Question about Garden
Toro lawn mower engine starts and then stops after 2 to 3 seconds
Changed plug
changed oil
drained gas and replaced
  • Anonymous Mar 18, 2014
    no problems
  • Anonymous Mar 30, 2014
    I do not get a spark from the spark plug when grounding the spark plug to the engine s I test fora spark.
I had this problem and the nut was plugged. After i cleaned the nut, it ran perfect.
Thank you very much!
Posted on Aug 23, 2009
Toro zx 5420 oil change
The lug is under the mower. There should be a square plug that is the oil drain plug. Disconnect the spark plug first then remove the oil drain plug. You should have the muffler facing up because oil will get into the cylinder and cause blue smoke when the engine starts if you don't.
May 18, 2014 | Toro Garden
Why does yardworks 173cc bs engine will start, run, for 2-3 seconds then stop
Bad gas. Drain gas and refill with fresh gas with Stabil. Old oil. Drain oil fill with fresh 30w oil, 16-18oz. Clean air filter and spark plug.. Relpace air filter if dirty. Saving $$$ on this simple tune up is not intelligent.
May 11, 2014 | Yard Man YardMan 11A41K3001 21Inch 173cc...
Toro ride on wont start
Battery required? Charge battery or replace. Replace air filter and spark plug. Dump out old oil and replace with 30w oil. Electric start may have a fuse blown. Dump out old gas fill with new with Stabile always added to gas. Try spraying starter spray in carb at air cleaner with filter removed. All mowers have a low oil sensor to prevent starting on low oil. Remove bowl from carb, should be full of gas. Pinch off fuel line with pliers or turn fuel valve off. Check float should be hanging down allowing fuel flow. Float up stops fuel flow.
Sep 19, 2012 | Toro Power Lawn Mower
Where is my drain plug on my toro lawnmower
there is one on the bottom of the engine i just run mine out of gas the turn it on it's side and drain it from the dip stick tube
Apr 12, 2012 | Toro Power Lawn Mower
After trying to run a water hose through it to clean my Toro 650 190 CC lawn mower has refused to start for me, let me add before the hose I turned it upside down to get out excess grass, Now I've...
Only tilt a lawnmower backwards toward the handle end (spark plug end raises) Other ways move the oil around to places it doesn't need to go. Now you probably have gas in the oil....check it or change it (milky looking or smells like gas..contaminated...might need changing anyway...You probably will have oil in the carb and it will blow smoke...You probably filled the oil breather with oil and it will drain down...causing smoke also. This was the wrong thing to do A 2 year old unit should be mechanically sound..Check the air filter, spark plug and carburetor for oil fouling. Remove the bowl on the carb to help get some of the oil will leak gas when you do.
Jun 10, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Toro Lawn Mower 20017 serial # 250000001 shaked and smoked while
drain the oil...the gas seeped into the cylinder and into the crankcase...fresh oil, a clean plug, should do the trick...
May 02, 2010 | Garden
Mower starts but won't run
Check gas line. Check for a gas filter and replace it. Replace spark plug. If the prob continues - it might need the carb rebuilt.. If a small engine sits to long without being run - the gas will shellac in the carb and render it to not function properly..
have a great day !
Apr 09, 2010 | Toro Lawn Mower With Toro Power Tools
I have a 2006 Toro 6.75 hp GTS lawn mower. I am
Your carburetor needs cleaned,you had gas in it that you drained out and replaced with new ? What engine do you have tecumseh,briggs,? Anyway remove carburetor and take apart get acan of carburetor cleaner and spray though jets in carburetor and blow out jets be carefull not to blow out needle seat !
May 15, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
972 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
