Question about Danby DWM99W Top Load Washer
Washer Won't spin & smells burning when it goes on spin
I have a Danby Top Load Portable Automatic Washing Machine--------DWM99W. It washes fine, but when it gets to the spin cycle, it won't spin. Sometimes it will cut in for a second or two and then that will be it. It will just drain out the water but no spinning. I can also smell a burning smell, whenever it cuts in for a second or two. The drum never spins around. I've also noticed that only one of the pulleys that supposed to spin the belt around is going. Not sure if that is how it supposed to be or not. I have replaced the belt, but it still isn't working. Could you please suggest to me how to solve this problem??
  • lebcan128
    lebcan128 Jul 18, 2013
    i have same problem any suggestion, i tried to open the washer today but cannt find the spin belt? any body can advice me about belt location
Hi there.I think it could be that when the belt was changed the bolt wasnt tightened onto the flat side of the spindle.I am talking about the small pulley that comes off to replace the belt.It has one flat side in which the bolt needs to be otherwise it might just spin because the laundry weight. Quick question I have this machine and it needs a replacement belt.I cant find one anywhere!!!!Where were you able to find one???? Good Luck
Posted on Feb 23, 2009
2 Suggested Answers
futureloginn
  • 734 Answers
SOURCE: danby washing machine noisy only during spin cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Posted on Dec 12, 2008
Danby DWM99W washer agitator not working. Assuming its the v-belt?
Try to see eBay.com or Amazon.com. Try to call or visit the place u bought the washer from, they should b able to give u what ur looking for
Jun 03, 2015 | Danby DWM99W Top Load Washer
I need belt for Danby portable washer , model no. DWM99W. Thank you! Natasha
You need to search appliance repair and find a local appliance repair company near you. Tell them the model number and they can look the part up for you and order it if they dont have it in stock. Then you can pick it up directly from them.
Feb 07, 2011 | Danby DWM99W Top Load Washer
Is this a portable washing machine?
yes, it has little wheels on the bottom and uses a quick-release connection to hook up to the kitchen sink when in use. It is only about 21"x21" and 34" tall.
Sep 23, 2009 | Danby DWM99W Top Load Washer
My washing machine stopped spinning! what should i be looking at to fix it???
The door switch is usually the problem. If it fails the washer will not spin or wash correctly. Have this replaced and that should take care of the problem. Hope this helps. Good luck.
Jul 31, 2009 | Danby DWM99W Top Load Washer
I have a new Danby washing machine but leaks from the springs area and several other areas. Will not fill with water and no wash cycle will engage. Seems to drain...spins well...but has an "intermittent...
you have a new washer so why not get the service agents out under warranty to fix the faulty machine
ask why there was water in a new machine as that indicates not new but second hand
May 25, 2017 | Danby DWM99W Top Load Washer
Washing machine problem
could be the door switch or the lid switch. this should, be close in order to drain. and spin. please check it for continuity when the door is close and open when the door is open.
tnx 4 using fixya,
drcool
Nov 05, 2008 | Danby DWM99W Top Load Washer
Won't wash
I didn't realize that you have to let the faucet run the entire duration of the wash cycle. But that was the problem.
May 21, 2008 | Danby DWM99W Top Load Washer
Danby washing machine noisy only during spin cycle
hi there,
Jan 13, 2008 | Danby DWM99W Top Load Washer
Danby DWM99W doesn't agitate properly
Under the agitator, there is a plastic wheel with groove that goes on the metal shaft that is shaking the agitator to wash ur clother. On my machine, the plastic grooves are not there anymore, probably the effect of the cheap plastic rubbing on metal and that is why the agitator is not turning. Porely designed or maybe good design to make you spen money on fixing it. Just change the plastic wheel with a new one and it will start washing again.  Good luck.
Aug 02, 2007 | Danby DWM99W Top Load Washer
Danby DWM99W Top Load Washer Logo
278 people viewed this question
Top Danby Washing Machines Experts
shaun taylor
Jim Y
Jim Y
Samyfam
Samyfam
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
