Question about Lexmark X5450 All-In-One InkJet Printer
LEXMARK X5450 PRINTER--PAPER WILL NOT FEED INTO PRINTER
PAPER STARTS TO FEED BUT THEN STOPS AFTER SHEET IS MIDWAY THRU...IF I TRY TO ASSIST PAPER BY BY TRYING TO PUSH IT A LITTLE, I GET PAPER JAM INDICATOR ON LCD--BEFORE THE PAPER STOPPED FEEDING ENTIRELY, IT STARTED FEEDING UNEVENLY AND OFTEN JAMMED, THEN JUST STOPPED FEEDING ENTIRELY,.CHECKED AS MUCH AS POSSIBLE WITHOUT TAKING IT APART AND NO VISIBLE BLOCKAGE..ANY TIPS OUT THERE??
  • 1 more comment
  • jandjsmom29 Feb 21, 2009
    put in new ink, paper wont feed, what part does feed goes in crooked, i can hear the printer clicking but it isnt printing because the paper doesnt go in!!!
  • dliendo Mar 11, 2009
    I have been able to only make 5 copies on my X5450. When paper is trying to feed it pulls to one side and jams.
  • kenny_eakins May 10, 2009
    I'm trying to print something and it says there is a paper jam. I open it up to find that there is no jam. I try and press the select button but it just beeps. It also beeps when I try to press any other button as well.
I need a solution to get out of my lexmark x5450
Posted on Jun 09, 2010
Epson wide format printer stops in the middle of a job saying paper jam. But I know it is not paper jam.
I do not know this particular printer but several things might be wrong. Make sure all the paper handling sensors and rollers are clean. Check to see if the next sheet of paper is sticking to the first and blocking a sensor. Check to see if the paper is advancing properly. Sometimes the roller will spin but slips on the paper, if the printer senses that the paper is not advancing properly it will throw a paper jam code. Make sure you are using fresh, crisp paper and the holding tray is at least half full.
Mar 17, 2016 | Epson Stylus Pro 10000 InkJet Printer
Lexmark
Please contact Lexmark technical support center to check your available options.
Dec 22, 2011 | Lexmark X1270 All-In-One InkJet Printer
Miss feeds when print multilpe pages
The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
Sep 02, 2009 | Konica Minolta magicolor 2300DL Laser...
Lexmark Z715 printer feed paper
The feed rollers might be dirty from the ink. Try cleaning them with a Q-TIP with a little isopropyl alcohol.
Jul 31, 2009 | Lexmark Z715 InkJet Printer
Printing stops halfway
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 11, 2009 | Lexmark All-in-One Printer with PictBridge
There's a pencil stuck in my Lexmark x5450
hmmm... try lifting up on the scanner part to open, like you are going to change the ink cart. might have worked its way in there thats about the only reasonable entry point i can think of. and please try not to shake it more than you have to. they dont like that :)
Dec 25, 2008 | Lexmark Z735 InkJet Printer
My paper goes to one side when printing starts and it does not print ny work
There may be a scrap of paper stuck in the machine, interfering with normal paper feed. Turn off the printer, and try to force a sheet of paper through the printer by hand. Feed the paper only in the normal direction that the paper goes. Forcing it by hand may push out the stuck scrap. Thin cardstock can be used instead of paper.
Nov 30, 2008 | Lexmark Office Equipment & Supplies
HP paper jam
That is usually caused by the paper feed rollers being cover with paper dust. Take a clean cotton pad and alcohol and clean the rollers :turninig each roller as you clean it. if it has a rear dor, open it to get better access to the rollers.
Please remember to rate all users who assist you for free :)
Sep 03, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Oct 03, 2006 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark X5450 All-In-One InkJet Printer Logo
564 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
