verified by me. Again, if you choose to apply this
guide to any DVD player, you do so at your own risk.
If you do find that this procedure works on another model, please drop me a line at [email protected] and let me know. Include the exact model number and original region of your player.
Update: Some users have reported success on the following players:
DVP-F21 (special thanks to Garry Self for this one)
DVP-LS500
DVP-LS755
DVP-LS785
DVP-NC615
DVP-NS300
DVP-NS305
DVP-NS310
DVP-NS315
DVP-NS330
DVP-NS333
DVP-NS355
DVP-NS360
DVP-NS400
DVP-NS405
DVP-NS410
DVP-NS430
DVP-NS433
DVP-NS575
DVP-NS585
DVP-NS590
DVP-NS700
DVP-NS730
DVP-NS765
DVP-NS900
DVP-NS905
DVP-NS930
DVP-PQ1 (thanks go to Michael Joy for this one)
DVP-PQ2
RDR-GX3 (thanks to Andreas Norman)
RDR-GX7 (thanks to Daniel Tapie)
RDR-GX300
RDR-GX700
RDR-HX900
RDR-HX1000
Please note that not all players behave exactly like the NS705. For example, some players do not display "success" when hacked.
Thanks to all who have contributed.
The infrared service codes required to make the update are
available on the Internet. Unfortunately, not many people have an
appropriate device to enter the codes into. You basically need a
programmable remote (Philips Pronto, One-For-All) or a PDA (Palm, iPAQ)
with suitable software.
This guide shows you how to make the update with a regular PC equipped with an IRDA port.
The procedure
1. Download the winsamp -package from Blank Frank's site.
http://www.veg.nildram.co.uk/remote.htm
This innovative piece of software allows you to send standard home electronics IR signals using a PC IRDA port.
2. Extract the package onto a bootable DOS floppy disk.
3. Download this IR code
http://www.selen.org/files/REMOTE.TXT
file and place it in the same directory as the package above.
This file holds the five necessary IR codes converted to the format
used by Blank Frank's winsamp.exe. Please do not bother Frank with
questions concerning this particular procedure.
4. Boot up your PC from the floppy disk and run winsamp.exe.
If your IRDA port doesn't appear as COM2 you may override this by
using an appropriate command line switch. For example, use COM1 by
running 'winsamp C1'.
5. Press the 'r' key to load up the codes into winsamp.
6. Make sure your DVD player is in standby mode and your IRDA port is within range.
7. Run the IR codes from 1 to 5 by pressing Enter on each corresponding button.
8. Your DVD player should start up and display the text "SUCCESS".
9. Repeat step 7. Your player should return to standby mode.
10.Your player is now multi-region."
SOURCE: my dvd player says playback prohibited by area
Sounds like it's the wrong region disc. Try a disc that worked before and if it does than there is nothing wrong with your dvd player it is the disc you are trying to play that has the issue.
SOURCE: wondering why my dvd player
This is a common problem on Sony players.The reason with every DVD so far is that they have been PAL (a European format) instead of NTSC (an American format). This is unrelated to the "region" limitations on the disk. It is the actual size in pixels of the picture. This is no fix for the same. The entire thing would have to be re-encoded.
From what I have seen the Sony players adhere stringently to DVD Specs.
That means a NTSC version of the player will not play a PAL disc.
That also means a PAL version of the player will not play a NTSC disc.
It is understandable when you think about the fact that Sony also owns
content production. Therefore their player will adhere to region
settings and only the supported type of disc, NTSC or PAL.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
