Question about Dual Audio Players & Recorders
How to connect a sr430qx equalizer to abpm500 gemina mixer and a carvin dcm2000
    Problem Solver:
  • 11 Answers
All of three of these components have balanced connections. There are many different ways to connect- but this is the best option. You will need 4 x standard XLR3(cannon) mic leads. Starting from the Gemini mixer:
take the left output and plug it into channel 1(A) of the DOD EQ
take the right output and plug it into channel 2(B) of the DOD EQ
then...
Connect the EQ output of channel 1(A) to the input 1(A) of your Carvin amplifier
Connect the EQ output of channel 2(B) to the input of 2(B) of your Carvin Amplifier
Happy DJ'ing
Rus.
Posted on Feb 19, 2009
Graphic equalizer
You connected your dvd player to WHAT mixer?
Connect your DVD to any one of your LINE IN jacks and your equalizer to one of the TAPE IN-TAPE OUT loops.
Apr 20, 2014 | Audio Players & Recorders
Studiomaster manual
On the rear panel there are two jack socket marked: Left and Right Insert.
These are connected to the graphic equalizer using two insert cables, one for each channel ( L & R). The cables have a stereo 6.35mm jack plug which plugs into the mixer, the cable splits into two mono jack plugs marked tip (or send) and ring (or return). The send (tip) connects to the input of the graphic equalizer and the return (ring) connects to the output of the graphic equalizer. How it works: The stereo jack interrupts the signal in the mixer and sends it to the equalizer, the equalizer processes the signal then sends it back to the mixer. Typical cable is shown below. If the equalizer has a different type of socket, phono for example you will need jack to phono adapters or insert cables with suitable plugs. Hope this helps.
Apr 05, 2014 | Audio Players & Recorders
Mixer and an EQ & amp ?
The order is mixer, equalizer and amp. The output of the mixer connects to the input of the equalizer and the output of the equalizer connects to the input of the amp. The equalizer has three types of input and output connections. They are XLR, 1/4 inch and screw terminals. The mixer will have one or two of the three. Choose XLR if possible on the mixer, choose line level output on the mixer if possible. A XLR male to female cable is needed for the connection. The equalizer has two channels, if the mixer has two output channels the two output channels of the mixer can connect directly to the two input channels of the equalizer. If the amp has two input channels, the two output channels of the equalizer can connect directly to the two input channels of the amp. If the mixer only has one output channel then only one channel of the equalizer can be used and one channel of the amp likewise. A XLR male to female connection cable can be used to connect the equalizer to the amp.
Jun 23, 2010 | DBX 1215V Home Equalizer
How do I connect to mixer
aux send out-------------to compressor in-------compressor out-------aux return in.
May 19, 2009 | Pioneer DJM-600 Silver Professional DJ...
How to connect my graphic equaliser to my dj mixer.
aux out(mixer)-------equalizer in--------equalizer out-------aux return(mixer)in.
Apr 18, 2009 | Audio Players & Recorders
Dont know how to connect everything so it all works
you need a small mixer from radio shack near you.
1-connect cd player to channel 1 in mixer.
2-connect tape to channel 2 in mixer.
3-connect mixer out to equalizer in.
4-connect equalizer out to amp in.
Nov 09, 2008 | Audio Players & Recorders
How do i conect equalizer
first connect pre-amp out to equalizer in and equalizer out to amplifier in-and amplifier to loudspeaker.
second-mixer out to equalizer in and equalizer out to amplifier in and amplifier out to speaker.
Jun 15, 2008 | Audio Players & Recorders
How can I make this sound great.
line out from mixer------to crossover in---------crossover out-------to amplifier line in-----------from amplifier out--------to loud speaker.
---from low output(low frequency)of crossover-----to line in in subwoofer.(mixer is ordinary mixer not powered mixer- and in case of powered mixer take care it is line out(0db---to4db)not amplifier out which you connect it to loudspeakers.
May 19, 2008 | Digi-Tech DOD-Digitech 231 - 31 Band Per...
244 people viewed this question
Top Dual Audio Players & Recorders Experts
Jerry Naidoo
Michial Gueffroy
Are you a Dual Audio Player and Recorder Expert? Answer questions, earn points and help others
