Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
Heater will not ignite checked lines but heater
Heater will not ignite checked lines but heater is not dispensing fuel to ignite.
  • 181 Answers
What is yor air pressure?have you checked you rotor to see if it is broken.all pro's are note for that.
Posted on Feb 24, 2009
Pentair mastertemp 250 NA. heater will not fire, no error codes. starts fine, gas flows, igniter heating but still will not fire. It has a new valve, gas pressure entering valve from new regulator is 8.35...
All appearances - No fuel to ignite!
evrything else looks good, proper gas pressure, proper volts at igniter, etc - it should ignite! If fuel present, heater should Fire!
make sure all valves are open.
Gas valve is ON
AND purge any air from gas line.
IMPORTANT ****. If you bled gas line, don't try to ignite for a few minutes. Allow gas to dissipate first, use a fan to help.
Mar 05, 2015 | Pentair Mastertemp 250 Natural Gas Pool...
Dyna glo pro forced air heater won't ignite?
I've had mine for about 8 years now. Just started spitting out fuel and failing to ignite. Took it all apart and found a couple of cracked lines where they went on to the fittings. One was to the air pump and the other was a fuel line at the manifold. Cut them both back and reattached, but it still wouldn't ignite. Then I checked the pressure coming off the air pump and it was at 2 psi, should be at 3.4 on mine. Adjusted the fuel pressure up and bingo, it lit right up as soon as the pressure was right.
Jan 02, 2012 | Dyna-Glo Heating & Cooling
WE HAVE A 15,000 BTU HEATER. THE IGNITER HEATS UP ANN THE PUMP STARTS, THE FUEL IGNITES THEN SHUTS DOWN IN JUST A FEW SECONDS. I CHANGED THE PHOTOCELL NO HELP, CHANGED THE CONTROL ASSEMBLY, NO CHANGE. THE...
Try checking the air line and make sure it's tight where it connects to the compressor and the fuel nozzle. Also check the fuel line where it connects to the fuel filter and the fuel nozzle. If the ends are cracked or stretched, make sure you will have enough left to reconnect then and trim some off of the ends so they will fit tight and won't leak air. Let me know if this doesn't help. If it does please take time to vote and leave feedback. nitensheaterservice@earthlink.net
Jan 12, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
Heater keeps shutting off what could it be cant find manual to help
Use this manual to assist you in troubleshooting. http://www.bealsmotor.com/Desa%20Hot%20Surface%20Manual.pdf
The manual will help you isolate the problem.
Things than can cause your symptoms:
1. Pump pressure incorrect
2. Dirty air intake, air output
and/or lint filter
3. Dirty fuel filter
4. Obstruction in nozzle
5. Photocell assembly not properly
installed (not seeing the flame)
6. Dirty photocell lens
7. Bad electrical connection between
photocell and ignition
control assembly
8. Defective photocell
9. Defective ignition control
assembly
10.Line voltage is below 108V or
above 132v
REMEDY corrosponds with 1 - 10 above
1. Fill tank with kerosene
2. See Pump Pressure Adjustment,
page 10
3. See Fuel Filter, page 11
4. See Nozzle Assembly, page 12
5. Drain and flush fuel tank with
clean kerosene. See Storing,
Transporting or Shipping,
page 7
6. Check electrical connections.
See Wiring Diagrams, page 16
7. Replace ignitor, see page 11
8. Replace ignition control
assembly
9. Check for proper line voltage
1. See Pump Pressure Adjustment,
page 10
2. See Air Output, Air Intake and
Lint Filters, page 10
5. Make sure photocell boot is
properly seated in bracket
6. Clean photocell lens
7. Check electrical connections.
8. Replace photocell
9. Replace ignition control
assembly
10.Check for proper line voltage.
Disconnect power equipment
that may be used on same
line
Thanks for choosing FixYa,
Kelly
Jan 09, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
My master heater will not ignite. i have replaced all air filters i have changed the back cover, it was cracked, i replaced the rotor and blades in the air pump and set the air at 6.4 pounds like the book...
The first thing to check would be the ignitor. If it is not working, then check the connections between it and the ignition control assembly. If the connections are fine, check to see if there is any voltage being sent to the ignitor. If there is then replace the ignitor, if not, then replace the ignition control assembly.
Dec 28, 2010 | Master Heaters B200BT
Reading says EE 2 what does this mean
Hi Sandra, EE 2 means that the heater did not ignite. There could be several causes. First let me ask, did the heater make a ticking or thumping sound before you got the EE 2? If so that means the fuel isn't getting to the fuel sump. It could be caused by an air bubble in the fuel line, a clogged filter at the tank (if you use an outside tank), or a clogged fuel strainer in the fuel sump. EE 2 could also be caused by a bad igniter. Did the heater light at all? If it did then the igniter is good. If it didn't the easiest way I have found to check the igniter is to use a clamp on ammeter or use a multimeter to check the resistance of the igniter. Another cause is a dirty flame rod. If the heater lit then went out I would suspect this. It can be cleaned with some steelwool or fine sandpaper. Let me know what you find or if you need more info.
Oct 04, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
My Dyna glo Heater RMC-KFA210WH-03 will not fully ignite
I just bought one. The fuel line was cracked. Replaced it 2$ fix
Jan 27, 2010 | Dyna-Glo (PPH16-LP) Utility Heater
I have a Dyna Glo-pro multi fuel heater. When I turn it on the ingitor starts working and than the fan comes on for a few seconds. Then the system shuts down because it willnot ignite. The tank is full and...
Since it does not ignite, Please check the ignition transformer. This have a secondary voltage of about 20,000 to 25,000 volts, enough to make your igniter
spark, thus, causing the atomized fuel to ignite and burn the fuel. So, please include igniter high voltage cable for ground leak. Ground leak is visible as line sparks when your heater is switched on. If your ignition transformer does not produce sparks at the
igniter, it means it needs to be replaced.
Have it done to make it work. Hope this will help you.
Jan 10, 2010 | Dyna-Glo RMC-8001SS Heater
Reddy Heater Doesn't fully ignite
First thing I would do is clean all of your air and fuel filters and check your lines for breaks. A lot of times they will do that if your not getting enough air to fuel mix. If it continues after that it's the CAD/ flame sensor which you can get from MR. Heater for 3 bucks they are all basically the same and I know reddy heater wants 18 for the same thing.
Jan 27, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Ignition
This is a "probably". The reset button trips because the photocell fails to see a flame in the combustion chamber. That's its job.
Check the ignition device ( transformer, coil). See if 110v going in. If there is no spark coming out, replace it.
Troubleshooting tips
Jan 10, 2009 | Reddy Heater-30-55,000 BTU Variable
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
218 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
